Old 01-07-2008, 06:45 PM   #1
chanders
Member#: 131319
2003 JDM STI
World Rally Blue
Default Stuttering while knocking
Hey guys,
This is my first foray into tuning etc. Whilst doing a third gear and fourth gear pull, the car felt like it was "missing" or "skipping" and was kinda "jerky" (hope I described that correctly).
I have attached both logs for third and fourth. I can see where there was knocking occurring but I really cant tell why. Any ideas? Thanks!
Sorry for the mix of Metric and Imperial, we're kinda crazy down here
Third Gear
Code:
Time,A/F Sensor #1 (AFR),Coolant Temperature (C),Engine Load (Calculated) (2*g/rev),Engine Speed (rpm),Feedback Knock Correction* (degrees),Fine Learning Knock Correction* (degrees),IAM (Ignition Advance Multiplier)* (raw ecu value),Ignition Timing (Total) (degrees),Injector Duty Cycle (%),Intake Air Temperature (C),Intake VVT Advance Angle Left (degrees),Intake VVT Advance Angle Right (degrees),Knock Correction Advance (degrees),Manifold Relative Pressure (Corrected) (psi),Mass Airflow (g/s),Primary Wastegate Duty Cycle (%),Throttle Opening Angle (%),Vehicle Speed (kph),Knock Signal 1 (On/Off)
0,15.16,89,1.14,1316,0.00,0.00,16,30.00,3.93,42,7.00,7.00,0.00,-4.93,12.33,20.00,6.27,22,0
281,14.81,90,1.96,1352,0.00,0.00,16,30.00,5.19,42,8.00,7.00,0.00,-2.76,22.05,25.88,16.86,22,0
578,12.86,90,1.82,1438,0.00,0.00,16,29.00,6.44,42,11.00,13.00,7.00,-0.15,22.01,32.94,40.00,22,0
859,14.13,90,1.87,1507,0.00,0.00,16,29.50,7.07,42,15.00,21.00,9.50,0.29,23.48,39.22,61.18,24,0
1141,13.44,90,1.88,1606,0.00,0.00,16,30.50,7.79,42,22.00,30.00,11.50,0.58,25.39,47.84,75.29,24,0
1437,13.55,90,1.95,1692,0.00,0.00,16,30.50,8.30,41,27.00,40.00,13.50,0.73,28.31,56.08,78.43,25,0
1719,12.40,90,2.04,1769,0.00,0.00,16,31.00,9.06,41,36.00,45.00,15.00,1.16,30.02,70.20,99.22,25,0
2047,12.98,90,2.07,1898,0.00,0.00,16,32.00,9.72,41,45.00,45.00,16.00,1.31,32.14,82.75,100.00,28,0
2328,12.63,90,2.12,2028,0.00,0.00,16,32.00,10.56,41,45.00,45.00,16.00,1.60,35.36,89.80,100.00,30,0
2609,12.86,90,2.07,2089,0.00,0.00,16,33.00,11.14,41,46.00,45.00,16.00,1.89,35.97,89.80,100.00,30,0
2906,12.98,90,2.09,2174,0.00,0.00,16,33.00,11.60,41,45.00,44.00,16.00,2.03,37.88,89.80,100.00,32,0
3187,12.98,90,2.12,2285,0.00,0.00,16,33.50,12.67,41,45.00,44.00,16.00,2.32,41.57,89.80,100.00,35,0
3484,13.32,90,2.18,2410,0.00,0.00,16,34.00,13.37,41,46.00,45.00,16.00,2.61,43.81,89.80,100.00,35,0
