North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC > NWIC Vendor Classifieds
Closed Thread
Old 01-02-2008, 02:40 PM   #1
Rallitek.com
Vendor Sales Rating: (15)
Member#: 34814
08 WRX
Lightning Red
Default Garage Sale - Overstock, Discontinued, or Used Bits
Garage Sale for Overstock, Discontinued, or used bits. We just did inventory and found some bits collecting dust!
-Coilovers from D2(WRX 02-07) and HSD/GPMoto(Legacy 05-08)
-Heavy Duty Rear Springs for Outback 2000-2004 from RalliTEK
-Skidplates from SSI for Legacy and Outback 2000-2004. Nice!
-Intercooler Water Spray Kits from APS
-UniChip PnP Engine Management one for WRX and 2 for 2.5L turbo.
-Fuel Injectors from AVO, 850cc Side Feed Fuel Injectors
-Intakes from WeaponR, 1 for WRX / One for RS
-Sway Bars from Whiteline, 1 Rear for Legacy, 2 front for n/a Impreza
-Seat Covers for Forester and Legacy
-LOTS more used and overstock bits from RalliTEK Shop!
-Free prizes to everyone that stops by!
Here is a link showing some of the garage sale items:
http://www.flickr.com/photos/rallite...91624738/show/
Post up any questions or just come by to shop....
Rallitek.com is offline
Old 01-03-2008, 10:43 AM   #2
Arthrogrian19
Member Sales Rating: (5)
Member#: 155466
2008 Stg III+ FSXT
How much for the Forester seat covers? Are the the OEM ones? Front and rear? What color?
Thanks!!!
Arthrogrian19 is offline
Old 01-03-2008, 12:03 PM   #3
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Thanks!!!
The seat covers are $89ea. (front/back) They are black, and made by Endura. They are designed to allow proper air bag deployment, and are waterproof. The material is similar to ballistic nylon so no tears from the dog...
Thanks!
Sean S.
www.RalliTEK.com
Old 01-03-2008, 11:52 PM   #4
martyg
Member Sales Rating: (2)
Member#: 52288
2000 2.5RSTi - sold!
Bye Bye Saabaru
Do you know if the skidplates would also fit on a 03 Baja?
Thanks!
martyg is offline
Old 01-04-2008, 10:26 AM   #5
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Thanks!
Yes! Perfect fit on '03 Baja.
Thank you,
Sean S.
www.RalliTEK.com
BTW: (04-06 Baja need to trim the sides of the plate due to a chassis brace Subaru has installed on those models.)
Old 01-04-2008, 02:52 PM   #6
Mr_Hox
Member Sales Rating: (21)
Member#: 118789
I just went from
six to midnight...
How much for the D2 coilovers? Specs? Mileage? Need a rebuild at all?
Thanks,
David
Mr_Hox is offline
Old 01-04-2008, 03:01 PM   #7
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Thanks,
David
David,
The D2 coilovers are brand new in the box. We paid $1050 for them a while back. We are asking $899.
Here is all the info I have on them:
"The D2 coilover system is a 36 way dampner and rebound adjustable monotube,
full coilover system. This setup has separate height and preload adjustment
allowing for optimal adjustment, and allowing full strut travel at all times
along with pillowball upper mounts, (top mounts). Mounts are constructed of
6061 aluminum that is powder coated. Threads are teflon coated to prevent rust."
Thank you,
Sean S.
www.RalliTEK.com
Old 01-04-2008, 03:37 PM   #8
Adam West
Member Sales Rating: (17)
Member#: 45614
93 Legacy Turb 5MT
White w/grey cloth
More info on the IC waterspray kit please! Thanks!
Adam West is offline
Old 01-04-2008, 04:29 PM   #9
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
The water spray kits are from APS... Here is info from APS:
(note: brackets and resovior not included in these kits)
Info from APS:
"Intercooler Water Spray System
As boost pressure is increased, the temperature of the inlet air increases and not only robs power from the engine but also increases the likely hood of detonation.
The APS Intercooler Water Spray System is designed to increase the effectiveness of an intercooler by spraying a fine mist of water over the intercooler core. As the fine water particles on the core evaporate, additional heat energy is removed over and above that possible through the intercooler alone.
Utilizing genuine STI water spray nozzles and production quality under hood components, the APS Intercooler Water Spray System ensures that you maintain that "factory" look whilst taking advantage of what is arguably the best performing WRX water spray system available.
The APS Intercooler Water Spray System is complete with every component required for installation and also includes the Unichip water spray driver module. Unichip control means that the water spray system operation is tailored to the exact requirements of your engine and activated only when the engine requires addition cooling of the charge air to the engine."
