Old 01-10-2008, 01:45 AM   #1
verendia
Member#: 54550
1995 LX
graphite grey
Default EJ20H long block with Ej20g manifold/wiring
As the title states. Im about to do this within the next month since i have to replace my clutch but i am curious how many people have done this. I read a lot of talk but no follow ups. What are the benefits if any? I have a perfect working ej20g non closed deck and i got a deal on a ej20h long block. all i have to do is swap over the manifolds(intake/exhaust) and all sensors and this should work right? will my ej20g ecu get retarted even though im running same turbo and injectors? I jsut want your 2 cents. if you think its not worth it or there in no gain please chime in.
verendia is offline   Reply With Quote
Old 01-10-2008, 06:00 AM   #2
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
No gain, no loss. Just plug the oil and coolant lines on the LH side head.
Marnix is offline   Reply With Quote
Old 01-10-2008, 10:41 AM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
People have been doing this for years as a cheap fix when their tired Ej20G gives up the ghost. It's practically an identical replacement...
Old 01-11-2008, 03:24 AM   #4
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Maybe the EJ20H pistons are a little bit beefier but I don't really remember...
Old 01-11-2008, 11:17 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
I just thought they had a little higher dome for a touch more compression...
Old 01-11-2008, 04:06 PM   #6
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Higher dome = more material = beefier
Old 01-11-2008, 04:09 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
Only if they leave more material behind the dome. I've never had an Ej20H apart below the shortblock state so I don't know. I've seen the dome on them and compared them to the Ej20G's from above, but I haven't ever seen the backside...
Old 01-11-2008, 04:18 PM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
I thought the dish was a bit more shallow on an EJ20H and the pistons a bit heavier, but it's been a few years back since I last built a short block using EJ20H parts.
Old 01-12-2008, 06:11 PM   #9
99WRXEJ20
Member#: 34545
1999 GC8
74f
I have a blown ej20h getting torn apart here soon. Anyone have the specs on ej20g stuff so we could compare? I dont need the info but if someone wants it then...............
99WRXEJ20 is offline   Reply With Quote
Old 04-08-2013, 12:05 PM   #10
luka
Member#: 194742
1993 Impreza WRX JDM
hey guys,
I'm attempting the same conversion, I blew my ej20g and got an ej20h longblock for a hyper cheap price. I'm just about ready to put the motor in the car but was wondering if anyone can clear up what sensors need to be swapped? I've read a lot about the EJ20R Cam/Crank sensors needing to be swapped but I haven't been able to find anything specific for the EJ20H -> EJ20G swap.
some gotcha's that I came across thus far:
1) Oil/Coolant feeds/returns need to be plugged on the one side
2) Coolant (feed I think?) is on the far side of the turbo now instead of directly underneath. anyone have a solution for this? the only thing I can think of is to S a line from the one side to the other.
3) Said coolant line is touching the up-pipe. my only solution is to wrap both the up-pipe and coolant line with heat wrap.
4) metal coolant lines that run from the thermostat behind the timing cover had to be swapped
5) Engine mounts look completely different but appear as if they will fit. I have yet to test it.
If I'm missing anything, any advice/guidance would be greatly appreciated.
Thanks
luka is offline   Reply With Quote
Old 04-08-2013, 12:21 PM   #11
eg33GC
Member#: 206851
56 Belair
Pro Street
re use the coolant stuff from your g.
nothing wiring/sensor wise has to be changed.
the h is literally a g with another turbo and intake manifold
eg33GC is offline   Reply With Quote
Old 04-08-2013, 01:49 PM   #12
luka
Member#: 194742
That is excellent news
Yeah the main coolant crossover is completely different and I will be using my G's.
is there any way to take the hard coolant line out of the head and swap them? they look to be pressed in... the way they are lined up now I gotta put together a serious mickey mouse hose to make the ends meet.
here's a pic of the EJ20H coolant line:
and here's the EJ20G line:
As you can see, mating the EJ20H with the stock turbo is a PITA.
Old 04-08-2013, 01:54 PM   #13
eg33GC
Member#: 206851
56 Belair
Pro Street
meh, just grab some heater hose and make it work!
Old 04-08-2013, 02:17 PM   #14
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Okay. That last pic has incorrectly labeled the oil return line as a coolant line.
You can get that off no problem and replace it with the G line. Just be careful getting the G one out of the head.
i_c_the_light is offline   Reply With Quote
Old 04-08-2013, 02:19 PM   #15
luka
Member#: 194742
That's my plan of record. I'm just anxious about having that coolant line pressed against the up-pipe.. I'll bend it a bit and wrap everything up.
Thanks for the help I'm feeling 139873298479324732 times better about this swap.
Old 04-08-2013, 02:23 PM   #16
luka
Member#: 194742
How do I get the line out? pry it out with a flat head? I've never dealt with lines like this before... I don't wanna start prying at it and break something :/
Old 04-08-2013, 02:31 PM   #17
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
It's a pain. Get it a wee way out with a driver and then wiggle it while pulling outwards. Be careful that metal is soft.
Old 04-08-2013, 03:27 PM   #18
luka
Member#: 194742
gahhh.... and there's no issues with tapping it back in and having it seal? I would hate to go through all that trouble and it doesn't seal...
Edit: would a propane torch help at all with taking it out?
Old 04-09-2013, 08:13 AM   #19
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
No unless you want to fry the head.
Old 04-09-2013, 01:14 PM   #20
luka
Member#: 194742
duly noted.
I opted to take the hard line off the turbo but because I have the TD05h the line is sitting much lower 'cause of the larger cartridge so the bend is extremely tight. gonna swing by the local auto chop and see if I can go through all their hoses to find something that will work.
Sign in if you have ej257 long block with ej205 intake parts hybrid gti 2 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 01-09-2009 11:24 AM
wrx long block with spun bearing scoobyred Engine/Power/Exhaust 5 07-04-2007 08:42 AM
WTB long block with wireing harnes and ecu monstergremlin16 RMIC Private Classifieds 0 01-21-2007 02:07 AM
WTB Full long block with wireing harnes and ecu. monstergremlin16 Private 'Wanted' Classifieds 0 01-21-2007 02:03 AM
Sti long block with 02 WRX ecu LiquidForce Built Motor Discussion 7 05-20-2006 06:06 PM
