Old 12-30-2007, 05:22 PM   #1
fulham
Member#: 167864
2005 Saabaru Aero
Default Injectors at 99% duty cycle
<sorry for the cross-post from openecu.org, but there's so much more traffic here i figure i might get more help >
flashed my otherwise stock 2005 5mt saabaru to stage 1 using this rom from openecu.org.
drove around town for 40mi or so, then on the fwy for about 50mi before creating this log (rt click, save as ) wot, 3rd gear pull, 76 brand premium gas (92 octane in oregon i think).
as the rpms hit 6k the injectors are at 99%. that seems too high to me. any thoughts? anything else stand out from the log that i should look into?
thanks!
-scott
fulham is offline   Reply With Quote
Old 12-30-2007, 06:20 PM   #2
quazimoto
Member#: 70395
Cold weather = denser air =more fuel needed.Normal http://forums.nasioc.com/forums/sear...rchid=12115286
Old 12-30-2007, 10:54 PM   #3
fulham
Member#: 167864
2005 Saabaru Aero
so you're saying i have nothing to be worried about? or it's normal in cooler weather & i need to make some adjustments to the map? it's not as if the nw is really ever very cold--or hot
your link was to a search, not an actual thread, but i did read some good info by searching some more. i also learned i can search on idc--duh.
could you post the thread you were referring to? or the search tems for me?
i also learned how to attach logs inline, if anyone else cares to look
Code:
afl    ct    el    rpm   fbkc flkc iam  it    idc     iat  kc adv mrp    maf      toa   mph
2.2    189   1.12  3692  0    0    15   19    23.63   46   6.5    0.44   68.96    100   50
1.81   189   1.8   3780  0    0    15   14    49.19   46   8      7.11   114.38   100   50
-0.49  189   2.11  3882  0    0    15   14    61.28   46   6.5    12.48  137.03   100   50
-0.49  189   2.1   3991  0    0    15   14    61.31   46   7      13.06  136.69   100   51
-0.49  187   2.17  4105  0    0    15   14    65.68   46   6.5    14.07  148.8    100   51
-0.49  187   2.19  4240  0    0    15   14.5  68.74   46   6.5    14.07  152.22   100   53
-0.49  187   2.21  4380  0    0    15   15.5  70.84   46   6.5    14.07  158.69   100   53
-0.49  187   2.22  4512  0    0    15   16    74.59   46   7      14.36  165.86   100   56
-0.49  187   2.26  4618  0    0    15   16.5  78.81   46   7.5    14.51  172.73   100   56
-0.49  187   2.24  4711  0    0    15   16.5  80.1    46   8      14.65  176.58   100   60
-0.49  187   2.27  4826  0    0    15   17.5  83.67   46   8.5    14.65  180.42   100   60
-0.49  187   2.28  4973  0    0    15   17.5  88.06   46   8      14.65  191.73   100   62
-0.49  187   2.28  5102  0    0    15   19    88.89   46   7.5    14.51  192.11   100   65
-0.49  187   2.27  5162  0    0    15   19    90.29   46   7      14.36  195.85   100   65
-0.49  187   2.24  5353  0    0    15   20    91.72   46   7      14.07  197.71   100   68
-0.49  187   2.21  5430  0    0    15   21    92.68   46   7.5    13.64  198.46   100   68
-0.49  187   2.17  5506  0    0    15   21.5  91.62   46   8      13.35  198.83   100   72
-0.49  187   2.18  5656  0    0    15   22.5  95.32   46   8      13.2   205.4    100   72
-0.49  187   2.16  5738  0    0    15   22.5  95.48   46   8      13.06  204.04   100   75
-0.49  187   2.13  5901  0    0    15   23.5  95.43   46   7.5    12.91  205.8    100   75
-0.49  187   2.1   5971  0    0    15   23.5  96.81   46   7      12.77  208.6    100   78
-0.49  187   2.11  6043  0    0    15   23.5  99.27   46   7      12.77  214.6    100   78
-0.49  187   2.08  6172  0    0    15   24    98.76   45   7.5    12.77  212.6    100   80
-0.49  187   2.04  6203  0    0    15   26.5  97.93   45   7.5    12.77  215.4    100   82
-0.49  187   2.02  6276  0    0    15   26.5  99.07   45   8      12.77  216.6    100   82
-0.49  185   1.99  6394  0    0    15   27    97.62   45   8      12.77  213.4    100   85
-0.49  185   1.97  6527  0    0    15   27    98.96   45   8      12.91  213      100   85
-0.49  185   1.95  6550  0    0    15   27.5  98.61   45   9      13.06  212.2    100   87
-0.49  185   1.93  6690  0    0    15   28.5  98.5    45   9      12.91  214.2    96.08 87
sorry for being such a newb to this. i wish enginuity was up so i could read more background stuff...
