Old 01-31-2002, 11:50 AM   #1
skullguy
Member#: 14269
Sedona Red
Default Engine check lights
I have a 02 WRX, just went with a intercooler, waste gate, blow off valve and 3" exhaust upgrade.
When I step on it, it gets to about 4000 rpm, and I get a big bump from the engine and the engine check light comes on.
Then every time I do it, it does the same thing.
does anybody know why this would be happening and what I can do about it.
It is very confusing and frustrating.
I am tired of taking it back to the dealer and theem telling me its fixed when it isnt.
PLEASE HELP!!!
skullguy is offline   Reply With Quote
Old 01-31-2002, 02:06 PM   #2
AK'S REX
Member#: 12163
Sounds like your hitting fuel cut. Do you have a boost controller?
Basically it means your running too much boost for the stock ECU. Fuel cut is at about 18 psi give or take depending on the car.
If you don't have a boost controller, I don't know what to tell you other than check your install again, I'd wager to say that something was done wrong. If you do have a boost controller, turn it down a bit.
Good luck.
AK'S REX is offline   Reply With Quote
Old 01-31-2002, 02:53 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
If your CEL came on and the dealer turned it off, then the dealer should have read one or more diagnostic trouble codes (DTCs) from the WRX's ECU. Do you know the code(s)? DTCs might show up on your work order or repair sheet you got from the dealer.
Jon [in CT] is offline   Reply With Quote
Old 01-31-2002, 04:36 PM   #4
MJSpiers
Member#: 4915
2002 WRX Sedan
Hmmm
What do you mean by:
Do you mean that you've adjusted the wastegate rod length or something dumb like that?
If so, then I would say that you're hitting overboost fuel-cut and CEL.
Read up on i-club about this issue and learn.
If that's not the case, then sorry
Mike
MJSpiers is offline   Reply With Quote
Engine check light & Cruise light on Plasteredcat Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 05-19-2004 11:55 AM
Engine check light jskho Bay Area Impreza Club Forum -- BAIC 2 09-21-2003 10:45 PM
Engine Check Light NiTRoN Legacy Forum 5 12-11-2002 10:14 AM
Engine check light coming/going subnewbie Normally Aspirated Powertrain 4 10-16-2001 04:04 PM
engine check light STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-27-2001 05:40 PM
