Old 01-06-2008, 10:52 AM   #1
35xj
Member#: 152267
2002 wrx
white
Default The OFFICIAL "I hit something while driving in snow and something broke" thread
had a small crash in the snow. smacked the passenger wheel againt a curb. Didn't hit very hard, but...
bent the a arm, gat a new one on the way. the question.
on the steering rack. the male portion that threads into the tie rod end (female on the knuckle) fairly small dia rod. Iits bent. is this a replacable piece? or do i need anew rack?
i'll try to post a pic. dave
35xj is offline   Reply With Quote
Old 01-06-2008, 10:53 AM   #2
MasterKwan
Member#: 98961
2003 WRX
Inner tie rod. It's replaceble.
Old 01-06-2008, 10:58 AM   #3
35xj
Member#: 152267
2002 wrx
white
wow, that was fast! thanks! I also ordered new poly bushings. anything else i should replace while its apart?
is the inner tie rod end a dealership only part?
Old 01-06-2008, 11:29 AM   #4
MasterKwan
Member#: 98961
2003 WRX
I got and installed one from Napa because I was impatient. Then the one, I ordered from Subaru showed up. The subaru one was far superior to the Napa one. I'd get a real subaru part. I've haven't taken the Napa one off yet so, I guess I have a spare.
Old 01-06-2008, 04:50 PM   #5
35xj
Member#: 152267
2002 wrx
white
gonna put springs on the car while its down. What else should i replace? other bushings? Pretty new to Subi's so let me know. dave
Old 01-06-2008, 07:43 PM   #6
Ostrowrx
Member#: 141342
2010 WRX STI
Default The OFFICIAL "hit something while driving in snow and want to know what broke" thread
I recently slid into a curb rear passenger side first followed by front going about 15 maybe 20mph while playing in the snow. So I replaced everything that looked bent, trailing arm, and lateral links, wheel and all associated bolts. impact was enough to crack front rotor as well. Well its all back together and the wheel is still sticking out on top a few inches. Is it safe to say that its just the strut?, Or should I track down a knuckle as well?. all body gaps seem fine a subframe looks fine. What else should I look for or measure. Any suggestions are welcome!
Ostrowrx is offline   Reply With Quote
Old 01-06-2008, 08:07 PM   #7
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
This is to merge the various snow accident threads into.
Old 01-06-2008, 08:10 PM   #8
Butt Dyno
Member#: 17301
is the "dark side"
Old 01-06-2008, 08:11 PM   #9
Butt Dyno
Member#: 17301
is the "dark side"
Old 01-06-2008, 10:54 PM   #10
MasterKwan
Member#: 98961
2003 WRX
I once drove my VW Karman Ghia straight over a curb in the snow going about 30. Future wife in the car. Stopped, took a hammer to the steel wheel which had peeled back like a banana then beat it back into shape and drove it for another year. No damage. Of course that car only weighted 2100 lbs.
Old 01-16-2008, 06:22 PM   #11
jchin829
Member#: 119909
02 WRX Stage 2++
WR BLUEE
Default so i smacked the curb back in thanksgiving...
i smacked the curb back around thanksgiving. had to replace the front passenger side control arm and some other stuff. my mechanic couldn't replace the rear passenger lateral link because of the rusted bolts. he bent it back and my car drives fine right now. got an alignment too but the wheel is still crooked.
he said if i wanted to replace the lateral link i would have to replace the spindle as well because he can't remove the bolt.
here are some pics. wanna see what you guys think and what exactly i would have to replace.
jchin829 is offline   Reply With Quote
Old 01-16-2008, 06:38 PM   #12
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
Seriously, time to get a new mechanic... Have him use a freaking breaker bar... If he still cant break the bolt, cut the damn bolt off - if its that rusted, you should use a new one anyway...
gto7419 is offline   Reply With Quote
Old 01-16-2008, 06:40 PM   #13
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
That bolt is a PITA if it's rusty. Cut if off, and knock out the rest with a punch and a BFH.
Old 01-16-2008, 06:55 PM   #14
jchin829
Member#: 119909
02 WRX Stage 2++
WR BLUEE
bfh = big ****ing hammer?
Old 01-16-2008, 07:10 PM   #15
Turn in Concepts
Member#: 93646
Many Track Records
Yes indeedy doodly.