-scott
Old 12-31-2007, 03:10 AM   #4
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
u need a pump and injectors or just turn down the boost a few PSI. Don't run your injectors near 100%. 90-94 is what I aim for in the cold.
gabedude is offline   Reply With Quote
Old 12-31-2007, 03:18 AM   #5
SJwrx
Member#: 14970
1997 GF8
multi
Injectors from the factory rarely run on the plus side of 8x% DC, simply for the fact that overheating and early failure of the injector will ensue. Solution: larger displacement pump with appropriate injectors.
Rich
SJwrx is offline   Reply With Quote
Old 12-31-2007, 04:13 PM   #6
Tgui
Member#: 44771
Well, even the stock ecu will push over 100% duty cycle at times. IDC is a rough calculation anyways.
That said, I'll say I've logged up to 118% duty cycle, YIKES! I'm not stock and dialed back the boost. But, even at that high duty cycle AFRs were spot on and I saw no knock correction. So I think there might be a little headroom.
I now see 104% on a regular basis and have had no problems. (I have new injectors ready to be flow tested btw)
Best not to chance things though, I'm prepared to pick up a new short block when the day comes
Tgui is offline   Reply With Quote
Old 12-31-2007, 07:08 PM   #7
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
fulham do you have a wideband?
If you were running super rich your duty cycle would be high.
Smoby is offline   Reply With Quote
Old 12-31-2007, 07:27 PM   #8
jordanretro1223
Member#: 143039
2007 STI
Yeah like Smoby said if this map leans out after a fill up or two it will run lower IDC's so go easy on it for like 150 or 200 miles and then check it again.
jordanretro1223 is offline   Reply With Quote
Old 12-31-2007, 08:31 PM   #9
fulham
Member#: 167864
2005 Saabaru Aero
Smoby -- no i dont have a wideband. i was looking at this as a "getting my feet wet exercise" by going to stage 1, then i'd start getting things like a wideband and experimenting more. guess i sure am getting my feet wet
jordanretro1223 -- i filled up with shell v-power today. i trust that more than the 76 gas i got right off i-5, so i'm hoping things will improve. of course i'm going snowboarding tomorrow which will mean driving 50 mi & gaining 3000' elevation (and temps < freezing at the top). guess i'd better take things super easy. pity i cant log on the way, but i'm not leaving my laptop in the parking lot...
otherwise--i wonder how many others have installed the osecu stage1 on stock cars and aren't logging at all can't believe i'm the only one driving around in cold dense air, especially with all the subarus in the nw.
the map shows a target boost of [email protected], and i'm at 14.65, and down to [email protected], and i'm at [email protected], so i'm not even hitting target.
i don't really want to go to bigger injectors & pump at this stage...guess it's time to start learning how to play with the map
thanks for all the help!
Old 01-01-2008, 11:28 AM   #10
controler
Member#: 100271
You should be fine with the stock injectors at that IDC, even at stage 2 levels. There are some threads on this if you search.
Also if that is a 3rd gear log, you'll hit a little higher boost in 4th, so don't expect to get exactly whats on your table in 3rd gear. So tune accordingly.
From logging, my map/car likes Shell 93 the least. IAM gets killed every time I use it. Your results may vary, but I suggest trying different gas.
controler is offline   Reply With Quote
Old 01-02-2008, 09:40 PM   #11
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
it is all normal. ive seen way too many threads of injectors running over 95% even over 100% iono how thats possible.
tux121 is offline   Reply With Quote
Old 01-02-2008, 09:56 PM   #12
fulham
Member#: 167864
2005 Saabaru Aero
well we only have shell 92 on the west coast so maybe that's better than the 93 . actually i plugged enginuity in & it's still at an iam of 15 so doubt it has helped much. chevron will be next...the last few tanks were 76. or maybe costco or arco should be next? haha!
it is indeed a 3rd gear log. i dont dare do a 4th.
just because people run at 100% idc doesnt mean it's good...i'd rather lose a little power and have money to spend on things other than a new engine! i know what you mean though--i'm sure subaru has plenty of leeway built into the thing. we all have our comfort levels i guess.
