Old 01-07-2008, 10:26 PM   #1
keirnna
Member#: 50167
1996 Subaru STI RA
Default EJ20K V4 STI heads + EJ257 US STI SB any issues?
Will my EJ20K V4 STI heads successfully bolt to a US STI EJ257 SB? What will the compression ratio be? I have been searching, but I haven't seen many people do this. Thanks in advance. Links and information would be wonderful.
keirnna is offline   Reply With Quote
Old 01-07-2008, 10:32 PM   #2
keirnna
Member#: 50167
1996 Subaru STI RA
Found this info:
http://forums.nasioc.com/forums/show...ht=ej20k+heads
Looks like it will be good. If there is more information I would love to have it. Thanks!
Old 01-16-2008, 03:38 AM   #3
Legacy_Turbo
Member#: 125633
Heads will physically bolt on without issues. They are the same casting as EJ25 DOHC heads which are popular on hybrids. Also, heads are more like 49cc.
You`ve got yourself the best heads for a phase I engine.
Legacy_Turbo is offline   Reply With Quote
Old 01-16-2008, 12:22 PM   #4
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
With 0.58 mm gasket thickness (11044AA641) your CR will be 9.0.
With 1.37 mm gasket thickness (11044AA610) your CR will be 8.4.
That's based on 47cc for the EJ20K heads (clover-style combustion chamber).
Marnix is offline   Reply With Quote
Old 07-11-2015, 11:27 PM   #5
binny
Member#: 198108
MY98 WRX
I'm about to do this conversion how accurate are these CR #'s ? I've been reading that the EJ20K heads will give higher #'s ?
binny is offline   Reply With Quote
Old 07-11-2015, 11:38 PM   #6
binny
Member#: 198108
MY98 WRX
Actually with a 255 block and pistons so CR would be "lower" than these #'s
FS, MO- EJ257 US STi short block NIB $1,650 + ship MJU1983 Engine/Power/Exhaust 12 02-12-2008 06:32 PM
FS: 2005 STI heads EJ257 AVCS decked & checked $850 OBO ten80 Engine/Power/Exhaust 1 01-31-2008 11:48 AM
05 sti I link on 05 wrx any issue??? craver Brakes, Steering & Suspension 0 04-18-2006 02:49 AM
JDM V7 STi heads vs. non-STi heads sheikthin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 10-02-2005 10:51 PM
Ver8 STi gead vs US STi head? NORCAL STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 58 12-09-2004 07:33 AM
