Old 01-07-2008, 05:47 PM   #1
Bboy AJ
Member#: 127021
2006 OBP WRX TR
Default ECU Flash not reading, help!
Please help. I recently purchased a Tactrix cable and wanted to flash to gabedude's stage 1.
I have an 06 5 speed WRX.
I hooked up the green connectors. I made sure they were connected by turning the ignition on, seeing the CEL flash, and hearing the fans.
Remove the key from the ignition. Open ECUflash. Plug Tactrix cable into laptop. The "Read" button colors in. Plugged in cable to OBDII port under steering wheel. Hit "Read" graphic button and the "Read" rectangle is grayed out. Flash graphic button on ECUflash is always grayed out.
I'm not sure what I did wrong. I updated the definitions for ECUflash. It just doesn't seem to read that the cable is in the OBDII port. I mean, is there something wrong with the cable? I just took it out of the box, blew the dust out of the port, and that's it.
Please help! I desperately want to flash to stage 1. Thanks.
Bboy AJ is offline   Reply With Quote
Old 01-07-2008, 06:03 PM   #2
wrxracer519
Member#: 149890
09 Forester
Green
Make sure you updated the drivers for the tactrix cable under control panel-> system-> device manager, then update the drivers with the drivers from ecuflash. I had to do that to get it to work and the past two days i have been loggin my car like crazy.
wrxracer519 is offline   Reply With Quote
Old 01-07-2008, 06:06 PM   #3
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
You removed the key from the ignition?
Did you put it back in? The key needs to be in the on position (without the engine running) to read/flash your car.
mickeyd2005 is offline   Reply With Quote
Old 01-07-2008, 06:35 PM   #4
Bboy AJ
Member#: 127021
2006 OBP WRX TR
Really? I thought I read that the key should not be on until the prompt tells me to do so. I have not received such a prompt.
From the FAQ:
Do not turn on your ignition until prompted by Ecuflash to do so and when you do, immediately hit ‘OK’, otherwise reading/flashing may fail (any moderate delay on your part can result in a failure). Note: The engine should NEVER be running when reading or flashing.
So...
Green connectors together
Plug in USB and OBDII
Key in the on position?
Run ECUflash
Read
or
Run ECUflash
Wait for prompt asking to put the key in the on position
Read
Thanks for the ongoing help
Old 01-07-2008, 06:39 PM   #5
Bboy AJ
Member#: 127021
2006 OBP WRX TR
I just did this and got the drivers from "D:\Program Files\OpenECU\EcuFlash\drivers\x86" and it said that there was no better match. So I suppose I already had this front covered. Thanks, though.
Old 01-07-2008, 09:53 PM   #6
maxbserr
Member#: 148417
WRB XPTStg2/GMBCS
Go under file/options/ then check to see if the directories are mapped to the folders correctly. I had this same issue with my install of ecu flash.
You want to check
Rom File Directory.
Color Map Directory
Metadata Directory.
maxbserr is offline   Reply With Quote
Old 01-07-2008, 09:54 PM   #7
Bboy AJ
Member#: 127021
2006 OBP WRX TR
Alright, I figured it out. If anyone has this problem, please heed:
The reason why nothing showed up when I picked "Read ECU" was because I pointed the directory DIRECTLY to the WRX folder. Instead, you need to select the "Subaru" folder.
Flashed to gabedude's stage 1, drove for a few miles, loved it! Thanks
Old 01-07-2008, 09:57 PM   #8
maxbserr
Member#: 148417
WRB XPTStg2/GMBCS
Drive it for a while then buy a downpipe off ebay. Flash over a stage 2 and love it more.
2007 wrx, open port 2.0 ECU flash wont read Dubstar112 Open Source Reflashes 5 06-25-2013 10:38 PM
Need help with an ecu flash subesport Newbies & FAQs 6 02-01-2010 03:52 PM
ecu flash cant read elevenpoint7five Open Source Reflashes 2 07-22-2009 09:21 PM
Need help, open ECU flash with blow thru N8WRX Open Source Reflashes 35 05-08-2009 04:23 PM
ECU Flash Help!!!!!! Kylar Commercial ECU Reflashes 12 11-27-2007 01:04 PM
