Old 01-04-2008, 04:25 AM   #1
100_Percent_Juice
Member#: 126042
2004 W Ŕ X
Default DIY: Hazard Switch Bulb Replacement
I searched for an hour or so before I decided to just try doing this myself. So I figured I should make a DIY since I wasn't the only one looking.
This was done on my 04wrx. This takes about 10-20 minutes depending on model car building experience.
To remove the hazard button, remove the cup holder, the trim piece and then just pull out the vent and unplug it.
Go to RadioShack and get this bulb 2pack.
Once you get the switch out, pry the switch apart using a small flathead screwdriver. When you pull it apart make sure to not let it pop open shooting the spring out.
It comes apart into 3 pieces.
Top
Middle.
bottom.
Pull the entire bulb/base off of the top.
To remove the bulb from the soft base you will need a pair of tweezers and good lighting. I didn't take pictures on how to remove the bulb so just do the install backwards.
Install
Put the 2 wires into the 2 holes in the very middle of the base. Then snake them through using the tweezers.
step 1.
step 2.
step 3.
Then push the base back on to the top piece of the hazard switch.
100_Percent_Juice is offline   Reply With Quote
Old 01-04-2008, 04:25 AM   #2
100_Percent_Juice
Member#: 126042
2004 W Ŕ X
When putting the hazard switch back together make sure that the spring and metal pin are in the right place.
Be patient when putting it back together because its kind of awkward. To put the top back in, slide the front tab under the hazard button, and then press down into place.
I tried to explain this the best way I could, but if something doesn't make sense, just ask.
Old 01-04-2008, 09:42 AM   #3
Moods
Member#: 71961
2003 WRX Sedan
MBP
Nice work... i just had a bulb go out in my cruise control button... which is basically the same thing... so thanks for a better understanding of how the bulb can be snaked into that housing
If only i had a radioshack.
Moods is offline   Reply With Quote
Old 01-04-2008, 11:23 AM   #4
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
very well done....
now hopefully I won't need it, but it will be nice to have.
dm
dwmoss_68 is offline   Reply With Quote
Old 01-04-2008, 09:09 PM   #5
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
sweet, thanks! About to do it on Sunday...
Old 01-04-2008, 09:22 PM   #6
wrxtasy555
Member#: 8293
2006 Forester XT
Crystal Gray Metallic
wrxtasy555 is offline   Reply With Quote
Old 01-14-2008, 03:44 PM   #7
XanRules
Member#: 157348
It's rowdy outside
I ain't signin' s***
I'm working on it as we speak.
Also, at my local radio shack, these parts now come in little bags as opposed to the little "blister" boxes.
XanRules is offline   Reply With Quote
Old 01-14-2008, 04:26 PM   #8
XanRules
Member#: 157348
It's rowdy outside
So here's my quick notes, considering all 6 of my indicator lights were burned out.
A SMALL PAIR OF NEEDLENOSE PLIERS WILL BE YOUR BEST FRIEND DURING THIS PROJECT.
That is all.
Thanks a huge amount for this, I was starting to freak out.
Old 01-14-2008, 06:10 PM   #9
XanRules
Member#: 157348
It's rowdy outside
My hazard lights don't work anymore...
help?
Old 01-16-2008, 11:46 PM   #10
XanRules
Member#: 157348
It's rowdy outside
bump. Still need help fixing this.
Old 01-16-2008, 11:51 PM   #11
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Seems you need to go through all the steps again. It's tricky to reassemble the switch, and one wrong move, or misplaced spring, or bad position of that little white thingie which allowes the push in - push of the switch, and the lights won't work. Take it off, disassemble, reassemble... unless you managed to fry a fuse in the process?
Old 01-16-2008, 11:58 PM   #12
XanRules
Member#: 157348
It's rowdy outside
Nope. Fuses are all good. I did have trouble reassembling it, I was just looking for what the most obvious solution would be.
Old 01-17-2008, 12:00 AM   #13
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Sorry to say I dont see any past re-assembling or buying a new one.
Does the switch click in an out as it used to?
Old 01-17-2008, 01:39 AM   #14
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
very nice diy!
some don't have the lamp though.
Handsdown is offline   Reply With Quote
Old 01-17-2008, 09:57 PM   #15
XanRules
Member#: 157348
It's rowdy outside
I think I just messed the metal pin thingie up. Oh well, easy fix.
Old 01-18-2008, 03:11 AM   #16
100_Percent_Juice
Member#: 126042
2004 W Ŕ X
Originally Posted by Handsdown View Post
very nice diy!
Then I guess they will have a surprise when they spend the time to take that switch apart.
Old 01-18-2008, 09:12 AM   #17
LYHTSPD
Member#: 26374
2004 WRX Sedan
San Remo Red
I have an 04 sedan, and I don't ever remember there being a light in the switch. Do all the hazard switches have the socket?
100_Percent_Juice: Are you using the stock hazard switch?
LYHTSPD is offline   Reply With Quote
Old 01-18-2008, 10:04 AM   #18
Bluefoton
Member#: 141373
2008 2.5i-hatch -
IMHO, they should all have, as one of these "safety" thingies. Not to mention there would appear to be NO logic whatsoever on cutting a 38 cent cost by eliminating light bulbs as of 2004!
Buy bulbs, take switch off, put bulb, and enjoy a soothing red spot on your dashboard ...
Old 01-18-2008, 10:26 PM   #19
XanRules
Member#: 157348
It's rowdy outside
I'm changing mine to blue! Except the hazard switch is gonna be BRIGHT red.
Old 01-22-2008, 09:05 PM   #20
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
eBay racing edition!
Wow, I just did this last week and a friend just sent me this link. I had to replace the bulb in the rear defrost switch as well. Same procedure, but it's easier as it's only a momentary switch and has less parts inside.
IMPREZive 02 WRX is offline   Reply With Quote
DIY: Cruise Control Light Bulb Replacement With Photos dcwrx2 Electrical & Lighting 58 10-08-2012 05:38 PM
Defroster and Hazard switch bulb replacement Kansai Subaru Electrical & Lighting 3 04-21-2008 11:03 AM
hazard switch bulb burned out Bluefoton Electrical & Lighting 7 01-04-2008 07:58 AM
Anyone know of a bulb replacement for the hazard switch? NITROS Interior & Exterior Modification 0 09-18-2006 05:12 PM
fog/cruise/defrost/hazard switch bulbs NateDogg Electrical & Lighting 1 05-11-2003 03:37 PM
Message Board Statistics All times are GMT -4. The time now is 02:18 AM.
