South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 01-03-2008, 01:36 PM   #1
C-grunt
Member#: 152713
2010 G37 Sedan
Gray
Default Need Help! (please) (aftermarket alarm)
Hey guys, the aftermarket alarm on my wifes mustang is set on engine kill mode and wont turn off. It only goes off when I try to start the car. It wont crank over and the alarm goes off. We bought the car used and dont know the alarm it has installed. I know it was installed by a dealership, but dont know which one. Does anyone know how to bypass an alarm or take one out?
C-grunt is offline   Reply With Quote
Old 01-03-2008, 01:59 PM   #2
Jim.mEh
Member#: 84517
05' Imprezilia
CruiseControl Warrior
its is a KARR alarm? is there a sticker anywhere on the windows "KARR"
If so i have remote for it..
Jim.mEh is offline   Reply With Quote
Old 01-03-2008, 02:45 PM   #3
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
Look under the dash for the unit and unplug it.
szeny is offline   Reply With Quote
Old 01-03-2008, 02:57 PM   #4
Jeff_360
Member#: 69073
Set said mustang on fire. That should take care of your problem
Jeff_360 is offline   Reply With Quote
Old 01-03-2008, 10:28 PM   #5
C-grunt
Member#: 152713
2010 G37 Sedan
Gray
Ok so I found the alarm and tried unplugging the three wires that splice, via plug, into some other wires. Nothing worked. Also just completely unplugging the alrm doesnt work either. If anyone can fix this Ill give you 20 bucks.
Old 01-03-2008, 10:33 PM   #6
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the ho's.
completely unpluggin the alarm doest work?
bobturismo is offline   Reply With Quote
Old 01-03-2008, 10:36 PM   #7
bobturismo
Member#: 42145
6-4 jockin da bish-
look for the wires that come from the ignition key, larger wires.
There will be a factory wire that is cut and then connected to two seperate wires that go to the starter kill relay installed with teh alarm.
What you have to do is reconnect the factory wire back to together.
Old 01-03-2008, 10:43 PM   #8
06AZREX
Member#: 132244
2006 OBP WRX
2006 BMW 325i
+1 look for the heavy gauge starter wire coming off the main ignition harness from the key cylinder. its the only wire in that harness that will be cut in half. each half will be connected to the alarm (key side and starter side). cut them off the alarm and re-join them with a butt-connect it back together. that will allow the car to start again.
06AZREX is offline   Reply With Quote
Old 01-03-2008, 11:02 PM   #9
06AZREX
Member#: 132244
2006 OBP WRX
2006 BMW 325i
oh yeah depending on what kind of alarm it is will determine if it uses an external relay or a built into the brain relay. like viper alarms are built into the brain and the starter disable wires are purple and green.
Old 01-04-2008, 12:07 PM   #10
dozer54321
Member#: 116437
2002 WRX - MINE
99 SUS - WIFEY
burn that mofo, road flare in the tank and problem solved, damn kids and their flares
dozer54321 is offline   Reply With Quote
Old 01-04-2008, 01:40 PM   #11
subykid
Member#: 116438
2009 WRX Hatch
FAT Snail Racing
does the key have a module?
subykid is offline   Reply With Quote
Old 01-04-2008, 01:42 PM   #12
C-grunt
Member#: 152713
2010 G37 Sedan
Gray
As in a remote button thingy? Yes
Old 01-04-2008, 02:07 PM   #13
subykid
Member#: 116438
2009 WRX Hatch
FAT Snail Racing
as in what year is the car? is it an aftermarket alarm or factory kit? it may need to be reprogrammed through the dealership.
Old 01-04-2008, 02:51 PM   #14
dozer54321
Member#: 116437
2002 WRX - MINE
99 SUS - WIFEY
or, burn it
Old 01-04-2008, 03:31 PM   #15
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
Give me a call tuesday im off and i can look at this,...
Old 01-04-2008, 11:29 PM   #16
C-grunt
Member#: 152713
2010 G37 Sedan
Gray
Took it in to the dealership. Found out the battery was defective and was not giving enough power to the electrical system. The key had somesort of little transmitter in it and the ignition has the reciever. Well the reciever wasnt working so the car thought the ignition was being turned without the key, so the alarm was killing the car. They originally thought the alarm was malfunctioning but it was working perfectly. But yeah, we're getting rid of it pretty soon.
Old 01-05-2008, 01:32 AM   #17
bobturismo
Member#: 42145
6-4 jockin da bish-
Damn you PATS!!!
Need help on a part number(08's+ help please) NickDHdfc Newbies & FAQs 1 12-10-2009 09:59 PM
need help with aftermarket steering wheel crash#2 Interior & Exterior Modification 1 08-22-2006 01:55 PM
Need help- Do i Need an aftermarket stereo? disque71 Car Audio, Video & Security 10 04-01-2004 07:08 PM
Need help with aftermarket springs 98LegacyGT Brakes, Steering & Suspension 1 08-07-2003 11:52 PM
need help with aftermarket steering wheel fast_1_m Interior & Exterior Modification 6 06-13-2003 04:19 PM
Message Board Statistics All times are GMT -4. The time now is 06:50 AM.
