Old 01-01-2008, 12:11 AM   #1
silver07sti
Member#: 156506
Default What would be the spool up difference between a bolt on gt30r vs a roatated gt30r?
What would be the spool up difference between a bolt on gt30r or something very close vs a roatated gt30r? Also what would be the the largest turbo i shoulkd use on my sti if i were to go with a bolt on turbo and since i wold only be able to use a 3inch intake because nothing larger will fit right?
silver07sti is offline   Reply With Quote
Old 01-01-2008, 11:19 AM   #2
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
If you want to go this big, go straight for rotated. The perrin kit, for example, is $2700 or so. An SZ55 or FP Red is $1400-$1700 , plus you will need a DP and likely a EWG to control it and avoid creep/spikes. The rotated kits start to make excellent economic sense. Plus, they open up the intake tract considerably, and the turbine housings flow more for better top end. The only real downside is some custom fab to connect to some interoolers.
Zornorph is offline   Reply With Quote
Old 01-04-2008, 07:49 AM   #3
silver07sti
Member#: 156506
What would be the spool up difference between a dom 3 and a same size rotated turbo? I just want to see what i'm getting into.
Old 01-04-2008, 07:59 AM   #4
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
your def. going to see a noticeable increase in turbo response and boost threshold in a rotated setup. The rotated 30r's use 4" compressor inlets with antisurge housings, big upgrade IMO. You also will be able to use the standard 't3' flange turbine outlet.
IMO you really should go rotated, the hybrids are not nearly as reliable as a true garret. Also keep in mind once you have a rotated setup you now can use any one of the dozens of t3 flanged turbos on the market without worry about fitment or subaru specific application meaning you can downsize and upsize freely and only swap the turbo and nothign else.
A ej257 with a rotated 3076r on the .64 hotside will have full spool by 3500 on pump, you would essentially have superior spool to a stock sti with a 55lb. turbo. I spent a LONG time and ALOT of research trying to decide between a rotated 30r and the ewg 20G setup I went with.
sluflyer06 is offline   Reply With Quote
Old 01-04-2008, 08:30 AM   #5
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Wait you just told him to go rotated and named the 2 of the bigger bolt on's.
The Red is 65lb and is $1400-$1700. The SZ55 flows 770CFM and is going to run you $2000 and thats IWG setup (I have one) and well worth the cost it comes lifetime free rebuilds, P&P, and both the exhaust & compressor sides ceramic coated.
4ST-AIR is offline   Reply With Quote
Old 01-05-2008, 07:18 AM   #6
silver07sti
Member#: 156506
The 3076r with a .63 ar is a 55lb turbo? As as far as spool up between a bolt on turbo and a rotated turbo would the spool up difference be like 200 rpms if not how much more? Thanks.
Old 01-05-2008, 10:53 AM   #7
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
A bolt-on of what size? A green? A SZ55? Fpred? Dom3?
The fact of the matter is that a turbo of equivalent size is not going to spool as good in stock location as it will rotated, the larger turbos really need a open intake tract for effeciency, I'm sure you seen all the supra videos where you'll see just a filter attached to the compressor inlet, you can do the same thing with a suby if you mount the MAF in a blow-thru setup.
The 3076R is good for up to about 450whp.
Pretty sure its 55lb, might be 52lb. You'll want to double check. Its big for sure.
Old 01-05-2008, 01:18 PM   #8
remowgn
Member#: 41149
09 FXT
SSM
Um, yeah... I think his point was that for a little more money than those bolt-ons (which you might have to spend anyway) you can go w/ a rotated setup, and have more upgradability.
remowgn is offline   Reply With Quote
Old 01-05-2008, 01:28 PM   #9
modaddict
Member#: 95840
sold to a good bud
awaiting next car
modaddict is offline   Reply With Quote
Old 01-05-2008, 01:39 PM   #10
STIBungy
Member#: 51684
Retail price on the Perrin GT35R kit is $7084?
Why is a bov price listed under Crawford? I thought they dont require a bov?
Originally Posted by modaddict View Post
STIBungy is offline   Reply With Quote
Old 01-05-2008, 01:51 PM   #11
squashman
Member#: 71718
07 STI LTD
^Yep - that's for the full kit including everything (intercooler, injectors, fuel pump, manifold, uppipe... ... ...) Not that I'd ever buy a Perrin kit, but that's what you get.
I did my research... it's my spreadsheet
I tried to keep everything pretty much equal across the board, so I listed a BOV with the Crawford kit. Yeah, they don't require it, and nor does any other kit, but most do so it stayed. Obviously the spreadsheet isn't 100% accurate FWIW.
squashman is offline   Reply With Quote
Old 01-05-2008, 04:05 PM   #12
modaddict
Member#: 95840
sold to a good bud
awaiting next car
look at the post below.
No kit requires a bov. People choose to run one
squashman decided to make it a level playing field to try and accurately tell what each kit would cost.
ha! I know your SN here, now.
Old 01-05-2008, 04:43 PM   #13
flycaster
Member#: 60142
2011 WRX
Grey
You need to look at what's included in this number to understand it. The turbo itself is a small part of the package. Once you add up all the ancillary stuff that this kit includes, and then tack that on to the other kits (which do not include them), the prices even up a lot.
flycaster is offline   Reply With Quote
Old 01-05-2008, 06:57 PM   #14
flatthump
Member#: 102749
2005 impreza STi
OBP'
Are you asking what the difference in spool/threshold would be with two identical turbo's mounted differently (Rotated and stock location)?
flatthump is offline   Reply With Quote
Old 01-06-2008, 07:11 AM   #15
silver07sti
Member#: 156506
Would the spool up difference between a ultimate racing rotated GT3076R kit and a bolt on dom 3 be more than 200 rpms in difference at full boost between the two with mods as close as possible to each other? From what i've read they both can produce up to 520 hp in proper configuration. The reason I am asking is if the differnce is between 300-500 rpms for full boost between the two. I dont want to get raped by people with fast spooling single scroll rotated gt30r kits and then imagine if they had a twin scroll rotated gt30r kit the loss in whatever circumstance would be even worse with similar hp figures. If the full boost difference ends being to much and when I say to much i mean 300-500rpms between the bolt on turbo and the single scroll rotated kit with the same hp producing turbo under full boost. I will just be willing to go straight to a full race twin scroll setup. Because gains from a twin scroll kit in terms of boost response and full boost time compared to a single scroll rotated kit are substantialy quicker from what I read and make for a better daily driver sti and a better powerbanded sti with a stock block. And the fact that i really have no interest in a rotated single scroll bolt on turbo kit. Because the price would be close to a twin scroll gt35r kit. And the gt35r bolt on turbos do not produce very good numbers compared to rotated gt35r kits because of that whole intake and exhaust housing size limit gt35r's have when bolt on. I understand that some of the other smaller bolt on turbos have a similar issues but are not affected as significantly as a turbo in the class of a gt35 or close to it.
What would be the first thing you would cut down with a lightsaber? TarmacRally Off-Topic 97 01-01-2010 10:50 AM
TD06h-20G vs. Superzilla 49 what would be the main differences? ninjaboy76 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 02-22-2007 12:25 AM
What would be the effect of not closing the air filter properly? Asinine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-22-2004 04:47 PM
What would be the difference between a 8 and 10 inch sub? garie Car Audio, Video & Security 7 04-18-2003 06:00 AM
