Old 01-08-2008, 04:25 PM   #1
team trucha racing
Member#: 118484
04 sti RotatedGT35
wrb harman motive tunned
Default mustang dyno #'s to dynojet #'s
i have an 04 sti stage 2. mod's are ti-tek catless d/p, blitz nur spec catback, hks u/p,perrin equal lengthe header, aem cai,re-circulated greddy type-s bov,perrin stock inlet, acessport v2, was tuned a while back @ harman motive on they're new mustang dyno and the car made 273whp and 293wtq on 91 oct. and 291whp and 309wtq on 95 oct. i want to know what kind of power i would have made on a dynojet with those number's.if there is a formula for that. just curious so if someone can help i would appreciate it. thanks.....
-Rob
team trucha racing is offline   Reply With Quote
Old 01-08-2008, 04:28 PM   #2
PowerTrip
Member#: 158674
'15 STi Limited
I think Harman's Mustang reads about 12% lower than their old Dynojet. For reference my old '06 STI with just a Cobb TBE dynoed around 262/284 on Harman's Mustang.
PowerTrip is offline   Reply With Quote
Old 01-08-2008, 05:06 PM   #3
Farnk
Member#: 91093
2002 Wrx
I've wanted a formula for that for months. Best I could come up with was that its about 12-15% lower than a dynojet which is still just a guess. And imo seems to be too much.
Farnk is offline   Reply With Quote
Old 01-08-2008, 05:26 PM   #4
team trucha racing
Member#: 118484
04 sti RotatedGT35
thats what i fugured about 15% so im probably making around 312whp and 336wtq dynojet power.
Old 01-08-2008, 06:29 PM   #5
PowerTrip
Member#: 158674
'15 STi Limited
It's closer to 12%...
Old 01-08-2008, 07:34 PM   #6
cpturbo
Member#: 49175
2004 STI
When are you people going to realize that a dyno is a TOOL not a gonadal measuring stick? Area under the curve from one tune to the next is all that matters as well as safety within that tune. If you want to compare your car to other cars, then take it to a track and settle it there. Many with less hp power on dyno A have whipped the fan boy on dyno B.
cpturbo is offline   Reply With Quote
Old 01-08-2008, 07:44 PM   #7
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
You're no fun anymore.
Dave D. is offline   Reply With Quote
Old 01-08-2008, 09:32 PM   #8
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
There is no formula. Each dyno reads different and has different weight rollers. You can make any dyno read what you want it to read by altering it.
Clark
AZScoobie is offline   Reply With Quote
Old 01-08-2008, 09:36 PM   #9
Paintballguy
Member#: 77810
2006 Evo IX SE
Tarmac Black
Clark
Which is why people shouldn't be all upset about dyno numbers.
Run it at the track to get some real numbers that mean something.
Paintballguy is offline   Reply With Quote
Old 01-08-2008, 11:19 PM   #10
downsti
Member#: 63179
2006 Stock Turbo STi
[email protected] VF39
Clark
very important stuff
downsti is offline   Reply With Quote
Old 01-09-2008, 06:32 AM   #11
sjl1614
Member#: 56791
06 OBS
I had my car on a Superflow dyno. On SAE numbers, it made 326 awhp & 342 tq. The software on the dyno can convert to dynojet #'s, they are 358 awhp & 376 tq. Dyno jet are known to read about 10-13% higher than the actual power, we can thank Harley for that. I also had the car on a dyno dynamics dyno, there it was 271awhp, didn't get tq #'s since it was a dyno day.
sjl1614 is offline   Reply With Quote
Old 01-09-2008, 08:37 AM   #12
speed industry
Member#: 141485
2002 Porsche 911TT
Arctic silver
I have a Mustang AWD dyno, and know that it will spit out lower numbers than any other dynos around. I also know that it pushes back harder than any other dyno around..that's why there's no street tuning needed after getting tuned on my dyno. I also know that low 300's on my dyno equals a high 11 second Subie, which has been proven...so the numbers are secondary to the robustness of the tune you get.
I'd be happy with those numbers on a Mustang dyno. How does the car drive? Are you happy with the performance?
speed industry is offline   Reply With Quote
Old 01-09-2008, 08:45 AM   #13
wrxhard
Member#: 108091
Exactly, because ultimately, that is ALL that matters.
wrxhard is offline   Reply With Quote
Old 01-09-2008, 10:15 AM   #14
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
I would just stick with the Mustang Dyno #'s. Makes it more challenging.
tux121 is offline   Reply With Quote
Old 01-09-2008, 12:51 PM   #15
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
First, you should not be using SAE corrections. See http://forums.nasioc.com/forums/showthread.php?t=873912 for a detailed explanation why.
Second, the Mustang as well as many other loading dynos can adjust the length of the pull to suit the tuner. You can make the Mustang run faster by reducing the load, and effectivly get close to the ramp time of the dynojet ( the closeness depends on which rollers you have). You can also make the pull take 15 seconds, or 200 seconds. As well, you can also use the simulation mode to add more drag at higher RPMS but less drag at lower RPMs in an attempt to simulate real road drag.
The most important thing is to pick one ramp time/rate for all tuning of the same car, so you can get an accurate reading of what changed. I personally prefer the target run time config, as it makes reading very consistant pull to pull. If your dyno operator doesn't understand what the "Vehicle Simulation" selection on the Mustang dyno does, you should be concerned. A professional should know his tools, and know them well.
Cheers,
Jeff Sponaugle
sponaugle is offline   Reply With Quote
Old 01-09-2008, 02:11 PM   #16
4SFED4
Member#: 88682
+ whatever it takes.
A chassis dynomometer is a comparitive tool, not an absolute one. Even dyno results for the same car performed on different days cannot be empiracally compared as fluctuations in the weather will result in differences. If you think the "correction" factor is 100% accurate and will correct for temeprature/humidity etc... well, it doesn't, not perfectly anyway. Also... it has been shown that how a car is strapped down can affect results. So... make your changes, make a pull... it is better or worse? Repeat until you have reached the maximum amount of power you are willing to make for a given octane and safety threshold.
If one wants to believe one has more horsepower so one can compare oneself to what others have than you need the type of help that is not regulary and readily availale on this forum!
4SFED4 is offline   Reply With Quote
Dynojet vs Mustang Dyno Jhovany Proven Power Bragging 13 11-02-2009 09:36 PM
Dailydevil dynoes does decent on Mustang dyno. reddevil Proven Power Bragging 7 09-25-2009 08:40 PM
dynojet vs mustang dyno? kooklie Newbies & FAQs 3 07-22-2009 05:43 AM
Latest dyno results: 145hp, 144ft-lb on Mustang dyno Patrick Olsen Normally Aspirated Powertrain 39 08-27-2008 03:19 AM
mustang dyno power #s vs. dynojet power #s bigworm Proven Power Bragging 15 08-07-2005 09:52 PM
