Old 01-06-2008, 03:41 AM   #1
railguy
Member#: 53756
Default eg33 into usdm 2002 wrx
I am looking to swap a fully built eg33 from svx into my 2002 wrx. I just want to know if the engine mounts line up, the trans bolts up, if the hydra can tune, and if ej22 pistons and rods with work for the build? Lastly where do you get valvetrain for this motor?
thanx
Eric
railguy is offline   Reply With Quote
Old 01-06-2008, 10:37 AM   #2
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
Engine drops right in. Can use EJ engine mounts, trans bolts up. There are some guys running the Hydra with the 33, and EJ22 pistons fit.
Josh
Whiteghost 2.5 is offline   Reply With Quote
Old 01-06-2008, 03:24 PM   #3
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
Just FYI the engine is approx 6" longer overall (and about 100lbs heavier) so you need to move the radiator and do pusher fans at the very least.
Ben
Old 01-07-2008, 02:50 AM   #4
Numbchux
Member#: 71658
'84 Brat
4" lift and 29" tires
Ben
I just wanted to emphasize this point......due to the size and weight issues, if you're going to the trouble/expense of fully building an engine, might as well go with an EZ 6-cyl. The new Link plus standalone system now has a downloadable base map/trigger setup that works with the EZ30DR with closed loop AVCS control.
Numbchux is offline   Reply With Quote
Old 01-07-2008, 04:00 PM   #5
GreenMarine
Member#: 36080
Oooooo, I'm interested in this... Where can I go to read about this engine map?
~ Chris
GreenMarine is offline   Reply With Quote
Old 01-07-2008, 04:29 PM   #6
Numbchux
Member#: 71658
'84 Brat
~ Chris
I haven't researched it much myself.....but here's a start:
http://forums.nasioc.com/forums/show....php?t=1358167
and
http://www.linkecu.com/forum/forums/lem/855742166
Old 01-07-2008, 04:46 PM   #7
GreenMarine
Member#: 36080
Sweet!! Thanks
~ Chris
How To - Swap a 2004 USDM STi Steering Wheel into a 2002 WRX Rizzo314 Interior & Exterior Modification 132 07-16-2016 01:27 AM
JDM STI EJ207 version 6 into USDM 02 wrx hELP!!! drftwell Subaru Conversions 6 07-31-2008 01:10 AM
Version 5 or 6 WRX or STi into a 2002 WRX? duece_bugeye Pre-2002 Factory Turbo Powertrain 6 03-24-2007 12:05 PM
2004 WRX clutch going into a 2002 WRX Hallywood Transmission (AT/MT) & Driveline 1 06-19-2006 02:48 PM
02-03 usdm wrx cluster fit into usdm 04 wrx? 11rex06 Electrical & Lighting 2 11-21-2004 09:48 PM