3766,13.09,90,2.27,2521,0.00,0.00,16,34.00,14.95,41,44.00,45.00,16.00,2.90,46.22,89.80,100.00,38,0
4047,12.86,90,2.45,2628,0.00,0.00,16,34.00,15.69,41,45.00,45.00,16.00,3.34,51.09,89.80,100.00,38,0
4344,13.21,90,2.43,2749,0.00,0.00,16,34.00,17.01,41,46.00,45.00,16.00,3.92,55.74,89.80,100.00,42,0
4625,12.86,90,2.65,2894,0.00,0.00,16,33.00,19.14,40,46.00,45.00,16.00,4.35,63.66,87.45,100.00,44,0
4922,12.52,90,2.75,3048,0.00,0.00,16,33.00,21.46,40,45.00,45.00,16.00,5.37,69.74,83.92,100.00,44,0
5203,12.29,90,2.90,3184,0.00,0.00,16,33.00,24.09,40,45.00,45.00,16.00,6.38,76.35,81.96,100.00,48,0
5500,12.06,90,3.12,3383,0.00,-1.05,16,30.50,28.14,40,46.00,45.00,15.00,7.69,89.51,79.22,100.00,48,0
5781,11.48,90,3.54,3407,0.00,-1.05,16,28.00,31.98,40,46.00,45.00,15.00,10.01,100.43,76.86,100.00,51,0
6062,11.25,90,3.95,3718,0.00,-3.52,16,22.00,39.76,40,46.00,45.00,12.50,12.62,131.33,74.90,100.00,56,0
6359,11.25,90,4.48,3856,0.00,0.00,16,22.50,51.00,39,45.00,44.00,14.00,17.27,146.62,74.90,100.00,56,0
6641,11.25,90,4.72,4047,0.00,-5.27,16,19.50,56.99,39,45.00,44.00,10.00,19.73,159.25,77.25,100.00,60,0
6937,11.25,90,4.78,4348,0.00,-5.27,16,16.50,57.50,39,45.00,44.00,9.50,20.02,160.73,79.22,100.00,60,0
7219,11.37,90,4.57,4723,0.00,-4.92,16,26.00,60.45,39,42.00,42.00,14.00,19.15,179.68,82.35,100.00,66,0
7516,11.25,90,4.81,4896,0.00,-4.92,16,22.00,66.11,38,38.00,38.00,8.00,19.88,189.10,85.88,100.00,72,0
7797,11.25,90,4.67,5102,0.00,-3.87,16,23.50,68.57,38,35.00,35.00,8.00,19.15,200.97,89.80,100.00,72,0
8078,11.25,90,4.57,5392,0.00,-3.87,16,22.50,71.31,38,29.00,31.00,6.00,18.57,205.23,89.80,100.00,79,0
8375,11.25,90,4.66,5576,0.00,0.00,16,24.00,73.75,38,27.00,28.00,8.00,18.43,216.61,89.80,100.00,86,0
8672,11.25,90,4.63,5846,0.00,0.00,16,25.00,77.32,38,26.00,27.00,8.00,18.14,225.70,89.80,100.00,86,0
8953,11.25,90,4.48,6073,0.00,-2.11,16,23.00,77.73,37,21.00,23.00,6.00,17.41,226.95,89.80,100.00,93,0
9234,11.25,90,4.44,6308,0.00,-2.11,16,25.50,78.05,37,19.00,20.00,8.00,16.98,233.15,89.80,100.00,93,0
9531,11.25,90,4.35,6482,0.00,-2.11,16,27.00,78.82,37,8.00,10.00,10.00,16.25,234.84,89.80,100.00,100,0
9812,11.25,90,4.20,6690,0.00,-2.11,16,30.50,77.87,37,10.00,13.00,12.00,16.11,232.32,89.80,100.00,106,0
10109,11.25,90,4.07,6893,0.00,0.00,16,33.00,79.41,37,12.00,13.00,16.00,16.25,234.00,89.80,100.00,106,0
10391,11.25,90,4.02,7042,0.00,0.00,16,34.00,78.12,36,8.00,9.00,16.00,16.40,236.14,89.80,100.00,112,0
