Old 01-10-2008, 10:31 AM   #1
jcayos
Member#: 94471
2003 WRX
Default Logging?
I have decided to tune the car myself, but for some reason I can not log. I have tried many of the free downloads but none of them seem to work. It seems as if I do not have the complete sofware. I was looking into buying EcuEdit Pro. Does anyone have any other suggestions or thoughts that can help me out. I am tuning with a tactrix cable. Thanks.
jcayos is offline   Reply With Quote
Old 01-10-2008, 10:48 AM   #2
Tea cups
Member#: 103136
Buying ecuedit is not going to help you log. Likely your issue is user error, but without more details on your part it is difficult to narrow it down. Did you install Ecuflash which installs the drivers for your tactrix cable? What OS are you using (e.g. XP, Vista, Mac, etc.)? What application are you trying to log with? Did you change the COM port in the logging application?
Read this:
http://forums.nasioc.com/forums/show....php?t=1410201
Tea cups is offline   Reply With Quote
Old 01-10-2008, 10:52 AM   #3
equinsu ocha 07
Member#: 157333
**** Hey kids, wanna
get hi?
yes and remember to start logging you have to hit your rear defrost button
equinsu ocha 07 is offline   Reply With Quote
Old 01-10-2008, 11:07 PM   #4
krexx
Member#: 168723
When I installed EcuFlash, it asked if I wanted to install the OpenPort drivers. Duh, I did.
When I plugged in the cable, it started looking for a driver to use with it. I pointed it towards that driver, and it works. It took me a while to figure this out, because I thought they had already been "installed" but really, the driver is just on your computer, but not in use. Was this any help?
krexx is offline   Reply With Quote
Old 01-11-2008, 05:23 AM   #5
Tea cups
Member#: 103136
EDIT: never mind.
Old 01-11-2008, 10:05 AM   #6
jcayos
Member#: 94471
2003 WRX
Thanks for all the info guys, but I still can not get it to work. I have read just about everything there is to read and still no luck. I will try again because it might just be user error, if not I guess I will buy the EcuEdit Pro. Thanks.
Old 01-11-2008, 10:25 AM   #7
Tea cups
Member#: 103136
Like I said, buying Ecuedit will do nothing for you. If you can't log with Enginuity or Ecuexplorer with the tactrix cable, you won't be able to log with Ecuedit either. You did not answer the questions I asked. What OS are you running the logger in? What COM port do you have it set to in the logger (in Enginuity, there's a drop down box in the upper left hand corner - did you try each one?).
Old 01-11-2008, 11:20 AM   #8
quazimoto
Member#: 70395
Dude,slow down and read what these guys are telling you and answer their questions.Good luck if you go the EcuEdit route.It's more complicated than using Ecuflash or Enginuity and there is not alot of support for it.You need to be halfway decent with computers to play with it.
quazimoto is offline   Reply With Quote
Old 01-11-2008, 02:17 PM   #9
wrxracer519
Member#: 149890
09 Forester
Green
def answer tea cups questions, he helped me get my logger working through my thread. Thanks again tea cups/merchgod
wrxracer519 is offline   Reply With Quote
Old 01-11-2008, 05:52 PM   #10
jcayos
Member#: 94471
2003 WRX
Sorry for not answering TeaCup, I am using XP, and I have tried everything that has been mentioned. I am able to pull the logging up but for some reason it will not save. I have done the defrost button and still no luck. I even had a friend do it that has tuned many cars before with opensource and enginuity and he can't save the logs either. I have deleted everything and downloaded it into the laptop and still nothing. Please help. Thank you.
Old 01-11-2008, 06:01 PM   #11
Tea cups
Member#: 103136
Did you read the FAQ that I linked to? Despite the "expert" help, this sounds exactly like user error which can be fixed by reading the following questions from the FAQ (read the underlined items):
Q: Can you give me a step-by-step on how to log with Enginuity?
1. Turn on your laptop.
2. Connect the USB end of your tactrix cable to the laptop and the other end of the cable to the OBD-II port on your car (underneath the steering wheel).
3. Start Enginuity. Select Logger -> Launch Logger from the top menu.
4. In the logger's Settings menu, make sure "Control File Logging with Defogger Switch" is selected.
5. Turn the ignition key to on or start the vehicle.
6. Choose the correct COM port for your tactrix cable from the drop down box in the upper left hand corner of the logger.
7. Select the parameters you wish to log in the left pane (the greater the number of parameters selected, the greater the sampling interval will be).
8. When you wish to log to a file, turn on the defogger. When you wish to end writing to that file, turn off the defogger. Each on/off sequence of the defogger will generate a separate file.
Q: Where are my log files saved?
In the logger, go to Settings->Log File Output Location to view or change the directory where the log files are saved.
How do I read my Log? Does this log look OK to you? Knock? scottjua AccessPort 3 05-21-2009 04:03 AM
First time log before tuning, what to log? ogboot Open Source Reflashes 3 07-10-2008 02:01 PM
Will utec log knock events in log when not in control? MAP 0 NITROS UTEC 1 08-21-2007 10:55 AM
Data logging gurus, need your help reading log. vortectoy AccessPort 5 05-22-2006 01:19 AM
ghetto logging. take a look at my Tari log, need help Keith Engine Management & Tuning 8 06-21-2005 07:14 AM
