Old 01-30-2002, 11:12 PM   #1
ImprezedRS
Member#: 2771
2003 BMW Z4
Default Seam Welding?
What is seam welding, I know they do this to most rally cars and race cars to stiffem the chassis, but what actually is done.
ImprezedRS is offline   Reply With Quote
Old 01-30-2002, 11:23 PM   #2
grumbly
Member#: 8938
2002 A Black Wagon
Oh thatís easy! Seam welding is where they weld the seams! sorry I couldnít help it..
The way cars are put together is that the various body parts are held together with tack welds. Or that there are lots of spot welds along the seams. When a car is prepped for racing they strip it down to the bare body and re-weld the whole seam. Vola! Seam welding!
grumbly is offline   Reply With Quote
Old 01-30-2002, 11:26 PM   #3
Dobes
Member#: 164
2008 Exige S240
It's my understanding that the seam is welded for one inch, then a one inch gap is left, then it is welded for another inch and so on.....
Completely welding the entire seam would add lots of unwanted weight.
JD
Dobes is offline   Reply With Quote
Old 01-30-2002, 11:28 PM   #4
grumbly
Member#: 8938
2002 A Black Wagon
actually i was just thinking about that.. your right it would add alot of weight and probably would also make the weld more prone to cracking.
Old 01-30-2002, 11:36 PM   #5
hotrod
Member#: 14141
2002 Impreza WRX
Default Yes they usually skip weld
The pattern of welding you discribe is called skip welding, and yes it is prefered for a couple of reasons.
1. It has essentially the same strength as a full weld with half the welding rod consumed. Weight is an issue, but the welders labor costs money and so do the materials, so it is far more cost effective.
2. If a crack develops in a weld it can only propogate the length of a single weld bead, so especially on high stress items like frames it is safer.
3. On thin material you are less likely to burn through or distort the base metals on skip welds because you are not putting as much heat into the material.
Larry
hotrod is offline   Reply With Quote
Old 01-30-2002, 11:38 PM   #6
ILPRocky
Vendor
Member#: 12903
2000 Subaru
Sedona Red Pearl
We tig welded most of the seams and it took alot less filler that way. But some said that the it creates too much heat. But we did it anyway. All the seams have to be completely stripped of all the crap that's in some of them. It took along time and we are still finding seams to weld.
Rocky
ILPRocky is offline   Reply With Quote
Old 01-30-2002, 11:41 PM   #7
grumbly
Member#: 8938
2002 A Black Wagon
Larry I guess the inevitable follow then is what other types of body prep/welds are there?
Chris
-Learning more everyday
Old 01-30-2002, 11:55 PM   #8
hotrod
Member#: 14141
2002 Impreza WRX
Default Thats the most common
Some times you can use what is called a plug weld.
If you can't get to the actual edge of the seam, or you want to spread the load over more of the sheet metal, you can take a grinder or a drill and grind or drill through the top sheet of material and then weld around the perimeter of the hole. Years ago they would sometimes do it with a common stick welder, and start a puddle on the top sheet and just before the arc burnt through both pieces they would quickly pull the electrode away. For all practical purposes it is a spot weld just done in a different way. It works well if you have a wide area of overlap, but you can only get to one side of the seam.
Basically welders are limited only by their imagination. Sometimes you need to be creative to get things connected the way you want.
Also modern cars frequently glue panels together with a mastic adhesive kind of like liquid nails.
Like ILPRocky says to get good welds you have to get all that crap out. Sometimes by placing a plug weld back an inch or so from the edge you can get past the goop that you can't get out.
Larry
Old 01-31-2002, 12:35 AM   #9
Irvine Subaru
Vendor
Member#: 5099
If you decide to seam weld your car and are going to have a roll cage in it (I assume you will if you're taking the time to seam weld it) consider not doing anything past the strut towers (i.e. boot and bonnet). This creates a less rigid area that is more likely to absorb an impact should you hit a tree. Its crumple zones for drives/passenger safety. The Rubys rally car is done this was to protect the occupants in the event of a collision.
Ryan
Irvine Subaru is offline   Reply With Quote
Old 01-31-2002, 08:17 AM   #10
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
I think a name more common than "skip" welding is "STITCH" welding.
Additionally, the "PLUG" weld you describe is usually referred to as a "ROSETTE" weld.