10672,11.25,90,3.92,7267,0.00,0.00,16,34.50,78.37,36,4.00,5.00,16.00,16.25,234.60,89.80,100.00,112,0
10969,11.25,91,3.83,7470,0.00,0.00,16,34.50,79.68,36,4.00,7.00,16.00,16.54,238.45,89.80,100.00,117,0
11250,11.25,91,3.76,7545,0.00,0.00,16,34.50,78.87,36,3.00,4.00,16.00,16.40,236.28,89.80,100.00,123,0
11547,11.25,91,3.63,7804,0.00,0.00,16,35.00,79.92,36,3.00,4.00,16.00,16.40,235.85,89.80,100.00,123,0
11828,11.25,91,3.60,7828,0.00,0.00,16,36.00,78.49,35,5.00,9.00,16.00,16.40,234.60,89.80,100.00,128,0
12109,11.25,91,0.34,7812,0.00,0.00,16,27.50,0.00,35,8.00,9.00,0.00,-1.74,22.27,0.00,0.00,128,0
12406,15.85,91,0.33,7075,0.00,0.00,16,11.50,0.00,35,3.00,5.00,0.00,-9.43,19.50,0.00,0.00,132,0
12687,25.27,91,0.40,6260,0.00,0.00,16,28.00,0.00,35,4.00,4.00,0.00,-10.16,21.12,0.00,0.00,135,0
12984,24.69,91,0.43,5514,0.00,0.00,16,28.00,0.00,35,3.00,5.00,0.00,-10.30,20.70,0.00,0.00,135,0
Fourth Gear
Code:
0,14.59,92,0.94,1840,0.00,0.00,16,36.50,4.71,36,2.00,3.00,0.00,-6.38,14.58,20.00,6.67,31,0
281,14.47,92,0.96,1862,0.00,0.00,16,36.50,4.78,36,3.00,4.00,0.00,-6.24,14.99,20.00,6.67,30,0
578,14.24,92,0.96,1879,0.00,0.00,16,36.50,4.81,36,3.00,4.00,0.00,-6.24,15.05,20.00,6.67,31,0
875,14.24,92,0.94,1915,0.00,0.00,16,36.50,4.90,36,3.00,4.00,0.00,-6.24,14.99,20.00,7.06,31,0
1156,14.47,92,0.97,1928,0.00,0.00,16,36.50,4.94,36,3.00,4.00,0.00,-6.09,15.35,20.00,7.06,32,0
1437,13.55,92,1.13,1976,0.00,0.00,16,37.00,5.90,36,5.00,6.00,0.00,-4.64,18.53,20.00,9.80,32,0
1734,14.24,92,1.15,2006,0.00,0.00,16,37.00,5.94,36,9.00,10.00,0.00,-4.64,19.57,20.00,9.80,33,0
2015,14.01,92,0.83,2027,0.00,0.00,16,37.50,4.32,36,9.00,11.00,0.00,-7.40,8.82,0.00,0.00,34,0
2297,13.21,92,0.37,1941,0.00,0.00,16,25.00,0.00,36,6.00,6.00,0.00,-10.16,5.95,0.00,0.00,34,0
2594,23.20,92,0.45,1553,0.00,0.00,16,21.00,0.00,36,2.00,3.00,0.00,-10.30,10.50,20.00,4.71,34,0
2875,13.44,92,1.86,1737,0.00,0.00,16,9.50,7.04,36,2.00,2.00,0.00,-2.61,26.95,26.27,17.25,34,0
3172,12.63,92,1.89,1632,0.00,0.00,16,30.50,8.20,36,10.00,17.00,9.00,0.00,26.44,39.22,34.90,35,0
3453,13.32,92,2.00,1674,0.00,0.00,16,23.00,8.21,36,16.00,27.00,13.00,0.73,26.74,45.49,68.63,35,0
3734,13.32,92,2.00,1708,0.00,0.00,16,30.50,8.74,36,23.00,42.00,15.00,1.16,28.42,58.04,100.00,35,0
4031,12.63,92,2.11,1772,0.00,0.00,16,31.00,8.74,36,31.00,46.00,15.50,1.31,30.45,70.20,100.00,36,0
4328,13.09,92,2.09,1809,0.00,0.00,16,31.00,9.65,36,41.00,45.00,16.00,1.60,31.46,82.35,100.00,38,0
