Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Old 01-10-2008, 04:16 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default Effect of Temperature on MAFv, MAFg/sec, and Engine Load
OK, so being Ohio in the winter, the temperature is fluctuating up and down by 40F every week. This means that I'm getting data with IATs that swing that much. It makes comparing one run to another pretty crazy.
1) Due to the way the MAF sensor works, it reads higher voltage at lower temps if flow velocity/volume is held constant, right?
2) Is the car actually getting more molecules of O2 at colder temps since the cold air is denser? (aka, do the actual mass of O2 and the MAF sensor trend in the same direction with temperature)
3) I'm looking at the MAF Compensation A/B (Intake Temp) table. When is this compensation applied? Obviously MAFv is pre-compensation, but if I log MAF g/sec, is the compensation already applied? What about Engine Load (g/rev)?
Basically, I'm trying to figure out how to compare two runs made at different temps to each other to figure out if one flowed more air than the other.
Old 01-10-2008, 07:16 PM   #2
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Log MAF G/S to see that. Tea cups will have to chime in on the specifics on when the compensations are applied, but all in all, colder air = more air mass. This is why you need injector headroom (for when it gets cold out).
You think temp fluctuations are bad there? Try 34 in the morning and 85 in the evening.
Gabe
gabedude is offline   Reply With Quote
Old 01-10-2008, 07:18 PM   #3
nv-wrx
Member#: 75643
2004 WRX
San Remo Red
The ECU has a compensation table for pressure and temperature for MAF. g/sec is g/sec no matter what temperature. That is the beauty of using g/sec and not CFM. Now your loads will be higher when it is colder out given the same throttle-RPM-gear.
nv-wrx is offline   Reply With Quote
Old 01-10-2008, 09:18 PM   #4
Tea cups
Member#: 103136
MAFv would increase if temperature drops given the same volume of air (greater density). Therefore, so would measured mass airflow (g/s) and load (g/rev) which is calculated based on airflow and rpm.
When you log mass airflow and load it is after the compensations (IAT and manifold pressure) are applied.
Tea cups is offline   Reply With Quote
effects of IAT on MRP vs LOAD ride5000 Engine Management & Tuning 24 03-31-2008 09:44 AM
Which advance multiplier and engine load from ecuexplorer to log? breathinez Engine Management & Tuning 2 02-07-2007 12:13 PM
Effect of Wastegate on MAP and MAF Jon [in CT] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-19-2002 12:31 PM
effects of putting on a intercooler on N/A engine WRXwannbe Normally Aspirated Powertrain 7 02-01-2001 02:16 AM
Effect of Accident on Warranty??? RSkid General Forum Archive 3 09-14-2000 07:40 AM
