Old 01-08-2008, 10:15 PM   #1
Minorityairsoft
Member#: 168577
2002 18g Wrx
Wrb
Default Cracked Cylinder Head
I had my block replaced due to a thrown rod, by SUBARU. 8,000 miles later I now have a cracked head. Subaru scanned my car and revealed that I had a PO171 code, Exhaust running lean, and a PO546 code, Exhaust temperature sensor. I have a cat before the sensor. My question is, can either of these codes lead to a cracked head in any way? My theory is that the exhaust running lean code is because the engine is lean causing extreme temperatures in my engine which explains the exhaust temp code. Extreme temperatures cause cracked head?
Minorityairsoft is offline   Reply With Quote
Old 01-08-2008, 10:27 PM   #2
Haelan
Member#: 151045
2013 Subaru STI
CBP
Detonation from too lean of an air/fuel mixture probably cracked your head--much higher explosive force than normal. But you're right, that detonation causes much higher exhaust gas temps. If it was running extremely lean for awhile it could have burned up your EGT probe causing the P0546.
Haelan is offline   Reply With Quote
Old 01-08-2008, 10:50 PM   #3
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Are you saying you did not have a CEL come on?
What year/miles of car please.
surowrxa is offline   Reply With Quote
Old 01-08-2008, 11:34 PM   #4
Minorityairsoft
Member#: 168577
2002 18g Wrx
Wrb
2002 Wrx, 88,000 mi.
Old 01-08-2008, 11:37 PM   #5
Minorityairsoft
Member#: 168577
2002 18g Wrx
Wrb
I had the cel on and went to the dealership and they told me about two codes,exhaust temp and a MAF code due to my aftrmkt cai, and it was prolly just a dirty sensor. My MAF code went away. Basically telling me nothing to much to worry about and i went along with my business keeping that in the back of my head as something to fix. Then i took my car back in after cracking the head where they told me i had another code that was an exhaust lean warning. All of this was after the dealership installed my new block. There were no CEL's before they replaced my block.
Old 01-09-2008, 10:07 AM   #6
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Ah, I see. You did not know about the PO171 because the light was on for other codes previous. That sucks, because that's a code/problem you wouldn't be driving around with.
WRX '02 Cylinder Heads cracked - any suggestions? CompuPsych Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 10-31-2009 04:53 PM
Cylinder head cracks kingsubi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-09-2007 12:55 PM
minor cracks in head, would you use these heads? 3fordasho Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-15-2006 05:00 AM
cracked cylinder heads- how common? 3fordasho Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-07-2006 03:29 PM
I can find RH cylinder heads all day long, but no LH heads, sheesh! RiftsWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-07-2003 10:19 AM
