Old 01-06-2008, 01:13 PM   #1
Barge
Member#: 62941
2004 WRX
Rally Blue
Default Relocated O2 sensor effects
I did equal length headers modified for an EWG some time ago and i relocated the front O2 behind the turbo, in the downpipe, because it made for better mounting since the 4-2-1 header had very little room in the area with all 4 cylinder merged.
Anywho... I just wondered if anyone had tuned a car with the O2 sensor relocated like that.
Is there any hidden information in the ECU related to the time delay for the O2 response?
My main issue is that the car seems to hunt more at idle than it did with the stock manifolds and also that at very light throttle positions, like going down a hill or something, the fueling will hunt really bad.. swinging from +25 short term to -25 back and forth.
I was considering modifying the O2 sensor calibration to basically deaden the area around 14.7 afr so that perhaps the ecu won't respond as much to changes. It seems almost like the ecu is making a correction and it isn't responding fast enough so it keeps pushing and overshoots.
Any suggestions?
Barge is offline   Reply With Quote
Old 01-06-2008, 01:41 PM   #2
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
What do you mean you relocated it to the turbo?
Do you really mean you tapped the housing? Or do you mean you relocated it to the downpipe like on the EVO or JDM twinscroll Subarus.
I asked my friend how his twinscroll was working out. He said his car idles just fine. Smoother in fact due to the equal length.
At idle, the flow should be steady state so it should still work fine. It sounds like your front O2 sensor is borked.
Here's a picture of the JDM front O2 sensor position.
mickeyd2005 is offline   Reply With Quote
Old 01-06-2008, 02:22 PM   #3
Barge
Member#: 62941
2004 WRX
Rally Blue
It is in the downpipe right behind the turbo.
Front O2 sensor vs Rear O2 sensor (MY00 RS) Jewbaru Service & Maintenance 3 07-29-2012 10:14 PM
FS (OH): WRX/STi rear o2 sensor, MAF sensor, MAP sensor coolblue05 Engine/Power/Exhaust 14 07-07-2009 02:52 PM
Effect on moving stock o2 sensor to post turbo? sorrowfulkiller Open Source Reflashes 31 05-06-2009 09:22 AM
Side effects of bad front O2 sensor?? Drews_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-29-2005 07:04 PM
Supposed to be a O2 sensor relocation kit available? BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-22-2002 07:50 PM