Old 01-16-2008, 11:48 PM   #16
jchin829
Member#: 119909
02 WRX Stage 2++
WR BLUEE
do you guys see anything else bent or a little off from the pictures? found a lateral link for 40 bucks
Old 01-17-2008, 08:47 AM   #17
Butt Dyno
Member#: 17301
is the "dark side"
Merged jchin829's thread.
Old 04-01-2008, 09:34 PM   #18
Scowboy
Member#: 149474
06 WRX
CGM
Though these cars rip in the snow, I get the feeling that Subaru overlooked that use in the newer cars. My cheap plasic skidplate snow loaded and broke (replaced with alum, makes changing oil messy!) and I have to carry a special stabbin stick to beat the ice out of my wheels. I would have preferred 16" wheels but the 4 pot brakes are a good trade off. I had to go with Nokian WRG2 tires for winter, probably why I am not posting a wreck post. Saved my bacon on many a warp speed Mt Hood ascent.
Scowboy is offline   Reply With Quote
Old 06-20-2008, 05:17 PM   #19
meatball18
Member#: 97123
2004 wrx black
boost gets you laid
subscribed
meatball18 is offline   Reply With Quote
Old 07-09-2008, 01:43 AM   #20
Makako54
Member#: 110013
2006 Impreza WRX
Hit a curb myself on pass side, Top of wheel stuck out side of fender and even rolled it out a bit. rear knuckle and strut were bent. May have some issues on the front as well.
Makako54 is offline   Reply With Quote
Old 11-19-2008, 05:14 PM   #21
iceman1733
Member#: 159665
04 STI
Hey I can add another one to the list for hitting a curb. We had about an inch of snow and ice near my campus and I was going into a turn doing about 5 mph and tires went out and I hit a curb. All the weight of the car went to the wheel and pushed it back a good 2 inches. Just went to the Subaru dealership and got quoted about 2000 in parts. Said I need a new strut, crossmember, links, front bearing, frame assembly tie rods, and axle.
Guess its time to call insurance. I love how my college missed the memo to plow any roads/parking lots on their campus since I wasn't the only one. I would say this price would be the HIGH part of the estimate for you, lol.
iceman1733 is offline   Reply With Quote
Old 11-20-2008, 12:06 AM   #22
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You can't do that kind of damage at 5MPH. It's just not possible. Dinged rim? Sure. Bent tie rod? Definitely. Bent crossmember, axle, bearing? No way in hell.
Old 11-20-2008, 12:21 AM   #23
iceman1733
Member#: 159665
04 STI
Hey I think Subaru was just covering themselves because from what me and my uncle looked it looks just like the control arm is messed up and needs replacing. But I was definitely doing that speed just when the traction gave out the only thing that impacted was the front drivers tire so that took the impact.
Old 11-21-2008, 02:49 AM   #24
06WHTWRX
Member#: 173690
2005 Ferd
F-TeenThousand
find a new dealer, you're getting screwed
06WHTWRX is offline   Reply With Quote
Old 11-21-2008, 10:01 AM   #25
XRWITS
Member#: 157870
0407 STi's
One Black, One White
Default Word of advise
Buy a damn STi. I didn't do this in the snow but I drifted a intersection and could not correct it in time and I went over a median up one huge curb through the bark dust, over another bigger curb and into on coming traffic... all it did was bent the **** out of my rota tarmac II wheel (one of them) so I put the BBS's back on and she kept on going. LOL they are built like battle tanks
XRWITS is offline   Reply With Quote
The official "I like the GTR, and I don't give a **** what OT thinks" thread. Strider Off-Topic 181 05-13-2015 10:18 AM
The official "I drove through some snow, and now my car shakes" thread Turn in Concepts Brakes, Steering & Suspension 48 07-09-2014 10:19 PM
The Official SEEK (john) needs to buy a turbo and nothing else thread blackrex13 Mid Atlantic Impreza Club -- MAIC 29 10-09-2009 03:58 PM
STi wheel hop bounces while driving in snow hilfiger4you Transmission (AT/MT) & Driveline 2 02-13-2007 11:14 PM
Driving In Snow And Ice... I Need Tips !! EagleRockWrex General Community 44 01-03-2006 12:32 PM
