Old 01-07-2008, 09:24 AM   #1
wrxracer519
Member#: 149890
09 Forester
Green
Default First log, let me know what you think and whats going on.
Air/Fuel Correction #1 (%)
Air/Fuel Learning #1 (%)Feedback Knock Correction* (degrees)Fine Learning Knock Correction* (degrees)IAM* (raw ecu value)Ignition Timing (degrees)Ignition Timing Advance* (degrees)Manifold Absolute Pressure (psi)Engine Speed (rpm)2.343.1200.351125.55.2715.67239402.3401.411122.55.6217.122538-17.972.3402.461121.55.9818.14262001.5602.8111205.9819.01264501.5602.8111195.9819.88276600.7802.8111185.9820.8928670002.8111176.3321.9129600002.8111166.3323.6531030-0.7802.8111155.9824.9632000-0.7802.8111145.9826.2632790-1.5602.4611145.9826.8433950-1.5602.4611135.6227.1334430-1.5602.461112.55.2727.4235220-1.5602.461111.55.2727.4235900-2.3402.461111.55.2727.5736550-2.3402.461112.55.2727.5737180-3.9102.4611135.2727.5737740-3.9102.4611145.2727.5739260-3.9102.461114.55.2727.5739810-3.9102.4611145.2727.5740500-3.9102.461114.55.6227.5741280-3.910-1.411110.55.6227.5741920-3.910-1.4111105.6227.5742960-3.910-1.41119.55.2727.7143450-3.910-1.41119.55.2727.8644300-3.910-1.4111105.622845230-3.910-1.411110.55.9828.2946210-3.910-1.411110.55.9828.2947080-3.910-1.411110.56.3328.2947920-3.910-1.4111116.3328.4448830-3.910-1.411112.55.9828.5849700-3.9101.4111165.2728.5850710-3.9101.4111185.2727.715140
This is the first log i have ever done. I know my IAM is supposed to be 16. My car is an 02 wrx auto, with a 4eat. The mods are snorkus delete, k&n filter, up-pipe, turbo back. It is on the stock uce, i wanted to see what my ecu is doing before i try and flash. Please let me know what you think of this log. I know there are some parameters missing. This is done in 2nd gear as that is the only gear i can go WOT and not down shift.
wrxracer519 is offline   Reply With Quote
Old 01-07-2008, 09:25 AM   #2
wrxracer519
Member#: 149890
09 Forester
Green
Mod delete please, didn't put it up right. Trying to figure out how to post a log.
Old 01-07-2008, 03:16 PM   #3
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
mickeyd2005 is offline   Reply With Quote
Old 01-07-2008, 03:50 PM   #4
wrxracer519
Member#: 149890
09 Forester
Green
thanks, just found out about this. Gonna sign up tonight and post again
Old 01-08-2008, 10:32 PM   #5
fulham
Member#: 167864
2005 Saabaru Aero
Default How to post a nicely formatted log
how to make a pretty (i.e. readable) log
1) open up your .csv in excel
2) replace the headings with the standard abbreviations:
Air/Fuel Correction >>> afc
Air/Fuel Learning #1 >>> afl
Feedback Knock Correction >>> kc
Fine Learning Knock Correction >>> flkc
IAM >>> iam
Ignition Timing >>> it
Ignition Timing Advance >>> ita?--not sure
Manifold Absolute Pressure >>> map?--not sure
Engine Speed >>> rpm
i also use:
engine load >>> el
manifold relative pressure >>> mrp
toa >>> throttle opening angle
iat >>> intake air temp
3) select all cells
4) format/text alignment/ left
5) futz with the column width to make it pretty
6) save as >> *.prn
7) open your *.prn file in notepad
8) ctrl-a/ctrl-c
9) in the forum message composer select # (code)
10) make sure the cursor is between the CODE tags
11) ctrl-v
12) hit preview and make sure it looks good!
13) submit!
Last edited by fulham; 01-08-2008 at 10:34 PM. Reason: ctrl-v, not ctrl-a in step 11. yes i'm a windows shortcut key master!
fulham is offline   Reply With Quote
Old 01-09-2008, 01:51 PM   #6
wrxracer519
Member#: 149890
09 Forester
Green
fulham, thanks, i will try this when i get home from work today. Haven't had the time the last few days to repost it.
My latest project. Let me know if you think it will work. balbino Off-Topic 6 03-19-2006 03:02 AM
Let Nicky know what you think he should cover on Speedtv leaknoil Motorsports 1 07-12-2005 06:50 AM
Heres my first pics...let me know what you think wrx78 Member's Car Gallery 7 04-01-2004 09:03 AM
Let me know if you see me on TV WRXWES Off-Topic 2 12-02-2003 07:22 PM
Let me know when you are going to meet at starbuck's??? EIMPREZARS Southern California Impreza Club Forum -- SCIC 2 12-27-2001 10:20 PM
