Old 01-04-2008, 10:09 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default My data log (02 WRX 3rd gear)
Need some input from you guys. If you need to see additional parameters, let me know. KCA dip occurs right around 5500rpm. FLKC = 0 throughout the pull and IAT of 37-39F.
VF34 & pinks
AP
One step colder plugs
BPM turbo inlet
K&N panel filter
Ported exhaust manifold
STi TMIC
Catted downpipe and Borla hush catback
93 octane
German castrol 0W-30
Old 01-04-2008, 10:19 PM   #2
crazymikie
Member#: 56321
2006 Honda El Camino
Green
yup- you want to do something about the KC drop- it looks like you are running on 93 octane? it's hard to say without wideband readings, but you timing curve looks pretty reasonable. i'd guess you can try richening it up a little bit and see what happens.
crazymikie is offline   Reply With Quote
Old 01-04-2008, 11:50 PM   #3
benw
Member#: 103320
1998 swapped
Forester L
knock city up top! bad winter gas?
benw is offline   Reply With Quote
Old 01-04-2008, 11:58 PM   #4
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
It's quite possible that it's a bad winter gas.
Since detonation can be also caused by high AFR, I will try replacing K&N panel filter with a conventional paper filter and tackle fuel filter at the same time (if tank of gas from diff. gas station again causes knock).
Any other suggestion to address this knock?
Old 01-05-2008, 12:41 AM   #5
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
Drive around a bit more on the freeway (cruising etc...) and then check AFR Learning A, B, C, and D.
Then put your stock filter in and drive around on the freeway (cruising, etc...) and check AFR Learning A, B, C, and D.
mickeyd2005 is offline   Reply With Quote
Old 01-05-2008, 01:04 AM   #6
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Correction: this log was done using K&N SRI not paper filter as originally thought.
In comparison, here is the ecuExplore data log from 12/07 I just found from my computer (K&N typhoon SRI).
Old 01-05-2008, 03:51 AM   #7
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
You might actually be leaning out because the colder air = denser (more) air.
Your previous log was already hitting the 300 g/s limit so the ecu doesn't know that you are taking in more than 300 g/s air.
It looks like your previous log IAT was 11-13 celsius.
Your current IAT is around 2-3 celsius. That means you're probably pulling in even more air than before but your ecu is still capped at 300 g/s.
If you decide to multiply everything by 1/2 or 2/3 or 3/4 to get around the 300 g/s limit, make sure that you rescale ALL your tables that reference load.
Old 01-05-2008, 09:59 AM   #8
crazymikie
Member#: 56321
Green
good catch!
what kind of intake are you running? maybe the intake cal is off a bit. 300 g/sec on a vf34 seems like a lot.
Old 01-05-2008, 01:45 PM   #9
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Stupid me. That ECUexplorer log was done using K&N typhoon which I ended up selling sometime after that log.
Today, plan is to repeat the log again way it is since temperature is much warmer than last night.
Old 01-05-2008, 04:15 PM   #10
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Here is another log from today. Weather is much warmer today than last night. Will try to get more logs later today after replacing fuel filter and cleaning out MAF.
Mickey, I did plot some AFR learning A/B/C/D data (K&N vs paper filter) below:
With K&N panel filter -- KC drop still visible!
With paper filter, but only up to 5400rpm due to traffic.
Old 01-05-2008, 05:01 PM   #11
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
Can you post the log.
Old 01-05-2008, 06:03 PM   #12
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
BTW, I didn't intend for you to datalog AFR Learning A, B, C, and D. You can just check it when you're stopped. Just write it down. Also, it won't stabilize until you've driven for a while.
I think your problem is related to the 300 g/s limit.
Old 01-05-2008, 06:22 PM   #13
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Mickeyd2005,
Here is the most recent data log after switching to paper filter and replacing fuel filter (and cleaning of MAF). Also tried spraying with car. cleaner to identify any leak. Everything seems just fine.
One thing I have not data log was airmass flow with a new paper filter. I will try later this evening.
Old 01-05-2008, 07:52 PM   #14
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Here is the most recent data log including mass air flow. It is maxed out at 300 g/s above 5500rpm.
4 gallons of 93 octane gas has been added prior to this run from a diff. gas station.
Old 01-06-2008, 05:10 PM   #15
ChrisSK
Member#: 117464
2008 Hayabusa 1300R
Tim,
What have you changed since your tune? There is no way you were achieving that hight of a VE on the dyno/road tune without me saying something to you. I have your maps and will review them tomorrow..
- Chris
ChrisSK is offline   Reply With Quote
Old 01-06-2008, 05:24 PM   #16
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Originally Posted by ChrisSK View Post
Tim,
- Chris
Hi Chris,
Engine oil from Mobil 1 to German castrol and BPM turbo inlet. Nothing else has been touched.
VF34 turbo - untouched
TBE/UP/DP - untouched
Pinks/FP - untouched
STi TMIC - untouched
One step colder plugs - untouched
Old 01-06-2008, 05:53 PM   #17
ChrisSK
Member#: 117464
2008 Hayabusa 1300R
The turbo inlet may be the culprit, but not entirely.
I reviewed your map a few minutes ago, I sent you a much more refined map. Try that, log it and check back. If you continue to max the g/rev, you will need to come back for a retune.
Thanks,
Chris
Old 01-06-2008, 05:59 PM   #18
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Chris, I appreciate your fast reply. I will post a log later.
Old 01-06-2008, 06:01 PM   #19
ChrisSK
Member#: 117464
2008 Hayabusa 1300R
Please just email it to me, I don't check the forums too often. I just happen to be on because I have the laptop on, and the game is on
Old 01-06-2008, 07:09 PM   #20
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Email sent with a new log.
Please Check My Data Log (New logs added) Xsile STI Engine Management & Tuning 6 04-30-2010 05:17 PM
Question about my data log... wrxrex AccessPort 4 12-05-2007 10:08 PM
Someone check out my data logs.. midnight302 Engine Management & Tuning 4 03-03-2007 05:11 PM
my data log from the other day.... rb22b Engine Management & Tuning 25 02-25-2007 02:58 AM
STI Utec Stage II map, check out my data log calib17a Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-06-2004 09:37 PM