4609,12.40,92,2.03,1891,0.00,0.00,16,31.50,9.89,36,47.00,45.00,16.00,1.89,32.72,89.80,100.00,38,0
4890,12.52,92,2.11,1938,0.00,0.00,16,31.50,10.33,36,45.00,45.00,16.00,2.03,34.27,89.80,100.00,40,0
5187,12.86,92,2.17,1977,0.00,0.00,16,32.00,10.97,36,45.00,45.00,16.00,2.32,35.72,89.80,100.00,40,0
5469,12.86,92,2.10,2056,0.00,0.00,16,32.50,10.96,36,46.00,45.00,16.00,2.47,36.69,89.80,100.00,42,0
5765,13.09,92,2.21,2117,0.00,0.00,16,32.50,11.74,36,45.00,45.00,16.00,2.61,39.02,89.80,100.00,44,0
6047,12.52,92,2.21,2188,0.00,0.00,16,33.00,12.06,36,45.00,45.00,16.00,2.90,39.01,89.80,100.00,44,0
6328,12.52,92,2.17,2263,0.00,0.00,16,33.00,12.55,36,45.00,44.00,16.00,3.05,41.71,89.80,100.00,46,0
6625,12.52,92,2.24,2310,0.00,0.00,16,33.00,13.30,35,45.00,44.00,16.00,3.19,43.21,89.80,100.00,46,0
6906,12.52,92,2.34,2402,0.00,0.00,16,33.50,13.97,35,45.00,44.00,16.00,3.48,46.25,89.80,100.00,49,0
7203,12.75,92,2.36,2437,0.00,0.00,16,33.50,14.56,35,45.00,45.00,16.00,3.77,48.03,89.80,100.00,51,0
7484,12.52,92,2.50,2506,0.00,0.00,16,33.00,15.50,35,44.00,45.00,16.00,4.06,52.16,89.80,100.00,51,0
7765,12.63,92,2.52,2604,0.00,0.00,16,33.00,16.67,35,45.00,45.00,16.00,4.50,55.53,89.80,100.00,53,0
8062,12.86,92,2.62,2658,0.00,0.00,16,33.00,17.58,35,45.00,45.00,16.00,4.93,58.14,89.80,100.00,53,0
8344,12.75,92,2.69,2734,0.00,0.00,16,32.00,18.66,35,45.00,45.00,16.00,5.51,62.93,89.80,100.00,56,0
8640,12.63,92,2.78,2802,0.00,0.00,16,31.50,20.33,35,46.00,45.00,16.00,6.09,67.39,89.80,100.00,59,0
8922,12.17,92,2.97,2901,0.00,0.00,16,31.00,22.28,35,45.00,45.00,16.00,6.96,71.80,86.67,100.00,59,0
9219,12.06,92,3.12,2992,0.00,-1.05,16,29.50,24.77,35,46.00,45.00,15.00,7.69,80.54,84.71,100.00,62,0
9500,11.94,92,3.41,3110,0.00,-1.05,16,29.50,27.87,35,46.00,46.00,15.00,9.14,88.27,83.14,100.00,65,0
9781,11.83,92,3.61,3210,0.00,-3.52,16,26.00,30.21,35,46.00,45.00,12.50,10.74,99.47,81.57,100.00,65,0
10078,11.25,92,3.88,3312,0.00,-3.52,16,23.00,36.75,35,46.00,45.00,12.50,13.49,112.25,80.00,100.00,68,0
10375,11.25,92,4.57,3438,0.00,-1.76,16,21.00,43.28,34,45.00,45.00,14.00,16.25,130.82,78.04,100.00,68,0
10656,11.25,92,4.94,3564,0.00,-2.11,16,19.00,51.71,34,46.00,45.00,14.00,19.15,146.96,76.47,100.00,72,0
10953,11.25,93,4.99,3651,0.00,-4.22,16,19.00,54.53,34,45.00,44.00,11.50,20.46,151.95,75.69,100.00,76,0
11250,11.25,93,4.90,3916,0.00,-4.92,16,19.00,55.36,34,45.00,45.00,11.00,20.75,155.00,74.90,100.00,76,0
