Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 01-10-2008, 11:32 PM   #1
krexx
Member#: 168723
Default Long time reader, First time (log)poster
So I finally got a log done on my stock 07 WRX TR. I wanted to see how healthy it was before I flashed stage 1. Please keep in mind that this is a 2nd gear pull. I know I'm supposed to be doing 3rd gear pulls, but there isn't much room to do 3rd gear pulls in downtown Chicago and a bit after rush hour in the rain, haha.
If anyone would be kind enough to take a quick peek, the link is here: http://www.box.net/static/flash/box_...hockwave-flash.
It looks as I'm hitting a bit of detonation from 48xx to 55xx RPM. So if I were to do something about it before I flash stage 1, I would A) pull tiny bit of timing, B) Add fuel, or C) pull boost(by target WGDC), correct?
I also noticed I'm only hitting 10.8x lbs. of boost. I'm not concerned about this as much as the knock, but still curious. Target boost is about 12 lbs. stock, correct?
I am still learning and will not touch ANYTHING until I know what I'm doing. Thanks in advance.
krexx is offline   Reply With Quote
Old 01-11-2008, 07:45 AM   #2
wage0052
Member#: 127556
2006 WRX
RomRaided.
The stock map is terrible. Personally, I'd take one of the free stage 1 maps from the OSecu forums, and tune from that.
You need to log feedback correction to check for knock. The timing pulled is learned timing, which means you knocked in that range sometime in the past, and the car learned to pull timing.
IIRC the stock target boost for the 2.5L WRX is ~11.6. Doubtful that you'll hit that in second gear, so your logged values appear to be in range.
When you feel like you know what you're doing, venture over to the OSecu forums and try out Gabedude's 06-07 WRX stage 1 map.
wage0052 is offline   Reply With Quote
Old 01-11-2008, 08:28 AM   #3
krexx
Member#: 168723
Yeah, I have been reading up on his map revision notes for a while. I guess I'll just flash it tonight so i can spend the weekend logging. Thanks for your help and input.
Long time reader, first time poster.... ChaseHeadrick North West Impreza Club Forum -- NWIC 8 02-16-2009 03:44 AM
long time reader,...first time threader... ImTehBetterThanU Texas Impreza Club Forum -- TXIC 13 06-15-2007 08:54 AM
Long time reader, first time post. krizzo Normally Aspirated Powertrain 3 04-16-2005 12:36 PM
long time listener, first time caller. i need help asap metalnerd Southern California Impreza Club Forum -- SCIC 22 03-25-2004 01:34 PM
Long time listener, First time owner! mbakercad General Community 17 11-13-2003 12:58 AM
