Old 01-30-2002, 10:15 PM   #1
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Default Fluttering chirp noise @70mph and up anyone?
so as soon as I hit 70 mph i start getting this fluttering chirp noise, sounds like its right behind the speedo...I really think its comming from the engine compartment area and resonating through the dash...
i thought it was a throwout bearing but when I step on the clutch the noise is still present. even when coasting, but as soon as I go under 70 it stops
its really pissing me off, i have to start taking stuff off to see If i can make it go away.
I thought it was my intake rubbing but I dont see any rub marks...bahhh i just want to drive the car into a wall!
just wondering if anyone else may have had this problem.
<------car.
mods
WRX/STi Version 5 suspension www.subaruparts.com
Whiteline Adjustable Rear Sway Bar 18-22mm (set at 22mm) www.rallispec.com
Whiteline Solid Rear Sway Bar Endlinks
Whitleine Rear Strut Tower Bar
Accurit Performance Intake
Stromung Dual tip Cat back exhuast (2.25 midpipe) www.stromung.com
Apexi S-AFC mounted in Center dash compartment
Sabelt Clubman Dual Release Harnesses (2) www.primmracing.com
Depo Clear Corners w/custom reflective '2.5 RS' stickers www.speed-fx.com
OEM Subaru headlight protectors
Custom Subaru side window banners
"Subaru Impreza Tuned by STi" seatbelt shoulder pads (4) in yellow.
Kartboy short shifter and shifter bushings www.kartboy.com
JVC KDLX-10 head unit w/four Infinity Reference 652i speakers
Uniden Pro 520 CB w/ wilson 1000 knock-off trunk lid mount Antenna
Relocated compass gauge pack (udner radio)
Custom Alignment
Color Matched Side Skirts
15 legacy alloys with snows.
Jay
Old 01-31-2002, 08:45 AM   #2
wistful
Member#: 745
2004 STi
Java Black Pearl
secret wastegate for the secret turbo?
Don
wistful is offline   Reply With Quote
Old 01-31-2002, 06:54 PM   #3
Jademonkey
Member#: 9213
2000 RS
Red
Check your stickers, that may be causing the problem
But seriously, a friend of mine is having this problem, and if you look carefully, the speedo needle vibrates rapidly...he says it's the entire unit.... When I first heard it, it sounded like old squeeky drive belts...
Jademonkey is offline   Reply With Quote
