Old 01-07-2008, 12:51 PM   #1
Giganticprune
Member#: 147662
2006 wrx tr stage 2
Default sti HID's in a wrx?
i was wondering how hard is it to drop sti headlights into a wrx. ive never seen any threads on this and i was thinking maybe one day i would go scouting for a wrecked sti at a junkyard.
Giganticprune is offline   Reply With Quote
Old 01-07-2008, 12:53 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by dithergizzard View Post
MY04-05 WRX/STI retrofitted:
- by hidtech.com: http://hidtech.com/projects/01500.jpg, http://hidtech.com/projects/01504.jpg
- by a nasioc member (includes head-on and beam pattern pics): http://forums.nasioc.com/forums/show...hella+bi-xenon
- threads with retrofit pictures (mostly MY04-05), including non-projector units and projectors:
http://forums.nasioc.com/forums/show...5&page=4&pp=25
http://forums.nasioc.com/forums/show...=projector+STi
In conclusion, the best advice that can be given regarding purchasing HID is simply to do your research. Take the time to search through the huge number of threads on this forum concerning this topic, as well as those on http://www.hidplanet.com/forums/ (if you plan on retrofitting). Here are a couple of comprehensive lighting FAQ sites with lots to dig through that I linked to throughout this post:
http://faqlight.carpassion.info/
http://www.danielsternlighting.com/home.html
dithergizzard
http://forums.nasioc.com/forums/showthread.php?t=664361
have you taken a look at lightwerkz?
Old 01-07-2008, 02:00 PM   #3
Giganticprune
Member#: 147662
2006 wrx tr stage 2
i have taken a look at that stuff before, but it seemed a little out of my range for the amount of work i wanted to do. maybe i didnt come off clear, i was wondering how much work would be associated with taking the whole STI headlight assembly, and making them work in my car. at this point it doesnt seem like it will be plug + play...
Old 01-07-2008, 02:09 PM   #4
Knightmare69
Member#: 25039
2005 CGM Stage 2 WRX
SQC 275
Same headlights, just differently designed reflectors, so just pop out the old headlights, install the STi ones and plug and play I'm sure.
Knightmare69 is offline   Reply With Quote
Old 01-07-2008, 03:33 PM   #5
eduSti
Member#: 136503
08 STI
im not sure that the connector is the same but the lights should bolt on the same
eduSti is offline   Reply With Quote
Old 01-07-2008, 03:55 PM   #6
nhat
Member#: 140163
03 STi
hellaflunctional
you would most likely have to upgrade your wiring anyways. looks like you'll need the headlights, wiring/harness/plugs, ballasts, and DRLs disabled.
Old 01-07-2008, 04:29 PM   #7
Giganticprune
Member#: 147662
2006 wrx tr stage 2
eh im lazy and dont really need HID's. thanks guys
Old 01-07-2008, 04:31 PM   #8
Knightmare69
Member#: 25039
SQC 275
Then just get plug n plays, honestly, not the best option but I installed a set in my friends 04 WRX and it came out fine. We aimed to factory specs and then lowered it from there to minimize glare.
Old 01-11-2008, 01:06 PM   #9
LightWerkz
Member#: 125432
2004 E46 M3
http://lightwerkz.net
You just need the plug and play wiring harness we provide, its $75 shipped
LightWerkz is offline   Reply With Quote
Old 01-11-2008, 01:13 PM   #10
jdmimprez
Member#: 153318
08 EVO X GSR
Why would you need the DRL disabled? Is there something wrong w/ having HID's w/ as DRL?
jdmimprez is offline   Reply With Quote
Old 01-11-2008, 01:20 PM   #11
ATMO5PHERE
Member#: 120820
O MF
G!!!!!!
its not THAT hard to do retrofits, but it is kind of expensive, you just need an extra pair of headlights it just takes alot of time baking, sodering, getting ther perfect shroud/ bezel that you want and alot of measuring. Check out hidplanet.com's forums or talk to LightWerks they have alot of cool stuff to read about
ATMO5PHERE is offline   Reply With Quote
Old 01-11-2008, 01:30 PM   #12
105wrx
Member#: 75931
2005 hmmm STI?
Clark Tuned!
^it just limits the life of the hid bulb and ballast...
105wrx is offline   Reply With Quote
Old 01-11-2008, 03:14 PM   #13
Knightmare69
Member#: 25039
SQC 275
DRL's usually run at less power then when the lights are on usually. Therefore the HID's would not get the power it needs and implode on itself sucking the lights and the car into a blackhole
But seriously the first part is true.
STI HID's in a wrx??? P.I.C Electrical & Lighting 7 10-29-2009 09:07 PM
how to install MY04 USDM STi HID's on a WRX? skivvie Electrical & Lighting 73 07-03-2009 10:53 PM
06 sti hid's in 06 wrx blah0r Interior & Exterior Modification 3 01-08-2007 09:04 PM
installed HID's in 06 WRX. are drl's okay??? toekneeyo Electrical & Lighting 22 03-08-2006 08:53 PM
what bulb size for HID's in stock wrx headlights? turn off day lights.. M32WRXin3seconds Newbies & FAQs 8 08-08-2003 04:29 PM
