Old 01-06-2008, 02:27 PM   #1
gaveup
Member#: 116036
2015 WRX STi
Default Idea for launch contro
Now, bear with me here because I am not some tuning expert or anything, but I was thinking on my way into work today about this.
Ok, so we all know enginuity is apparently never release their launch control (at least not any time soon), so there has to be some way to program it into the ECU. I mean cobb can do it, right? We know enginuity can, so it's most definately possible.
Does anyone know exactly how cobb programs the ECU to set launch control? If not, can't you just find a car that has LC using an access port and pull their map from the ecu using ecuflash or a similar program?
Just trying to see if there is anything I can do to get this done. Not wanting to buy an AP or any other expensive programmers.
*this is not a stab at all to enginuity. Just trying to move the process along.
gaveup is offline   Reply With Quote
Old 01-06-2008, 02:58 PM   #2
rkramer
Member#: 118209
2015 WRX Limitec
as i understand it, the things we upload are just blocks of data sets. The ones with launch control contain the memory, but also a jump instruction (in assembly) to a different block of data sets. if that condition is hit, (speed=0 for launch control), then the other dataset that has a lower rev limiter is used.
it isn't a matter of getting a map that does it that is hard, it is building the interfaces and backend that is probably slowing them down.
Old 01-06-2008, 04:01 PM   #3
Tea cups
Member#: 103136
I already developed launch control for testing for both the 16-bit and 32-bit ECU (with FFS also for the 32-bit ECUs) before Cobb even released their version. It is not very hard to do at all if you know what you are doing (per gear wg compensation is also easy which also has been tested). I've even been running a prototype real-time tuning on my 02 wrx which allows for on-the-fly map switching and dynamic map selection. The point is, the ROM hacks are not difficult to do. Plus we wouldn't copy someone else's code even if it wasn't easy. The problem is the user interface as well as how to best implement these features for the general public. Releasing hacked ROMs for download is not very feasible when you consider the number of different models, years, and markets. For a little perspective, the latest Enginuity/Ecuflash ECU definitions support 186 different Subaru ROM revisions. Even if you only support one revision per model/year/market, that is still quite a few to try to manage/host. Then there's the issue of what you do when you update the code? Do you maintain support for the older versions (for example, the definitions)? As you can imagine it can become an exponentially greater headache as well as more confusing for users as time passes.
The best solution is to implement a patching system in Enginuity that would be able to:
1. Patch existing supported ROMs with new code
2. Upgrade older versions to newer versions (i.e. versions of the ROM hacks)
3. Return ROM to stock.
4. display/hide relevant tables (ex. LC rpm threshold) based on features and version of the current ROM.
In addition, you have to plan ahead based on real-time tuning, especially for the 16-bit ECUs which have very limited RAM/ROM that we can make use of.
Even before the Enginuity site went down, contributions to Enginuity development had declined quite a bit. The only active java developer (that I'm aware of) right before the site went down was Kascade, who created/develops Enginuity's logger. So a lot of the features planned during the height of development were never realized due to the lack of java developers. I don't know if that will be the case in the future. If it is, then ultimately I'll release LC, per gear wg comp, etc. maybe through a free standalone app (I don't work with Java) and also possibly real-time tuning down the road as well, depending on how much time I have to work on it.
Other than myself and outside of Enginuity, the only other person that is working on ROM hacks that I know of is Freon who has developed his own speed density setup for the 32-bit ECU, so that is something else to look forward to in the future for the openecu community.
Tea cups is offline   Reply With Quote
Old 01-06-2008, 07:17 PM   #4
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Two questions:
Could features #2 and #4 be cut if the user just backs up their factory ROM before messing with launch control, speed density, or anything else? That way, the only patching that would be necessary would be from stock to whatever-modified-ROM. I guess it comes down to one question: is flashing to a stock image from an image with modified code any different from flashing to a stock image from an image with modified data (i.e. modified tables, which people are doing already).
To apply code patches to factory ROMs, would this work?
http://binpatch.sourceforge.net/doc.html
It seems optimistic to think that a simple pattern-based search-and-replace operation would do the trick, but I gotta ask. What other complexities need to be dealt with?
I'm guessing that the patches could alter the ROM's ECU ID, which should make #4 easy enough just using the existing ECU definition mechanisms (at least for tables in ROM).
Old 01-06-2008, 07:38 PM   #5
Tea cups
Member#: 103136
Originally Posted by NSFW View Post
Two questions:
I'm not talking about the ROM version, but the version of the feature. For example, it is likely that the features, such as LC, would be refined over time. So, this would need to be taken into account. Everytime there was a new version, the user would would have to manually transfer their tune over to the new ROM, if the hacked ROMs were simply uploaded instead of a more user-friendly patching of the ROM (with the ability to first remove the any older version). Flashing a hacked ROM is no different from any other modified ROM.
