Go Back   NASIOC > NASIOC Regional Areas > International Forum
Old 01-04-2008, 08:57 PM   #1
HUDI
Member#: 157000
02 wrx
blue
Default hi from aus
Been reading the forum for a little while . i live on the sushine coast in queensland aus ..
here is my beast
Engine management: Motec plug & play unit
Heads:Ported and polished, PMS group A cams,pms cam gears , heavy duty valve springs, 1mm oversized inlet valves, 2mm oversized exhaust valves, 80 mm throttle body ,custom manifold
Bottom end: EJ257block, full closed deck & sleeved, cp pistons, argo rods, 1/2 inch head studs, nitrrade crank,
Bolt on bits: garret gt35,hks 60mm waste gate into sreamer pipe ,rockchester 1000cc , custom fuel rails, 500hp fuel pump feeding magnafuel pump swirl pot ,magnafuel fuel regulator , APS dr 650 fount mounted intercooler,3inch custom fmic piping , 3.5 inch exhaust, i.s extractors (heat wrapped),custom up-pipe (heat wrapped), tial 50mm blow off valve, oil catch can, oil cooler, gfb pulleys, motec ignition ,merrcury coils
Gearbox: PPG straight cut gear set, kazza front diff ,cusco rear diff ,cusco center , ceramic clutch ,spec c slave cylinder ,billet drive shafts
Suspension: bc , 25mm front adjustable, 24mm rear adjustable, solid mounts holding on to them, anti lift kit,gt spec 8 point brace,spec c steering rack,spec c powersteering pump .
Brakes:willwood 6 piston frnt willwood 4piston rears Braided lines, master cylinder brace
HUDI is offline   Reply With Quote
Old 01-04-2008, 11:56 PM   #2
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
Wow! Welcome...
MJU1983 is offline   Reply With Quote
Old 01-05-2008, 02:46 AM   #3
sku81
Member#: 143283
2001 bugeye wrx
white
u dont live on the sunnycoastdam ricer..
Kris
sku81 is offline   Reply With Quote
Old 01-05-2008, 03:09 AM   #4
HUDI
Member#: 157000
02 wrx
blue
i dont consider my self to live in brissy .. u just take your rust bucket and push off
Old 01-06-2008, 07:51 PM   #5
tabletennisman
Member#: 159347
2000 WRX
WRC Blue
**** thats alot of power. Must be a hoot to drive!
tabletennisman is offline   Reply With Quote
Old 01-26-2008, 11:21 PM   #6
jaws_57
Member#: 145751
2001 wrx
Zoinks
jaws_57 is offline   Reply With Quote
Old 03-14-2008, 11:53 AM   #7
gonzo009
Member#: 135372
2007 Impreza STI
Rally Blue
nice car and very clean mods
gonzo009 is offline   Reply With Quote
College in the US! Exchange from Aus SPESHAL Off-Topic 84 03-06-2006 05:07 AM
06 STi Review from AUS fenix News & Rumors 17 08-17-2005 03:26 AM
Cool routes from Aus to SA? dissolved_girl Texas Impreza Club Forum -- TXIC 7 06-16-2005 06:21 PM
Why do people think Scoobs are from AUS PanamaJack General Community 23 07-03-2002 04:59 PM
Aftermarket parts for WRX from aus. herky WRX Forum Archive 3 02-08-2001 09:40 AM
