Old 01-08-2008, 12:40 AM   #1
Vizzionz
Member#: 139109
2007 Impreza 2.5i
Crystal Gray Metallic
Default WRX CAI on my 07 2.5i
i got a AEM WRX CAI off ebay about 8months back, installed it, used the "build your own intake" pieces from spectre. here is the out come of the WRX/2.5i hybrid intake.
Vizzionz is offline   Reply With Quote
Old 01-08-2008, 12:47 AM   #2
1337Impreza
Member#: 151432
1998 2.5 RS
Arcadia Green Machine
Thats pretty cool. Has alot of bends though nonethe less Good job looks good
1337Impreza is offline   Reply With Quote
Old 01-08-2008, 12:52 AM   #3
Vizzionz
Member#: 139109
2007 Impreza 2.5i
the red piping is the WRX pieces, the chrome ones are the spectre pieces in order to make it all work together [i noticed a improvement on low end torque]
Old 01-08-2008, 02:15 AM   #4
banjabi
Member#: 119385
GDA
i like how you're trying new mods. lookin good bro.
banjabi is offline   Reply With Quote
Old 01-08-2008, 07:47 PM   #5
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
An improvement in low end torque? I have only heard of low end losses with just about any CAI setup that loses the factory airbox. Anyone have insight into a low end torque gain with a CAI? I would love to get my low end back and keep my high end gains with my CAI if its a matter of setup or addition of something. Looks good, BTW. suprisingly clean for a franken-intake.
GrundleJuice is online now   Reply With Quote
Old 01-09-2008, 10:22 AM   #6
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
Is the filter itself in sitting in the fender well?
What air does it pull from? Engine or outside (I see fender holes to the engine bay)?
Jerry Xu is offline   Reply With Quote
Old 01-09-2008, 12:00 PM   #7
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
You've got a bend on either side of the MAF .. and the piping is sized for a different MAF. Two wrongs don't make a right. Even most WRX owners who've read anything on this site know better than to throw those on a WRX due to the way it screws up the MAF reading.
Sell the WRX intake and buy a cheap intake from Ebay and a MAF adapter. Trying new things is cool.. but throwing stuff together and making something bad work just to be different isn't.
Old 01-09-2008, 05:36 PM   #8
EvoSpeed
Member#: 155430
2008 Nissan
SE-R Spec V
Dont listen to them i bet that runs fine on the 2.5i. I agree too many bends witch probably affect the sound and performance slightly but its original. Good DIY.
EvoSpeed is offline   Reply With Quote
Old 01-09-2008, 06:18 PM   #9
Vizzionz
Member#: 139109
2007 Impreza 2.5i
lets see, if AEM tested thier intakes on a WRX, then i assuming it WORKS! [isn't that why major companies send thousands of dollars on R&D for?] (the intake i have is a TRUE AEM piece, i'll use that before i use any cheapo intake off ebay, the other pieces are from spectra)
oh yeah, and if you look at ANY CAI for a WRX/STi, you know damn well there will be bends before and after the MAF sensor to make it work for the fender opening! the only intake that does NOT have a bend is a Short Ram style intake!
i have yet to throw any CEL's in my car from the mods i've done. so apparently, i must be doing some thing right....
Old 01-09-2008, 06:19 PM   #10
Vizzionz
Member#: 139109
2007 Impreza 2.5i
i might take out the WRX MAF pipe and swap over to a spectra 4" maf pipe... [which will take 2 bends out of the piping ]
Old 01-09-2008, 06:24 PM   #11
EvoSpeed
Member#: 155430
2008 Nissan
SE-R Spec V
In general, try to keep all piping about the same diameter. Or at least start big then go smaller and not back and forth big and small. It wont matter that much just telling whats optimal.
Nothing you slap on there is going to cause a CEL unless u mess with the MAF itself or the MAP. Go ahead and mess with different setups. I tried like 4 or 5.
Old 01-09-2008, 06:34 PM   #12
Vizzionz
Member#: 139109
2007 Impreza 2.5i
i've messed with the MAF it self and throw a couple of codes, nothing like having a OBD2 scaner handy
Old 01-09-2008, 11:27 PM   #13
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
That would be fine and dandy IF you drove a WRX, which, according to your profile over <-- thar, you don't.
Counterfit is offline   Reply With Quote
Old 01-09-2008, 11:43 PM   #14
Vizzionz
Member#: 139109
2007 Impreza 2.5i
well the stock WRX intake maf pipe & the stock 2.5i maf pipe is the same size internaly, so you do the math
Old 01-11-2008, 10:10 PM   #15
code_hat
Member#: 90896
CO RallyX'er
circuitmotorsports.net
You use too many smiley faces. I swear, it's almost every post.
code_hat is offline   Reply With Quote
Old 01-12-2008, 12:29 AM   #16
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
hes a happy dude, besides thats an obvious and poorly masked attempt to change the subject. but regardless, the WRX and 2.5i intakes being the same diamater hardly make the intake design similar. One being forced induction makes so many other variables relevant that you cant even compare the two... its apples and pork chops.
Old 01-12-2008, 02:16 AM   #17
Vizzionz
Member#: 139109
2007 Impreza 2.5i
would you rather me be a complete ass and all emo?
Old 01-12-2008, 05:37 AM   #18
Counterfit
Member#: 124254
"The Scoobinator"
Mmmm, pork chops with applesauce... *drool*
Old 01-14-2008, 11:32 AM   #19
EvoSpeed
Member#: 155430
2008 Nissan
SE-R Spec V
I agreee with this. I also agree with the OP that he got the WRX intake "to work" on our NA which is what he was trying to do. It "functions" as an intake and probably improves top end air flow over stock. But no, your right its not an optimal setup.
Installing UEL WRX header on 06/07 2.5i impreza Vizzionz Normally Aspirated Powertrain 99 10-24-2014 08:54 PM
Is it worth putting STI springs on my 07 2.5i? Buktheng Impreza Forum 14 06-06-2009 09:27 PM
Will this fit on my 07 2.5i? DJNA Newbies & FAQs 2 10-01-2008 03:29 AM
Yeah, the brakes on my 07 2.5i suck zoltan Brakes, Steering & Suspension 11 10-08-2007 05:51 PM
05 wrx sideskirts on my 06 2.5i LandoCommando Interior & Exterior Modification 3 04-09-2007 07:49 PM
