Old 01-01-2008, 03:02 AM   #1
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
Default Timing, how much is too much
Does anyone know the maximum amount of timing the engine/equipment can handle? I notice that the stock map has a max of 42.XX so I have not gone over that, but I find my car wanting more than this in certain areas...Can I keep going?
Wheeler Bement is offline   Reply With Quote
Old 01-01-2008, 04:52 AM   #2
dynamix
Member#: 122603
To answer this question you need to understand what the timing is actually doing.
In simplistic form:
The ideal is for the explosive force to occur just after TDC but the spark takes time to create this full combustion. Hence giving it some advance to give it time to ignite fully.
If this explosion happens too early the piston will still be travelling upwards and will cause det, too late and the piston will be 'running away' from the force of the explosion so the power will be wasted.
With std pump fuel you will find approx 25 degree (depending on compression, fuel and other factors) of total timing advance at high revs to give the fuel time to ignite for the piston to go past TDC. At lower revs, this advance will need to be less (maybe 14 degrees at 4000) for the same time to elapse.
Timing on low load sites such as the 42 degrees you mention is more about emissions than power.
dynamix is offline   Reply With Quote
Old 01-01-2008, 02:17 PM   #3
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
I'm more concerned with low loads(less than 1.13g/rev) and mid RPM(2800-5000).
Are you saying 42 is too low or too high for more power? I have tried to drop it, but it turns into a little FBKC monster. maybe I need to go more...but the EGT's go higher quicker.
Old 01-01-2008, 02:29 PM   #4
dynamix
Member#: 122603
Have you logged to see how many time to see you are in the 2800-5000 at low loads?
That is part throttle / closed loop / cruise mapping.
There is another thread in here about timing on cruise and most of us seem to run 39-42 degrees of timing there but I really dont spend too much time on this area apart from to make sure it is running . Power is higher up the load range and in open loop and certainly not at 42 degrees of timing.
Old 01-01-2008, 02:48 PM   #5
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
yes, everytime I drive the car I log.
I guess 42 is the max for now.
Old 01-04-2008, 11:48 AM   #6
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
I run 58 degrees of timing at cruise...
bluescoobywagon is offline   Reply With Quote
Old 01-04-2008, 01:41 PM   #7
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
interesting.
what kind of load do you see?
Old 01-05-2008, 01:52 AM   #8
bluescoobywagon
Member#: 14911
Not A Wagon!
Code:
	.22	.40	.54	.70	1.0
800	15.86	22.54	22.54	21.13	14.45
1200	27.11	39.06	33.09	28.16	17.61
1600	36.95	47.50	42.23	38.01	26.40
2000	45.04	54.88	51.72	48.91	30.97
2400	45.04	55.94	58.05	55.94	35.54
2800	45.04	54.18	56.99	54.88	34.84
3200	45.04	51.02	52.07	52.42	36.25
3600	45.04	47.85	49.26	50.66	37.30
4000	45.04	46.80	47.85	47.85	38.36
4400	45.04	45.74	45.74	45.74	39.41
4800	45.04	45.04	45.04	45.04	39.41
5200	45.04	43.98	43.98	43.98	39.41
5600	45.04	43.98	43.98	42.93	39.41
6000	45.04	43.98	43.98	42.93	39.41
6400	45.04	43.98	43.98	42.93	39.76
6800	45.04	43.98	43.98	42.93	40.46
I arrived at this after a lot of logging with my car. Your car may vary...
Old 01-05-2008, 01:59 AM   #9
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Interesting...
Old 01-05-2008, 06:18 AM   #10
bluescoobywagon
Member#: 14911
Not A Wagon!
Columns below 1.0 have 0 advance. I forgot to include 7200 rpm:
Code:
	.22	.40	.54	.70	1.0
7200	45.04	43.98	43.98	42.93	41.17
Old 01-05-2008, 06:57 AM   #11
hsnt
Member#: 160874
Code:
    .22    .40    .54    .70    1.0
Is yours a 2litre wagon?
hsnt is offline   Reply With Quote
Old 01-05-2008, 06:55 PM   #12
bluescoobywagon
Member#: 14911
Not A Wagon!
2.0L w/ 147,000+ miles on it.
Old 01-07-2008, 01:50 PM   #13
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
have you done any compression checks lately?
what is the response like over stock? this is confirming that my car wants more, or will atleast run with more....I thought I was on the edge a few days ago becasue of FLKC being almost nothing with cold IAT...I thought it would ping like a mother when it went up 20 degrees...but nothing. it wants more
Old 01-07-2008, 04:03 PM   #14
bluescoobywagon
Member#: 14911
Not A Wagon!
My last compression test came up clean. Also, notice how rapidly the timing drops off as I reach a load of 1.0. At no point do I have abnormally high timing under boost.
I actually based this map off one of the newer 2.5 maps. I noticed that it had much more timing in the cruise area than the earlier years so I tried that on my car. It responded well, so I added more timing. My exhaust is free flowing and I have 1 step colder plugs so you may not be able to go as high. I'm also running 15.3 AFR in closed loop.
Old 01-07-2008, 05:57 PM   #15
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
what kind of EGTs are you getting in closed loop?
simon021 is offline   Reply With Quote
Old 01-07-2008, 07:45 PM   #16
crazymikie
Member#: 56321
2006 Honda El Camino
Green
that's probably because the 2.5L motor NEEDS more timing.
running leaner than stoich will require more timing as well, but i've never seen anyone run as much as you. have you checked to see if it's actually making more power/getting better fuel economy?
crazymikie is offline   Reply With Quote
Old 01-07-2008, 10:22 PM   #17
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
also, why not run any advance so that it can pull timing if there is any fine learning knock correction?
Old 01-08-2008, 09:49 AM   #18
bluescoobywagon
Member#: 14911
Not A Wagon!
Fuel economy tests showed an improvement. The peak of the timing is right around 55 mph steady cruise. EGT's are around 1275F 6" from the ports.
As for no advance below 1.0 load, I was getting a lot of false knock from my noisy engine (it's got good compression but it is old) and solid endlinks. If it's knocking at load that low, then I've got other problems...
Old 01-08-2008, 04:28 PM   #19
crazymikie
Member#: 56321
Green
because you put unnecessary strain on the bottom end. also, knock learning isn't active below a certain load. you could be doing awful things to your motor and the ecu wouldn't stop you.
Old 01-08-2008, 04:59 PM   #20
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
you can change the load point...but looking back, i was confussed, so nevermind
1. Can you drink too much green tea? 2. If so, how much is too much? crowbar Off-Topic 32 10-19-2006 12:24 PM
What is the biggest pro/con of more caster? How much is too much on a WRX suspension? rex n effect Motorsports 6 06-20-2004 11:05 AM
Clutch rollover/tickover- how much is too much? beachbum Normally Aspirated Powertrain 0 05-16-2001 10:41 AM
How much is too much? (Remote lead) BJamerican Car Audio, Video & Security 3 04-19-2001 11:50 PM
How much is too much? LeadFoot Canada Region Forum 4 04-24-2000 03:28 PM