We have the UniChips here too. UTEC or RalliTEK P6 can also run the kit. (You could also fabricate a manual control switch is so desired.)
Thanks!
Sean S.
www.RalliTEK.com
Old 01-05-2008, 01:26 AM   #10
Mr_Hox
Member#: 118789
I just went from
six to midnight...
Originally Posted by Rallitek.com View Post
David,
Thank you,
Sean S.
www.RalliTEK.com
Damn, now you're giving me another reason to head down to Portland! The other being to check out a classic Austin Mini I've been looking at.
By chance, do you know the spring rates f/r f those coilovers? I'd like to stay at or under 8k and 6k...
Mr_Hox is offline
Old 01-05-2008, 07:56 AM   #11
ToastermonkeyPat
Member#: 159826
1995 Impreza L
Aegean Blue
What size are the NA impreza whiteline front sways?
ToastermonkeyPat is offline
Old 01-05-2008, 01:53 PM   #12
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Not sure on the spring rates. I'll check the box on Monday....
Sean S.
www.RalliTEK.com
Old 01-05-2008, 01:56 PM   #13
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Whiteline front sways are 22mm
Thanks!
www.RalliTEK.com
Old 01-09-2008, 01:40 PM   #14
Arthrogrian19
Member#: 155466
2008 Stg III+ FSXT
I installed the front seat covers over the weekend. They fit nicely, except for the headrests, but I knew they wouldn't. I'll install the rears whenever I get a chance to unbolt the back seat. Those ballistic nylon seat covers are going to last forever!
Thanks again!
Old 01-09-2008, 11:01 PM   #15
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Thanks again!
No worries! Let us know if there is anything else we can do for you!
Garner Thomas
www.RalliTEK.com
1-888-773-1212
Old 01-12-2008, 12:26 AM   #16
MkIII
Member Sales Rating: (1)
Member#: 100637
2002 Legacy GT
Silver Stone
I've sent off a PM of a few Legacy specific questions.
MkIII is offline
Old 01-12-2008, 01:22 PM   #17
homegrwn97
Member#: 167445
05 LGT Wagon Ltd.
Sean and his crew at RalliTek took really good care of me when I went down to Portland.
BUMP for dang good ppl and an awesome shop!!!
homegrwn97 is offline
Old 01-12-2008, 06:38 PM   #18
Mr_Hox
Member#: 118789
I just went from
six to midnight...
Sean S.
www.RalliTEK.com
Bump...
Mr_Hox is offline
Old 01-12-2008, 11:50 PM   #19
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Thanks! pm will be answered first thing on Monday!(when I am at the shop and have more details!
Garner Thomas
www.RalliTEK.com
1-888-773-1212
Old 01-12-2008, 11:52 PM   #20
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Thanks for the kind words! It was great to have you down. Let us know if there is anything else we can do for you! Great looking Legacy btw!
Garner Thomas
www.RalliTEK.com
1-888-773-1212
Old 01-12-2008, 11:55 PM   #21
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Bump...
Mr Hox,
I will make sure this happens for you first thing on Monday. Sean will get a harsh talking to!!!
Garner Thomas
www.RalliTEK.com
1-888-773-1212
Old 01-14-2008, 04:40 PM   #22
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Spring rates on D2 coilovers : 7.5k front / 5.1k rear
Thanks!
Sean S.
www.RalliTEK.com
Old 01-14-2008, 07:07 PM   #23
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
All pm's answered! Thanks for making this a great sale!
Garner Thomas
www.RalliTEK.com
1-888-773-1212
Old 01-14-2008, 08:00 PM   #24
whitebugeye
Member Sales Rating: (4)
Member#: 149158
2002 Impreza 2.5RS
White/ Stage 13,457,849.3
pm'd you back about one of the the n/a front swaybar
whitebugeye is offline
Old 01-14-2008, 10:59 PM   #25
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Pm'd back!
Garner Thomas
www.RalliTEK.com
1-888-773-1212
Closed Thread
FS: Misc OEM parts *Garage sale* for Food or Beer bwco VIC Private Classifieds 26 06-12-2010 12:45 PM
Flatirons Tuning Garage Sale!!! Lots of Rare JDM Bits! FlatironsTuning.com Interior/Dressup/Audio & Security 9 09-04-2009 09:11 PM
Spring Cleaning!! Discontinued & Used Items Up For Sale! Audio Integrations Interior/Dressup/Audio & Security 16 07-14-2008 07:42 PM
CT: Garage Sale- Lots Of Random Bits Chuck 1993 - 2001 Impreza Specific Parts 7 04-15-2008 05:14 PM