--Roy
LUME is offline   Reply With Quote
Old 01-31-2002, 10:22 AM   #11
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
not all rally cars can be seam welded...
Seam welding is not allowed for
SCCA Production class rally cars
J.
www.subiegal.com
Old 01-31-2002, 12:21 PM   #12
Spectre23
Member#: 311
2013 STi
CBS
I was watching a Japanese video where they were prepping a car for racing. I believe it was the JGTC. But they were using the plug weld method on that car.
Spectre23 is offline   Reply With Quote
Old 01-31-2002, 12:26 PM   #13
johnfelstead
Member#: 856
2005 JDM STi
good answers
quick quiz
which production impreza is seam welded at the factory?
johnfelstead is offline   Reply With Quote
Old 01-31-2002, 12:31 PM   #14
Marquis
Member#: 64
1999 Impreza 2.5RS
Rally Blue Pearl
Current production, or ever? The only one I know of was the 22B.
Marquis is offline   Reply With Quote
Old 01-31-2002, 12:34 PM   #15
WRXSTI?
Member#: 6432
1999 Outback
I was gonna guess 22b, but Marquis beat me, so I'll guess type RA...
WRXSTI? is offline   Reply With Quote
Old 01-31-2002, 01:07 PM   #16
johnfelstead
Member#: 856
2005 JDM STi
22B it is.
too easy
Old 01-31-2002, 01:13 PM   #17
Travis R
Member#: 153
'07 Mazda CX-7, '91
BMW 535i & '06 Ninja 650R
So the next question that begs to be asked... which method did they use? Stitch, rosette, or continuous?
Travis R is offline   Reply With Quote
Old 01-31-2002, 04:57 PM   #18
johnfelstead
Member#: 856
2005 JDM STi
well no one uses continuous. I would imagine stitch, if i can be bothered i'll take a look next time i am out in one.
Old 01-31-2002, 08:46 PM   #19
hotrod
Member#: 14141
2002 Impreza WRX
Default terminology is always a problem
Lume:
Yup -- I've heard both terms. Like most trades there are both regional differences in terminology and industry differences. Based on your location, did/do you work in the steel industry ? I mostly worked in Large industrial machine shops, and shops that worked on heavy equipment. My dad worked in the trucking industry so a lot of my terminology came from exposure to those industries.
Skip and stitch are both colloquilisms for intermittent fillet welds, which no one but the engineers use
The shops I worked in you'd find different welders that used different terms. I wonder if it is specifically regional, ie east coast, vs west coast or by industry. In the gravel quarry the guys that worked on the heavy equipment almost exclusively used the term skip weld. I never heard the term stitch weld until I went to a smaller machine shop.
There is a subtle difference between the rosette weld and the plug weld though. There is a specific weld symbol for the plug weld in the American Nation Welding Society welding symbols. There is no symbol for the rosette weld. In the description of the usage of the plug weld symbol, it explicitly says not to use it to refer to a fillet weld around the perimeter of a hole (ie a rosette weld).
So as I've seen it used, the plug or slot weld is a small weld that completely fills the hole or slot it is placed in, and the rosette weld is a fillet weld around the inside perimeter of a larger hole.
For those of you who have not worked in the metal trades, here is a link that gives some info on the welding symbols, if your into technical trivia like I am.
http://155.217.58.58/cgi-bin/atdl.dl...237/Ch3.htm#s1
It would be interesting to hear from others about which terms are prefered in which, racing/industrial environment.
Larry
Old 01-31-2002, 09:53 PM   #20
Bonzo
Member#: 2307
2009 530EXCXTZ1200
Orange
I'm a stitch welding kinda guy. I also do a great deal of gas or oxy/acet welding. I don't see this method used to much anymore since the advent of TIG. Little known fact is you can weld aluminum with oxy/acet.
Bonzo is online now   Reply With Quote
Who does cages and seam welding around here? Ru fan New England Impreza Club Forum -- NESIC 12 03-03-2003 08:13 AM
Seam welding, how is it done? Ru fan Motorsports 6 02-25-2003 09:02 PM
Seam-welding questions dead-eye Normally Aspirated Powertrain 24 12-31-2002 11:35 AM
Seam welding XT6Wagon Motorsports 6 06-21-2002 11:20 PM
Self seam welding... tcs007 General Community 5 01-16-2002 03:19 PM
