Old 01-09-2008, 06:46 PM   #1
nono192002
Member#: 135066
2005 wrx sti
Default afr
i did datalogging on my sti on my car and i have question about my afr im getting 14.1 on idle and 11.7 on wot is it normal? or im getting almost 1600 on my egt gauge and im getting 100% on my fuel pump my mod is catted downpipe and 3 inch catback and accessport stage 2w/hwg
nono192002 is offline   Reply With Quote
Old 01-09-2008, 06:56 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
How are you getting the AFRs? 14.1 at idle is richer than it should be, 11.7 is what I usually tune for but if you are logging the stock O2 sensor then neither of those values are correct. Idle should be at 14.7 though.
Old 01-09-2008, 07:54 PM   #3
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
when you idle, give it time, does it come back up to 14.7? maybe after 1-3 minutes?
Wheeler Bement is offline   Reply With Quote
Old 01-09-2008, 08:27 PM   #4
nono192002
Member#: 135066
2005 wrx sti
its stay in 14.1 in long time. i think my o2 sensor is bad cause im getting .05-.06v instead of .02-.04v in idle.
Old 01-09-2008, 09:09 PM   #5
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
not necessarily...the value you read is calculated from the voltage....but the car could really be doing it.
with constant throttle input(idle or crusing) mine always runs rich and then intime will lean out to the target...have not figured it out yet. my trims aren't changing at the time either...so go figure.
Old 01-09-2008, 09:13 PM   #6
nono192002
Member#: 135066
2005 wrx sti
what is your egt temp.?^^
Old 01-09-2008, 09:49 PM   #7
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
is this for me? temps for what, idle, crusie?
see here for something similar...is your car doing this?
http://forums.nasioc.com/forums/show....php?t=1397452
http://forums.nasioc.com/forums/show....php?t=1405039
Old 01-09-2008, 10:05 PM   #8
nono192002
Member#: 135066
2005 wrx sti
did yu figure it out whats wrong with your car?
Old 01-09-2008, 11:54 PM   #9
Tgui
Member#: 44771
Dude, I see 1750F while racing. Sodium filled valves, have some faith. Stage 2 STi here running 22psi.
Tgui is offline   Reply With Quote
Old 01-10-2008, 10:21 AM   #10
JWX
Member#: 28990
What widenand are you guys running?
JWX is offline   Reply With Quote
Old 01-10-2008, 10:22 AM   #11
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
not yet...cleaned the MAF sensor really good last night and still nothing....
apexi afc or hks afr takumi Normally Aspirated Powertrain 5 08-09-2001 06:13 PM
HKS Super-AFR and other fuel Q's Ethan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-09-2001 10:30 AM
Try the HKS Super AFR instead of the the S-AFC it's better. yebokmj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-01-2001 05:50 PM
Any one using a HKS Super AFR? yebokmj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-21-2001 03:51 PM
Anyone using an AFR for Tuning instead of S-AFC? yebokmj Normally Aspirated Powertrain 5 03-20-2001 10:42 AM
