Old 01-09-2008, 01:57 PM   #1
ejh25
Member#: 65267
Default AC Removal/ Delete
Can anyone point me to a DIY AC delete or removal?
I tried searching and pulled up a lot of irrelevant stuff.
Thanks,
Eric
Update:
Did some more searching: http://forums.nasioc.com/forums/show...6#post20673576
ejh25 is offline   Reply With Quote
Old 01-09-2008, 02:00 PM   #2
98EJ20
Member#: 163184
98 Swapped Impreza
Red
Just remove everything AC related. Its a seperate belt so you wont need a special belt after
98EJ20 is offline   Reply With Quote
Old 01-09-2008, 02:43 PM   #3
ejh25
Member#: 65267
So what you're saying is just start ripping stuff out?
I can do that. Do I need to worry about any fluids? The refrigerant?
Old 01-09-2008, 03:46 PM   #4
rkramer
Member#: 118209
2015 WRX Limitec
it is possibly toxic, depending on who you ask. take it to a shop and have them drain the system for you.
Are you planning on ever selling or re-installing it? That will dictate how much you actually want to remove.
Old 01-09-2008, 03:56 PM   #5
maddhatteroo7
Member#: 78840
Go to a propper AC shop to have the AC system drained. DO NOT just start cutting lines hoping it will dissapate there's alot of pressure in an AC system which can hurt you. The refrigerant is toxic and you're supposed to legally have it vaccumed out, not just dissapating into the air.
maddhatteroo7 is offline   Reply With Quote
Old 01-09-2008, 04:12 PM   #6
ejh25
Member#: 65267
I'm not concerned about selling the car.
It is on its way to being entirely stripped out.
Thanks for the advice.
- Eric
Old 01-09-2008, 04:12 PM   #7
ejh25
Member#: 65267
I appreciate the advice. Is there a way I can safely drain the system myself?
Thanks,
Eric
Old 01-09-2008, 08:06 PM   #8
JCooper702
Member#: 151669
2005 WTB 05 STi, pst
wtb sti, my car was total
You may be able to rent the equipment to evacuate the system at an auto parts store.
JCooper702 is offline   Reply With Quote
Old 01-09-2008, 09:43 PM   #9
ejh25
Member#: 65267
Thanks.
I may just have a local gas station drain it for me this Saturday. I'm in a big weight savings mode and I like to rip a little bit out every weekend!
It is amazing how different the car feels after what I've done so far.
- Eric
Old 01-09-2008, 10:46 PM   #10
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
[email protected] dd
When in doubt, rip it out. Ive been thinking about doing the same thing, but then I remember the 100+ degree summers in my DD and forget about it. Removing weight = free horsepower
Str8Gone is offline   Reply With Quote
Old 01-09-2008, 11:43 PM   #11
AlboWRX
Member#: 37719
2003 WRX
R134A is no way near to being toxic and destroying the ozone layer. Its actually enviromentally friendly but EPA still wants to see it being disposed of properly. Or else, they wouldnt sell it at any auto parts store without being certified to handle such gases. Im EPA certified to handle these gases and thats how I know.
AlboWRX is offline   Reply With Quote
Old 01-10-2008, 11:37 AM   #12
ejh25
Member#: 65267
Okay so let's just say I want to do this myself and I don't want to rent the required equipment. The liquid refrigerant will just turn to a gas and defuse out as soon as I cause a leak in the system right?
- Eric
Old 01-10-2008, 11:54 AM   #13
Impaled
Member#: 149442
Yes the refrigerant is only liquid under pressure.
Impaled is offline   Reply With Quote
Old 01-10-2008, 12:00 PM   #14
ejh25
Member#: 65267
So wear gloves and don't breath. Got it.
Old 01-10-2008, 12:31 PM   #15
98EJ20
Member#: 163184
98 Swapped Impreza
Red
Removing weight is free hp, so it removing load from the crank pulley Get a Perrin pulley too, nice lil gain for $125
Old 01-10-2008, 01:58 PM   #16
ejh25
Member#: 65267
Thanks for the advice. Rotational weight is key but I think I'll stick with OEM pulley for the time being.
Old 01-12-2008, 06:38 PM   #17
ejh25
Member#: 65267
I deleted my AC today. Everything except the condensor.
The compressor and all the engine bay lines CAN be removed without taking the radiator out.
I decided to vent the A/C refrigerant myself. I cracked open several locations in the system and let the liquid dissapate into a gas. There still was some residual green goo that I tried to cleanup.
The bolts on the bottom of the compressor are difficult to access. The one towards the rear of the car is needs a substantial offset yet a very shallow wrench as there is very little space to get to it. The compressor is heavy and well worth taking out for a race car.
I was able to remove all the lines without hacking anything up what-so-ever. I did realize as I was doing this that this mod would be very hard to reverse. Re-installing the lines would be very difficult with a full engine bay. I had to tug and twist a little bit to get the lines out.
I'm more than happy to answer any qs on this topic for those concerned with weight loss.
I have dropped a substantial amount of weight from the car and it makes a HUGE difference in acceleration and handling. My guess is that I'm right around 2850 lbs w/out driver. My goal is to get it down to 2650. I'll weigh the car when I can.
- Eric
Old 01-13-2008, 04:17 PM   #18
AlboWRX
Member#: 37719
2003 WRX
If you have a handy list of all the stuff that you have taken out it would be helpful. Also, why cant you reverse the mod? You didnt damage any lines so putting it back should be just the reverse?!
Old 01-13-2008, 04:26 PM   #19
ejh25
Member#: 65267
You could reverse the mod but it would be really difficult to get the lines back into place with the motor in the car. It would be a big PITA. I'll adjust what I said previously to incorporate that.
Weight savings so far (I'm missing some stuff and will update more later).
A/C
spare
jack
tools
trunk carpet
trunk surrounds
rear seat
rear door cards
rear speakers
rear deck
under carpet insulation
under dash insulation
center console and armrest
sun visors
coat hangers
ashtray
plastic sheeting underneath all door cards
some under carpet tar
unecessary bolting brackets and associated hardware
fog lights
brake dust shields
Part changes with weight reductions:
TXS TBE
Gruppe-S headers
Wilwood 4 pot front brakes
Aluminum driveshaft
Aluminum control arms
FMIC w/ front bumper beam delete
Old 01-14-2008, 08:42 AM   #20
98EJ20
Member#: 163184
98 Swapped Impreza
Red
Whats your next plans? CF parts?
Old 01-14-2008, 08:50 AM   #21
ejh25
Member#: 65267
Lightweight parts:
lightweight battery
racing buckets
removal of all airbags
aluminum subframe
removal of rear bumper beam
coilovers
alumnium trunk
If the funds become available:
CF doors
Maybe Remove:
stereo
front speakers
wiring for stereo
AC removal DIY sch3838 Newbies & FAQs 3 02-01-2009 08:46 PM
AC removal newsubie05 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-10-2008 12:29 PM
ac removal? scoobydrew06 General Community 2 03-30-2004 07:11 PM
auto AC removal mod? asianboy101 Electrical & Lighting 1 02-01-2004 07:10 AM
AC removal questions jeffg Normally Aspirated Powertrain 25 06-28-2002 10:09 PM
