Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 01-07-2008, 01:17 AM   #1
Solotoy
Member Sales Rating: (2)
Member#: 99421
'13 BRZ
White Pearl
Default WA: Tein RA
Tein RA - $1100 – Renton, WA *****Price Reduced***** - Sold!
TEIN Type RA has been designed for advanced circuit racing and street use for experienced drivers. It incorporates a newly designed mono-tube structure, which allows for maximum road handling and driving stability for all type of situations. This product has been developed from a huge background of TEIN motor sports activities (such as the World Rally Championship, N1 and endurance racing).
* Mono-tube design for maximum performance.
* Strut type suspension has an inverted steel shock absorber for durability.
* 16 levels of damping force adjustment (compression and rebound together).
* Ride height adjustable.
* Exclusive designed pillow ball upper mount for optimized performance.
The front camber plates have been professionally machined to optimize negative camber and caster. Spring rates are 10k and 6k. These fit ‘02+ Imprezas.
Solotoy is offline   Reply With Quote
Old 01-07-2008, 01:22 PM   #2
Solotoy
Member#: 99421
'13 BRZ
White Pearl
Bump for sweet performance
Old 01-08-2008, 12:18 PM   #3
Solotoy
Member#: 99421
'13 BRZ
White Pearl
Autocross season is right around the corner
Old 01-09-2008, 01:45 AM   #4
selvar05WRX
Member Sales Rating: (9)
Member#: 165524
2012 CTS-V Sedan
Black Diamond Tri-Coat
How old are the coilovers and about how many miles on them?
selvar05WRX is offline   Reply With Quote
Old 01-09-2008, 12:34 PM   #5
Solotoy
Member#: 99421
'13 BRZ
White Pearl
I'm not entirely sure since they were on the car when I bought it. I removed them when the car had roughly 60k. They probably have 20-30K on them. None of them have leaks. They all have gas pressure.
Old 01-11-2008, 03:59 PM   #6
Solotoy
Member#: 99421
'13 BRZ
White Pearl
The weather is getting better. It's time to prep your car for this coming season.
Old 01-13-2008, 04:39 AM   #7
petawabit
Member Sales Rating: (66)
Member#: 18978
96 brighton
05 AP2 ,09 GE8
why the 10/6 springs, if you don't mind me asking
petawabit is offline   Reply With Quote
Old 01-14-2008, 12:07 PM   #8
Solotoy
Member#: 99421
'13 BRZ
White Pearl
When I bought the car, it came with 10/8/6 springs. I'm using the 8 with other shocks. That leaves the 10/6 for sale. Springs are only $50-60 ea. if you want to change the spring rates to something that matches what you are looking for.
Old 02-01-2008, 08:28 PM   #9
Solotoy
Member#: 99421
'13 BRZ
White Pearl
These were a great value at $1200 but are now a steal at $1100.
Old 02-06-2008, 10:26 PM   #10
Solotoy
Member#: 99421
'13 BRZ
White Pearl
Bump for a nice upgrade
Old 02-06-2008, 11:20 PM   #11
jyi
Member Sales Rating: (6)
Member#: 147312
2007 WRX Stage 1
Black Obsidian Pearl
Whats the average life span of these coilovers?...*sorry for noob question .
jyi is offline   Reply With Quote
Old 02-07-2008, 02:49 PM   #12
Solotoy
Member#: 99421
'13 BRZ
White Pearl
Life of your vehicle. The primary reason you'd rebuild them is if they blew a seal and lost their pressure. You also might rebuild them if you wanted to change the valving to accommodate a spring rate that is outside of the shock's current capability. If they ever need to be refreshed, Tein charges $130/shock to return them to factory spec. Additional details can be found at http://www.tein.com/seavice/index.html
These shocks all have great pressure and have had springs on them that are well within their operating range. The RA is an inverted mono tube and is one of the beefiest shocks that Tein makes.
Old 02-07-2008, 03:41 PM   #13
jyi
Member#: 147312
2007 WRX Stage 1
Did you auto-x, or track with these coilovers? If so, how many miles tracked?
Old 02-08-2008, 01:24 AM   #14
Solotoy
Member#: 99421
'13 BRZ
White Pearl
They are off the car and all cleaned up. They have been off the car since the end of '06 or Jan '07. They have only been autocrossed and daily driven on.
Old 02-13-2008, 02:25 PM   #15
Solotoy
Member#: 99421
'13 BRZ
White Pearl
bump to the top
Old 02-14-2008, 12:10 AM   #16
mikea322
Member#: 112314
2002 wrx wagon
platinum silver
pm sent
mikea322 is offline   Reply With Quote
Old 02-15-2008, 03:52 PM   #17
Solotoy
Member#: 99421
'13 BRZ
White Pearl
Rear camber bolts are included.
Old 02-20-2008, 12:20 PM   #18
Solotoy
Member#: 99421
'13 BRZ
White Pearl
bump bump
Old 03-01-2008, 05:21 PM   #19
live_2race
Member#: 82199
02 WRX and S2000
Could I use my Rear Cusco Camber Plates with these?
live_2race is offline   Reply With Quote
Old 03-03-2008, 11:54 AM   #20
Solotoy
Member#: 99421
'13 BRZ
White Pearl
Yes you can. You would simply use the Tein pillow nuts in the Cusco camber plates. The non threaded, smooth, outside of the pillow nuts are the same size for both the Tein and the Cuscos. The threaded inside of the pillow nuts are 12mm for the Cuscos and 14mm for the Teins.
Old 03-05-2008, 01:06 PM   #21
Solotoy
Member#: 99421
'13 BRZ
White Pearl
bump to the top
Tein Flex vs Tein RA Coilovers LTBlackBird Brakes, Steering & Suspension 19 12-17-2009 01:19 PM
FS WA: Tein RA Solotoy NWIC Private Classifieds 14 03-04-2008 02:09 PM
FS WA: ver6 RA gearset w/ syncros RoundtheBend Private 'For Sale' Classifieds 37 05-19-2006 05:33 PM
TEIN RA - TEIN FLEX rebuild cost - Which to Choose? engineerx Brakes, Steering & Suspension 22 09-23-2004 09:20 PM
Tein RA spring Squeak? RA owners please respond zoomfactor Brakes, Steering & Suspension 5 11-10-2003 12:39 AM