I could write the necessary patching application. But as I mentioned, I'm not a java developer, so it would be a standalone application and not integrated into Enginuity.
Yes, you could modify the ROM id (and change it for each new version if necessary). That is how I would do it if the other functionality is not added to Enginuity.
Old 01-06-2008, 08:09 PM   #6
DocDetroit
Member#: 24977
2003 WRX
I'm a java developer, but have never looked at the Enginuity code. Nor do I have any detailed knowledge of the internal workings of the ECU (other than some tuning).
I'd offer up my services to build a patching system. But I think my hill may be bigger to climb than Tea Cup's hill (learning java).
Tea Cups, what are you thinking for this patching system? Are we just talking about sections of binary data and list of where it overwrite or insert it into the ECU hex images?
DocDetroit is offline   Reply With Quote
Old 01-06-2008, 08:09 PM   #7
NSFW
Member#: 140444
05 Stage Free LGT
Thanks for clarifying. Yeah, I overlooked the issue w/ transferring the tune between ROM images. It seems like a similar approach would still work though - apply a patch for V1 of the feature, and then if V2 comes out, reverse that patch (returning the code to stock) and then apply the V2 patch.
Given the pace of Enginuity development, I'm all for the standalone approach. The usage scenario is pretty different from what Enginuity is all about. A user would only need to do this when code updates come out. Changes to the code and changes to the tune are probably pretty much independent. Unless maybe the user wants to update the LC rev limit right after applying the patch, but if the code gets patched with a standalone utility that would only take one extra download/tweak/upload cycle.
Also, if you get the ROM patches out there, maybe that would motivate someone to make the corresponding changes to Enginuity.
Old 01-06-2008, 08:50 PM   #8
Tea cups
Member#: 103136
I have no desire to learn Java.
If the Enginuity project continues on its current pace in the future (especially if the site is permanently down), then I'll come up with some tools to support LC,etc. and real-time tuning in visual basic (eventually at least). It might be easier that way, especially for real-time tuning since I know exactly what needs to happen. However, I am no-where near as skilled of a programmer as the Enginuity developers so it will likely not be as polished. But, hey, if it works, it works.
Yes, although there would need to be a master default which would return the ROM to stock for all past versions. This would be applied before a new version is applied to avoid any conflicts. The patching system is easy. The hard part is the interface and functionality to support real-time tuning.
Old 01-06-2008, 11:14 PM   #9
DocDetroit
Member#: 24977
2003 WRX
I'll start looking through the enginuity code. If I decide I want to give the patch manager a shot, I'd need to pick you brain Tea cups. I've got about a bazillion questions already. These don't need to be answered now, but I'm just thinknig out loud... I'm assuming we'll needa system to create/edit "patches". I'm assuming we'll need a system to manage the "patches." I'm assuming we'll need a system to apply and un-apply "patches". I'm assuming some patches may work on some images and not on others. I'm assuming some patches may be incompatible with other patches. Given an unknown ecu image are we looking to have a way to determine which patches are applied to it based on something contained in the image? And so on and so on...
Old 01-07-2008, 03:51 AM   #10
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
As I have mentioned - Enginuity is Open Source - so if there are devs willing the project should never go down.
I find what is currently happening with Enginuity.org VERY disappointing. The guys in charge should take a good look at them self because this is not how open source projects are supposed to be run.
If it is website troubles, then that is nothing - I will provide hosting for free. If it is something else, then make it public so we all know what is going on - you'd be surprised at the efforts the community will go to to stand behind an open source project if it is being targeted.
Anyhoo, the longer the site is down the more I start to worry. So to ease my mind, it would be very much appreciated if one of the current Enginuity devs would forward me a link to the latest 0.4.1b source code.
wrxsti.l is offline   Reply With Quote
Old 01-07-2008, 03:57 AM   #11
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
See that folder in your Enginuity install directory named "src"...
/me waits
/me waits some more
Yup.
Old 01-07-2008, 05:43 AM   #12
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Thanks for pointing that out.
To think I searched google for hours looking for the latest source files and didn't even think to check the Enginuity "program Files" directory - lol.
Cheers
Old 01-07-2008, 07:14 AM   #13
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
dude, not for nothing but you have absolutely no grounds to make such insinuations of incompetence.
maybe you'd be singing a different tune if you were here 5 years ago when the only reflash you could get cost you 1,000 dollars.
Old 01-07-2008, 08:25 AM   #14
Tea cups
Member#: 103136
The basic functionality is already there. The switch table allows for patching. It is currently used primarily for the CEL fixes. It would need to be expanded to allow for switch groups for which non-consecutive patches could be grouped together for a particular feature. And, of course, a default switch group that would return to stock all past patches. And then a simple interface to control this (with warnings the damaging effects of launch control, etc.). The patches would have to be rom specific, so they would be arranged as the current ECU defs are -> by rom id.