11515,11.25,93,4.76,4030,0.00,-4.92,16,19.00,56.74,34,45.00,44.00,10.50,20.60,162.48,75.69,100.00,80,0
11812,11.25,93,4.73,4202,0.00,-4.57,16,18.00,58.26,34,45.00,44.00,11.00,20.89,165.72,76.08,100.00,80,0
12094,11.25,93,4.81,4230,0.00,-4.57,16,18.00,60.43,34,44.00,44.00,10.50,20.60,175.54,77.65,100.00,86,0
12390,11.25,93,4.89,4472,0.00,-4.22,16,19.00,62.02,34,42.00,42.00,10.50,20.31,182.21,80.00,100.00,91,0
12672,11.25,93,4.76,4780,0.00,-4.22,16,22.00,62.52,34,43.00,43.00,9.50,20.46,175.21,81.57,100.00,91,0
12953,11.25,93,4.89,4673,0.00,-3.87,16,21.00,61.80,34,39.00,37.00,10.00,20.31,174.86,83.14,100.00,97,0
13250,11.25,93,4.99,4690,0.00,-3.52,16,20.50,68.04,34,40.00,37.00,9.00,20.89,195.02,84.71,100.00,97,0
13531,11.25,93,5.23,5154,0.00,0.00,8,20.00,70.22,34,31.00,31.00,5.50,20.31,206.88,85.88,100.00,101,0
13828,11.25,93,4.89,5088,0.00,0.00,8,20.00,72.72,34,35.00,36.00,6.00,20.46,210.00,89.80,100.00,107,0
14109,11.25,93,4.96,5162,0.00,0.00,8,20.00,73.78,34,34.00,29.00,5.00,19.88,213.13,89.80,100.00,107,0
14390,11.25,93,4.76,5403,0.00,0.00,8,20.50,73.77,33,33.00,34.00,5.00,19.59,214.30,89.80,100.00,112,0
14687,11.25,93,4.81,5490,0.00,0.00,8,20.00,77.43,33,31.00,31.00,4.00,19.59,223.34,89.80,100.00,117,0
14969,11.25,93,4.78,5664,0.00,0.00,8,19.50,76.47,33,28.00,28.00,3.50,19.59,228.76,89.80,100.00,117,0
15265,11.25,93,4.73,5725,0.00,0.00,8,20.00,78.17,33,26.00,27.00,3.50,19.15,227.10,89.80,100.00,121,0
15547,11.25,93,4.66,5891,0.00,0.00,8,20.00,77.56,33,27.00,27.00,3.50,19.01,228.71,89.80,100.00,121,0
15828,11.25,93,4.67,6004,0.00,0.00,8,20.00,79.42,33,22.00,22.00,3.50,18.57,233.77,89.80,100.00,125,0
16125,11.25,93,4.57,6097,0.00,0.00,8,20.00,79.28,33,20.00,22.00,3.50,18.14,230.83,89.80,100.00,130,0
16406,11.25,93,4.49,6276,0.00,0.00,8,21.50,80.33,33,18.00,18.00,4.00,17.70,235.02,89.80,100.00,130,0
16703,11.25,93,4.51,6308,0.00,0.00,8,21.50,79.39,33,19.00,20.00,4.50,17.85,237.16,89.80,100.00,134,0
16984,11.25,93,4.44,6372,0.00,0.00,8,21.50,78.84,32,15.00,16.00,4.50,17.56,235.85,89.80,100.00,134,0
17281,11.25,93,4.40,6573,0.00,0.00,8,23.00,81.33,32,16.00,16.00,5.50,17.27,239.32,89.80,100.00,139,0
17562,11.25,93,4.30,6614,0.00,0.00,8,23.50,80.42,32,14.00,14.00,6.50,16.98,239.76,89.80,100.00,143,0
17859,11.25,93,4.31,6702,0.00,0.00,8,24.00,80.07,32,13.00,13.00,7.00,17.12,238.89,89.80,100.00,143,0
18140,11.25,93,4.22,6880,0.00,0.00,8,25.00,80.43,32,12.00,12.00,7.00,17.12,243.19,89.80,100.00,147,0
