Old 01-10-2008, 01:30 PM   #1
wittmer25
Member#: 102970
2004 STi gt30r
Default Maximum AVCS Advance w/ Cosworth cams?
Whats the Max AVCS intake cam advance with Cosworth cams, 100mm wiesco pistons, cometic .051" thick head gasket, ej257 block and crank, heads surfaced .005", and block surfaced (not sure how much). Anyone have any experience with this?
Jonathon
Edit: With stock intake/exhaust valve size.
wittmer25 is offline   Reply With Quote
Old 01-10-2008, 04:32 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yeah, its a not fun problem to solve...you also have to use the lift and profile of the cams too...so unless you have the complete cam profile you can't have a definative answer.
Also would need your valve size.
to get nit picky, you need to have actual valve lift at rpm in the cam.
Old 01-10-2008, 04:45 PM   #3
wittmer25
Member#: 102970
2004 STi gt30r
I am finally finished with my build and i am about to fire her up. I wanted to make sure that I won't hit my pistons with my valves at max cam advance. Has anyone used max AVCS cam advance with these cams? And if so, what where the your engine specs?
Old 01-10-2008, 04:49 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
what em are you using? open ecu or hydra?
if hydra, you may want to call phil (element), dom (kito autosport), tim bailey (?)...you get the idea.
besides, which cossie cams are you on?
Old 01-10-2008, 04:50 PM   #5
wittmer25
Member#: 102970
2004 STi gt30r
I think I bought them from you. 278/274 i think. and I use enginuity to tune with.
Jonathon
Old 01-10-2008, 04:56 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
haha, oh yeah...you did. Now the name clicked. 278/274 is correct
Old 01-11-2008, 10:54 AM   #7
wittmer25
Member#: 102970
2004 STi gt30r
bump for sti cosworth cam users. Whats your max intake advance?
Old 01-11-2008, 01:33 PM   #8
modaddict
Member#: 95840
sold to a good bud
awaiting next car
ahahahaha...that's funny Micah
modaddict is offline   Reply With Quote
Old 01-11-2008, 02:02 PM   #9
Homemade WRX
Member#: 33782
96 bastard child
I aim to please
Old 01-11-2008, 08:22 PM   #10
shvrdavid
Member#: 86078
2005 Sti
4094R Twin Scroll
I would also love to know how much advance you can use with these cams...
I have the next step up from the ones wittmer25 is questioning... (284)
If nobody knows, I will be spending a lot of time to figure it out...
If you are really in doubt, zero out both maps before you fire it up.... Better safe than sorry...
shvrdavid is offline   Reply With Quote
Old 01-11-2008, 11:45 PM   #11
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
advance until you hear a tapping sound, then back it off a degree
jigga is offline   Reply With Quote
Old 01-12-2008, 09:56 AM   #12
Homemade WRX
Member#: 33782
96 bastard child
haha...I'm buying adjust cam gears for this reason exactly...easier than doing it on paper and also adjustable cams are a beautiful thing...
Old 01-12-2008, 06:09 PM   #13
wittmer25
Member#: 102970
2004 STi gt30r
bump bump bump for somebody out there that has built an engine, advanced his cosworth intake cams, and their engine is still in one piece.
Old 01-12-2008, 11:31 PM   #14
modaddict
Member#: 95840
sold to a good bud
awaiting next car
try contacting tim bailey
Old 01-12-2008, 11:36 PM   #15
flycaster
Member#: 60142
2011 WRX
Grey
Or mick_the_ginge.
flycaster is offline   Reply With Quote
Old 01-14-2008, 09:26 PM   #16
Badazzcr
Member#: 67693
4 Making them
faster then anyone else.
Cosworth cams have pretty mild lift, so I wouldn't worry to much about it.
Badazzcr is offline   Reply With Quote
Old 01-14-2008, 10:40 PM   #17
charliew
Member#: 125304
Pretty mild as compared to what. If you don't have anything of value to contribute please don't waste our time.
Charliew
charliew is offline   Reply With Quote
Old 01-14-2008, 11:32 PM   #18
Badazzcr
Member#: 67693
4 Making them
Hows this for ya then...
I have tuned a ton of subaru's running the Cosworth cams, even running an aggressive amount of cam advance without any piston to valve clearance issues. Cosworth cams are not a really big lift cams like some of the more aggressive Kelford ones. So like I said in my previous statement... I wouldn't worry about it.
Cosworth made these cams so the avg Joe could bolt them in and not have to worry about anything.
Old 01-15-2008, 10:03 AM   #19
shvrdavid
Member#: 86078
2005 Sti
4094R Twin Scroll
I guess the 10.7 mm on my Cosworths (intake) are mild lift....
Old 01-15-2008, 10:37 AM   #20
R & H Garage
Member#: 139767
it's true
the high lift 11.3 kelfords are another story.
R & H Garage is offline   Reply With Quote
Old 01-15-2008, 10:47 AM   #21
wittmer25
Member#: 102970
2004 STi gt30r
Ok fellows, high lift cams are a relative term. I specifically wanted to know if the 278/274 cosworth cams at 10.7mm (.421") lift will have any trouble with max avcs advance?
Jonathon
Edit: In other words, post up if you are personally maxing out the avcs cam advance in your car.
Old 01-16-2008, 10:32 PM   #22
boogerwrx
Member#: 13448
2002 wrx wagon
You can run stock AVCS values with the Cosworth cams, or at least I have in the past without any problems. The ones you have to look out for are the Kelford cams that have more lift. With those, I recommend you run no more than 8deg pos or neg cam fluctuation. I typically tell my guys to just unplug the AVCS selenoids until they can either get a reflash to mod the AVCS settings or if they are running a Hydra or similar to get a base map to reflect the cam values.
Ron
boogerwrx is offline   Reply With Quote
Old 01-16-2008, 10:42 PM   #23
wittmer25
Member#: 102970
2004 STi gt30r
Ron,
Correct me if I am wrong, but I think the stock avcs map on an 04 STi runs 20 degrees advance. Isn't that the maximum advance that the stock cam pulleys can rotate? Anyone know for sure?
Jonathon
Edit: I can reflash the ecu with enginuity. My current map is set up to fully advance the cams at low rpm, high engine load. I may need to change it back to stock.
Old 01-17-2008, 05:24 PM   #24
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Ron
Ron,
According to your spec sheet from TurboQueef:
You say to limit the AVCS to +/- 8*. Now the lift you spec is 10.7 and 10.2 respectively. Isn't that almost identical to cosworth's peak valve lift of 10.7 and 10.0?
Crystal_Imprezav is offline   Reply With Quote
Old 01-17-2008, 05:50 PM   #25
shvrdavid
Member#: 86078
2005 Sti
4094R Twin Scroll
I am really confused here, how do you get the avcs to turn the wrong direction (8 +/-)...
I emailed Cosworth about it and have yet to get an answer....
I guess I will have to mock up my long block and figure it out for myself...
I have far to much invested to mess it up....
Cosworth cams on AVCS problem butt_crack Built Motor Discussion 21 08-13-2009 11:37 AM
maximum AVCS with BC 272 cams for EJ257? benw Built Motor Discussion 10 12-20-2008 12:31 PM
Maximum AVCS Advance w/ Cosworth cams? wittmer25 Open Source Reflashes 3 01-17-2008 10:34 PM
Cosworth Cams EJ25-Material added? (What other Cams are as well?) EjtwentyfiveSti Built Motor Discussion 5 04-16-2007 10:15 PM
AG970 STi RA ECU and AVCS Advance... 30 degrees? dug-e-fresh Engine Management & Tuning 0 11-04-2003 03:10 PM
