Welcome to the North American Subaru Impreza Owners Club Wednesday April 1, 2015
Old 12-31-2007, 10:28 PM   #1
TurboQueef
Member#: 86700
2005 STI
Silver/Black,11.44@123.60
Default Is it possible to force leaner AFR in closed loop?
HI..
I am going to be tuning aftermarket cams in my STi.. am running Kelford 276/272's...
I tune with StreetTUNER for RT and Enginuity for the base maps.
I want to know if there is any way to force a more lean AFR during closed loop easy crusing... has anyone figured out how to do this with the stock ECU?
Thanks,
Jeff B
TurboQueef is offline   Reply With Quote
Old 01-01-2008, 01:56 AM   #2
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
yes, it can be done. it is under the Fuel tab in enginuity. look for it.
Wheeler Bement is offline   Reply With Quote
Old 01-01-2008, 10:08 AM   #3
Big Bear uk
Member#: 15344
2004 STi type uk
If you look under closed loop in enginuity you will see a heading for closed loop fueling, it is there you change the AFR. You may need to change the tip in fueling to stop any engine judder , this is what I did and on cruise I could get another 30-40 miles out of a tank at about 70 mph
Big Bear uk is offline   Reply With Quote
Old 01-01-2008, 10:11 AM   #4
Tea cups
Member#: 103136
This is not for the 32-bit ECU, though (OP has an 05 STi). Also, if the parameter is under the "closed loop" category then you are using old ECU definitions and you should update to the latest (will be under fueling category).
Tea cups is offline   Reply With Quote
Old 01-01-2008, 10:27 AM   #5
TurboQueef
Member#: 86700
2005 STI
Yea... not finding any direct input fueling tables in closed loop tab... seems to only allow changing parameters that control when the ECU exits closed loop...
Old 01-01-2008, 10:32 AM   #6
TurboQueef
Member#: 86700
2005 STI
...you are using old ECU definitions and you should update to the latest...
sorry off topic... I am getting a warning box every-time I open my ROM.. it says that a "newer version of this ECU revision exists"... so I downloaded it and I want to know if there is any way to "copy" the values in the modified ROM (old ECU version) to the new (without having to copy every table one by one)
Thanks
jb
Old 01-01-2008, 11:38 AM   #7
Tea cups
Member#: 103136
You still need to update the ECU (and logger) definitions:
http://forums.nasioc.com/forums/show....php?t=1410201
You should not tune with old definitions because each update often contains important bug fixes, not to mention new tables and ecu support.
It is not necessary to update to a newer ROM revision unless there is something specific that will be solved in your particular case with the newer revision, which is why the newer ECU defs have eliminated that "newer revision" message from appearing. Yes, you will have to manually transfer your tune, table by table, to the newer revision if you choose to go that route. I wouldn't recommend doing this unless you know what you're doing (i.e. it is your own tune and you know what you changed). You should be fine with the older revision (although we don't know exactly what changed in the 05 revisions as it is missing from SOA change list).
Old 01-01-2008, 01:23 PM   #8
TurboQueef
Member#: 86700
2005 STI
You should not tune with old definitions because each update often contains important bug fixes,...
Very good info.. I updated with no problem.. thanks a BUNCH for the post...
jb
Old 01-01-2008, 04:24 PM   #9
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
jb
Jeff,
As mentioned in that EGT post on IWSTI that I referenced, you still cannot change the closed loop AFR (1.0 lambda) target with the 32-bit roms using Enginuity (even if you are using the latest defs).
t
WolfPlayer is offline   Reply With Quote
Old 01-01-2008, 04:43 PM   #10
Tea cups
Member#: 103136
Originally Posted by WolfPlayer View Post
Jeff,
t
Yes, this was already mentioned in post 4 of this thread. Regardless, users should always update to the latest defs.
Old 01-02-2008, 04:46 AM   #11
Big Bear uk
Member#: 15344
2004 STi type uk
Ok sorry for the duff info , I don't tend to "upgrade" software for the sake of it , if somthing works I leave it alone (software wise)
Old 01-28-2008, 04:26 PM   #12
GuitsBoy
Member#: 61721
2006 WRX
Steel Grey Metallic
Sorry to drag this back up, but Im looking for the stoich table, and perhaps I just dont know the actual name Im looking for. I have the latest definitions, I believe, 0.8.0b. I just dont seem to see the a table that lets me adjust stoichiometric. Car is a 2006 WRX.
GuitsBoy is offline   Reply With Quote
Old 01-28-2008, 04:38 PM   #13
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The 32bit ECUs don't allow adjustment of CL target.
Old 01-28-2008, 04:42 PM   #14
GuitsBoy
Member#: 61721
2006 WRX
Steel Grey Metallic
Ouch. I guess thats why I cant find it then.
I guess my other option is shifting over the "Front Oxygen Sensor Scaling" table to trick it into seeing stoich as a slightly higher voltage (or is it really milli-amperage). Has anyone gone this route?
Old 01-28-2008, 07:29 PM   #15
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
Didn't someone on enginuity.org shift the lambda definition for the front O2 sensor? They would need to shift the MAF scale too but only for low MAFv. It seems kind of complicated plus the transition between CL and OL would be tricky.
mickeyd2005 is offline   Reply With Quote
Old 01-28-2008, 09:03 PM   #16
Freon
Member#: 88322
2009 BMW 135i
You can skew the front O2 sensor scaling and this will have the desired affect. Keep in mind this will not make you log a different front O2 sensor reading. It will go to 14.7, but you'll actually be running 15.0 or 15.5 or whatever based on how much you skew it. This would work on either 32bit DBW or the old 2L.
It will also tilt your fuel trims, and you'll have to decide how you compensate for this. You could change injector size, or just deal with fuel trims being slightly more negative.
And since tuning different intake MAF scales is based on having an accurate injector size, you could end up skewing airflow and load.
Freon is offline   Reply With Quote
Old 01-29-2008, 01:14 PM   #17
NemesisWRX
Member#: 134413
2015 WRX
...(although we don't know exactly what changed in the 05 revisions as it is missing from SOA change list).
Pardon my interruption...
I have never heard of this list until now, is there anywhere I could look at this and maybe learn more about what the different SOA revs do for my car specifically (03 WRX)? I changed to the -400 rev a long time ago and never really knew why, i figured a higher number = new = better, all of the tables visible through Enginuity were identical so it must have been some unused (by us) stuff that changed.
Thanks
NemesisWRX is offline   Reply With Quote
Old 01-29-2008, 01:35 PM   #18
Tea cups
Member#: 103136
Thanks
It is somewhere on the openecu site. I think it was posted by "Jon [in CT]". It doesn't list every change and the descriptions are vague most of the time.
Old 01-29-2008, 11:38 PM   #19
NemesisWRX
Member#: 134413
2015 WRX
Ohhhhh, I know exactly what you're talking about and I've seen it before. From what I remember it didn't have anything useful that I could find, and didn't have any info on the -401 map I was considering switching to.
Thanks for the help
Is it possible to bring the 4pots close to the stopping power of Brembos? Hyper Brakes, Steering & Suspension 2 10-31-2006 03:20 AM
Is it possible to eat Oreo cookies in moderation? Asinine Off-Topic 68 02-28-2005 03:52 PM
Is it possible to get this key in the US? Louros Interior & Exterior Modification 30 11-19-2004 08:15 PM
Is it possible to loose 10 lbs in 3 weeks? two_ton_tammy Off-Topic 34 11-25-2003 03:19 PM