18437,11.25,93,4.21,6880,0.00,0.00,8,25.00,80.73,32,8.00,8.00,7.50,16.98,241.51,89.80,100.00,147,0
18719,11.25,93,4.17,6976,0.00,0.00,8,25.00,80.37,32,6.00,7.00,7.50,16.83,242.38,89.80,100.00,150,0
19000,11.25,94,4.02,7143,0.00,0.00,8,26.00,79.24,32,9.00,10.00,8.00,16.98,235.85,89.80,100.00,154,0
19297,11.25,94,3.97,7136,0.00,0.00,8,26.00,79.16,32,10.00,10.00,8.00,17.56,236.28,89.80,100.00,154,0
19578,11.25,94,4.00,7253,0.00,0.00,8,25.50,79.75,32,7.00,8.00,8.00,17.41,238.01,89.80,100.00,157,0
19875,11.25,94,3.88,7382,0.00,0.00,8,26.00,80.31,32,7.00,8.00,8.00,17.27,238.45,89.80,100.00,161,0
20156,11.25,94,3.97,7346,0.00,0.00,8,26.00,81.49,32,9.00,8.00,8.00,17.70,242.82,89.80,100.00,161,0
20453,11.25,94,3.79,7530,0.00,0.00,8,26.00,80.32,32,10.00,9.00,8.00,17.56,238.45,89.80,100.00,163,0
20734,11.25,94,3.77,7606,0.00,0.00,8,26.50,81.13,32,8.00,9.00,8.00,17.70,238.88,89.80,100.00,163,0
21031,11.25,94,2.78,7583,0.00,0.00,8,28.50,3.24,32,8.00,9.00,0.00,6.67,175.48,43.92,0.00,167,0
chanders is offline   Reply With Quote
Old 01-07-2008, 07:42 PM   #2
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
You should post your car info, mods, tune info, etc...
In my opinion, you're trying to run too much timing and the car doesn't like it.
The knock may or may not be in your logs because most of the timing is being pulled using fine learning knock correction. So, the knock may be here or may have happened when you did a partial throttle drive.
Your 4th gear log, something bad happened between time 12672 and 13531. RPMs actually dropped quite a bit and your IAM dropped from 16 to 8.
mickeyd2005 is offline   Reply With Quote
Old 01-07-2008, 07:46 PM   #3
chanders
Member#: 131319
2003 JDM STI
World Rally Blue
^^ Thanks
Car is a Prodrive Edition 2002 JDM STI EJ207 V7
Only mod really is full decatted turbo-back 3.5" Kakeemotor exhaust
Help! Clunking/stuttering/binding when turning while warmed up NeoteriX Brakes, Steering & Suspension 31 02-17-2015 10:32 AM
5MT mystery... skipped/stuttered for a while, now it's fine spaceywilly Transmission (AT/MT) & Driveline 7 01-19-2009 10:30 PM
engine stutter while idling Jason Temple Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-14-2003 05:57 PM
Stutter while drifting? DDMan Brakes, Steering & Suspension 10 09-03-2002 12:43 PM
does anyone else feel/hear a knock while shifting into 2nd SWEETWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-29-2001 04:04 PM