Old 01-07-2008, 08:32 AM   #15
Tea cups
Member#: 103136
The current issue with the site is not the fault of the guys in charge and has nothing to do with any action or lack of action that has been taken by them. As far as development of Enginuity, it is entirely up to how many developers are willing to contribute. You can't fault the developers who have taken the project as far as it has. They just don't have time to work on it anymore due to changes in their personal lives. I don't think the Enginuity site will be permanently down, but it has been awhile since I heard any more news.
Old 01-07-2008, 09:54 AM   #16
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Re read my post. I did not insinuate any incompetence. In fact I am more than happy with by the ability of the Enginuity devs and the application they have created.
BUT this does not mean I am not allowed to be disappointed with what is happening atm.
I only just purchased a WRX for the first time, and after looking around found the open source Enginuity application.
Now being pro open-source and knowing how to program, perhaps I wanted to contribute so that the extra features I was seeking would be implemented!
However since there is no project website there is no information for willing devs, no details of svn/cvs, no contact details, no list of current devs, no information pertaining to the source code etc etc - and that is what I find disappointing.
Do you see what I am getting at?
In no way am i saying that the work the devs have done is unappreciated, it isn't - I'm merely interested in the future of the project now that I have happened to stumble across it.
If the devs are too busy (for personal reasons) or just "over it" then that is fine, but there needs to be an avenue for future devs and people who want to contribute to the project to keep it going.
What happens every so often with open-source projects is that when a project is idling in no-mans land (like Enginuity is atm) other keen programmers (such as myself) will take what source code is available and fork the project.
This can be a good thing sometimes (as the new forked project will have some momentum and a fresh approach) but it can also waste resources that could be pooled to make the current Enginuity application better.
Anyhoo, I justthought that needed to be said, so you understand that I am not having a go at the current devs.
Regards
L
Old 01-07-2008, 10:15 AM   #17
DocDetroit
Member#: 24977
2003 WRX
I started looking at the source last night. It uses netbeans, their proprietary form files and swing jars. I'm an eclipse guy, so I had to get netbeans installed. I didn't see any ant build scripts, so I'm now sure how they are going about building this into an distribution although it's possible I missed it. It looks like it uses a package called RXTX for serial communications. That appears to be JNI. I started looking into getting that last night as well but I'm not sure what version the code is based on, etc.
There appears to be almost no comments nor any javadoc in the code.
In wrxsti.l's defense, without a home for the development that includes the proper packages, build scripts, tips about getting the development environment setup, and somewhere to control the distributions it does seem a bit daunting.
Old 01-07-2008, 10:19 AM   #18
Tea cups
Member#: 103136
The site issue is not the fault of any of the devs or the creator (Jared), nor is it possible to solve the problem by moving it to a different host (a lot of people have already offered free hosting but this not solve anything). We can't discuss what the dispute is, as this would compromise what was near resolved (last time I was able to get ahold of Jared, anyway). Meaning that if the details were revealed, you can pretty much guarantee that there will be no more Enginuity site. As I have said before, this has nothing to do with intellectual property and has nothing to do with any tuning companies, such as Cobb and Ecutek, where it could be said that Enginuity might compete with them to some degree. Enginuity is not being bought out either, as far as I know.
Old 01-07-2008, 04:41 PM   #19
reddoak
Member#: 147628
2014 Fiat Abarth 500
Rosso
...We can't discuss what the dispute is, as this would compromise what was near resolved (last time I was able to get ahold of Jared, anyway). Meaning that if the details were revealed, you can pretty much guarantee that there will be no more Enginuity site...
OK folks, I think it's fair to say that we're not going to be told the reasons why the site is down. Let it go.
You can still get the software at Ken Gilbert's site, you can still get ROMs at Osecuroms, you get info on tuning at openecu.org, and you have access to the people who seemed to do most of the developement on this site and the others just mentioned.
Curiosity is human nature, but really, we've all been politly asked to wait and be patient. Being a pain in Jared's ass won't accelerate the process, and evidently may make it worse. Bugging Tea cups isn't going to get an answer either, and won't bring the site back even if you do get an answer.
This particular topic (why is Enginuty.org down) is showing up in almost every thread here, and it's gotten old. If you want to bitch about something you can't fix, go somewhere else (preferably OT) and do it.
reddoak is offline   Reply With Quote
Old 01-07-2008, 05:50 PM   #20
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
And as I said, I think that is unacceptable for an open-source project and very dissappointing.
This is fine for those that simply want to install and tune - but what about those who want information relating to development of the code?
