Old 01-04-2008, 05:22 PM   #1
DemiSlayer
Member#: 120339
02 WRX
Alliance Motor Sports
Default Cause of rear main seal failure
02 wrx and i guess the rear main seal might be out. what would be a cause for the failure on an 02? could there be engine damage of some sort? thanks
DemiSlayer is offline   Reply With Quote
Old 01-04-2008, 05:42 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
How many miles? Seals go bad over time or could have been defective to start with or installed incorrectly. Frequent overheating of the flywheel could cause the seal to go bad as well.
Old 01-05-2008, 02:12 AM   #3
DemiSlayer
Member#: 120339
02 WRX
90k miles
Old 01-05-2008, 02:24 AM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Seals wear out over time. 90k isnt too bad.
There are seperater plates on the back of the motor also, those can leak also. Usually spewing oil all over your exhaust when you go up hills.
If this is the first maintenance done to the car, it's that bad.
~Josh~
Cost of repairs: Motor mounts + Rear Main seal DreddRS25 Service & Maintenance 3 03-19-2008 09:32 AM
rear main seal mybluesubi Service & Maintenance 11 02-09-2004 06:28 PM
Rear diff seal failure Shankster Warranty Issues & SOA Problems 0 01-19-2004 02:13 PM
rear main seal replacement?+ flywheel and pressure plate bolt torque? Haase14 Transmission (AT/MT) & Driveline 7 01-17-2003 10:42 AM
('93-'01) Rear main seal gone - 650kms? Help! JNaubur Impreza Forum 6 05-25-2001 12:29 AM
