Welcome to the North American Subaru Impreza Owners Club Wednesday January 28, 2015
Old 01-16-2008, 05:04 PM   #26
benw
Member#: 103320
2005 wingless
aspen white
Originally Posted by williaty View Post
However, if the AFR targets weren't being met because the MAF scaling was off, then in stock form you're getting bad load data anyway. Fixing the MAF scaling would fix both the AFR targets AND give you correct load data.
The real question is what's wrong in the stock tune.
we're talking stock cars here, and from what I've seen, the stock airbox and ECU calibration are pretty darn close. I've only seen about 6-7 cars but they were all within 3-5%. The only one that wasn't had a dirty maf sensor, cleaned it up and all was good.
benw is offline   Reply With Quote
Old 01-16-2008, 05:46 PM   #27
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Testes, if the injector scaling is the actual problem, then fixing it rather than MAF scaling is the correct thing to do.
The injector scaling would give a consistent change across the board, the errors i've seen are not. To me that points to either just the maf table, or both.
With that said, it is a good point about changing the maf table... it will affect anything load related.
ExpO is offline   Reply With Quote
Old 01-16-2008, 07:43 PM   #28
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I've seen exactly the same thing on my car. The error is not consistently in one direction, and you can't fix that with just injector scaling.
Logged target boost does not match map STIlin' Open Source Reflashes 1 04-15-2009 01:10 AM
Stage 2 WRX map enginuity HKSpowerWRX Commercial ECU Reflashes 3 12-04-2007 01:12 AM
Stage 2 WRX looking to go back to the stock map-Questions.. SubbieAndCoop Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-14-2007 10:22 PM
06 Stage 2 WRX PDXtuning map drmichael North West Impreza Club Forum -- NWIC 11 10-20-2006 06:56 PM
PDX Maps for 06 Cobb Stage 2 WRX sleestak6326 TXIC Private Classifieds 15 07-23-2006 11:34 AM