Curiosity is human nature...
And open-source software is supposed to allows you to be curious
Old 01-07-2008, 07:19 PM   #21
reddoak
Member#: 147628
Rosso
He (Jared) is not doing anything unacceptable. He owes all of us nothing. Not even explainations... As shocking as it sounds, open source doesn't mean "free-ride." It is open source, the source code IS available publicly. That's it. You, me, none of us have no claim on his personal time. He hosted and ran the web site, but he was not, and is not obligated to spend his time, money, or effort in any amount he doesn't see fit.
Want info on developement, ask Tea cups. Post questions asking about developement. Guess what, open source doesn't mean ANY developer is obligated how to teach you to do what they do.
Go ahead an be curious, but demanding something you aren't due is rude. Complaining about it to no positive effect is ridiculous. You've asked, you've been told no, and it's pretty immature to keep asking.
If you feel so strongly about this, why not start your own web site? Create a forum and make it available to the public, like he did. Rather than sit around, complaining that no one is doing the hard, unglamourous part if it, step up to the plate and take that role on. I'm sure most everyone here, including myself would support you on some level with it.
Old 01-07-2008, 09:28 PM   #22
NSFW
Member#: 140444
05 Stage Free LGT
Yup. All that's really needed right now (IMO) is a source control server with the last-known-good revision and an administrator who is willing to grant write access to, or process submissions from, interested developers. Far as I know, this could start with the source in the installer that ride5000 is distributing. I'm guessing there won't be a flood of new commits anytime soon, so the administrative overhead should be fairly small.
NASIOC's forum will suffice until Enginuity.org is either revived or pronounced dead.
It would be great to have Enginuity's wiki again, but the information there was aimed more at users than at developers so its absence isn't blocking development.
Old 01-08-2008, 12:42 AM   #23
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
First and foremost I need to say that this will be my last post on this and I'm sorry if I have said things that have offended the current devs, it was never my goal.
I wish you guys/gals all the best and want to thank you for your time and effort in creating Enginuity for the public. Thank you.
I never said he did and I never said it was.
The GPL also stipulates that all make files and any other files relating/required to comilation of the source code
I never said it was. Gees mate, please re-read my posts.
People are allowed to express their disapointment in the current affairs mate, afterall it is a forum. Please explain to me what it is you think I keep demanding so I know how I am being rude.
If you actually take the time to read my posts, instead of focusing on what you can flame, you would see that I mentioned this, but I did not think it was good for the current Enginuity project.
I quote myself just for you - take note of the bold text.:
"What happens every so often with open-source projects is that when a project is idling in no-mans land (like Enginuity is atm) other keen programmers (such as myself) will take what source code is available and fork the project. This can be a good thing sometimes (as the new forked project will have some momentum and a fresh approach) but it can also waste resources that could be pooled to make the current Enginuity application better."
I could set up a new project and fork enginuity (and I am contemplating this atm), but I DO NOT want to re-create the wheel when there are still some active devs working on the current enginuity project who are churning out stable releases.
Anyhoo, I've started digging through what is available and who knows - something fresh may already be in the making
Old 01-08-2008, 02:00 AM   #24
NSFW
Member#: 140444
05 Stage Free LGT
Enginuity's developers weren't exactly "churning out stable releases" before the forum went down. Kascade was doing some work on the logger IIRC so you might want to coordinate with him if you want to work on that stuff but the core map editing stuff wasn't changing much. Qoncept had a large refactoring in mind but wasn't making much visible progress with it. Merchgod was releasing XML updates frequently but that can evolve independently from the Java.
Stuff like ROM patching might benefit from close coordination between XML and Java, but like I said earlier I think decoupling that from Enginuity might help it move forward faster. Then integrate everything when it's stable and only if it's really worth the trouble to integrate. (I personally don't see a problem with using separate tools to modify the code vs. the data.)
Some fresh contributions might be just the thing to get the project moving forward again.
Old 01-08-2008, 06:09 AM   #25
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
what i'm failing to see is the crux of wrxsti.l's desire to have an "enginuity" open source project flourishing.
what exactly does the current revision lack? what exactly is he looking to do? it's never been stated, and from my perspective he's making much ado about nothing in particular.
Have ECUTEK, any chance for launch control? faylix Engine Management & Tuning 8 05-24-2005 02:22 AM
Using E-Brake for launch? DDMan Transmission (AT/MT) & Driveline 14 02-10-2004 02:00 AM
techniques for launching... URABUSx714 Newbies & FAQs 4 11-17-2002 02:07 PM
Proper Technique for Launch? Beachpig Newbies & FAQs 2 09-28-2002 03:20 AM
Ready for launch 2OHOH2WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 03-10-2002 06:16 PM