-scott
Old 01-04-2008, 12:39 PM   #13
pweizman
Member#: 131268
.... GOD........
Make sure you have a clean fuel filter.
I believe when I was dyno tuned, my filter was clogged.
I am a bit surprised at a target boost of 15.47 psi you are out of fuel.
My '03 didn't max out the injectors until 18-19 psi in 3rd gear at 6500 rpm+, and that was on a clogged fuel filter.
Patrick
pweizman is offline   Reply With Quote
Old 01-05-2008, 08:30 PM   #14
fulham
Member#: 167864
2005 Saabaru Aero
did a couple more logging runs. all in all i'm happier with these logs. the idc is still on the high side, but not crazily so, and i rarely get up over 6k in daily driving anyway. it was slightly warmer, so that may have something to do with it, but i have a feeling the map has more miles on it now, and it may like the shell gas better than the 76 i got from a sketch station right off i-5. i'll probably try chevron next.
first run:
Code:
Time    rpm     el      fbkc    flkc    iam     it      idc     kca     mrp     maf     wgdc    toa     TDC     mph     afc     afl     ct      iat
0       2028    0.17    0       0       15      13.5    2.6     0       -10.59  12.98   0       8.24    3       29      0       4.83    189     46
302     2096    0.87    0       0.35    15      31      12.07   0       -0.29   43.08   5.88    100     3       28      -2.34   4.35    189     46
605     2057    1       0       0.35    15      35      13.61   8       0.58    35.89   20.78   100     3       29      0       3.91    189     46
909     2171    1.07    0       0.35    15      31.5    14.82   8       1.6     39.98   36.08   100     3       29      0       1.76    189     46
1214    2258    1.12    0       -2.46   15      26      16.37   5       2.76    42.59   47.84   100     3       29      0       1.76    189     46
1517    2333    1.19    0       -2.46   15      22      17.92   5       3.48    47.65   62.75   100     3       30      0       1.76    189     46
1823    2404    1.28    0       -2.46   15      18      20      5       4.5     53.34   74.9    100     3       30      0       1.46    189     46
2127    2500    1.35    0       0.35    15      19.5    21.16   8       5.66    57.77   89.41   100     3       31      0       1.03    189     46
2429    2584    1.45    0       0.35    15      19      23.71   8       6.53    64.85   81.18   100     3       31      0       -1.27   189     46
2733    2726    1.57    0       0.35    15      18.5    26.75   8       7.84    74.08   80.39   100     3       34      0       -1.27   189     46
3037    2813    1.72    0       0.35    15      18.5    31.81   8.5     9.14    83.47   80.39   100     3       35      0       -1.27   189     46
3344    2960    1.87    0       0.35    15      17.5    37.89   8.5     11.32   94.14   80.39   100     3       35      0       -1.27   189     46
3645    3098    2.01    0       0.35    15      15.5    43.62   8       13.2    105.42  80.39   100     3       37      0       -1.27   189     46
3949    3221    2.06    0       0.35    15      14      46.73   7       14.07   113.6   80.39   100     2.32    40      0       -1.27   189     46
4252    3375    2.1     0       -0.7    15      14      50.4    6       14.22   118.35  80.39   100     2.2     40      0       -1.27   189     46
4556    3534    2.16    0       -0.7    15      11.5    53.7    5.5     14.36   128.18  80.39   100     1.99    43      0       -1.27   189     46
4863    3678    2.16    0       -0.7    15      12      58.06   5.5     14.22   133.57  80.39   100     2.11    46      0       -1.27   189     46
5164    3809    2.16    0       -0.7    15      12.5    59.31   5.5     14.22   140.01  80.39   100     2.06    46      0       -1.27   189     46
5469    3978    2.14    0       -0.7    15      13      59.47   5.5     14.07   141.81  80.39   100     2.06    49      0       -1.27   189     46
5772    4096    2.15    0       -0.7    15      13      64.66   5.5     14.07   144.54  80.39   100     2.95    52      0       -1.27   189     46
6075    4280    2.16    0       0       15      14      67.57   6.5     14.07   151.24  80.39   100     2.02    52      0       -1.27   189     46
6384    4396    2.17    0       0       15      14.5    70.34   6.5     14.07   162.6   80.39   100     1.97    55      0       -1.27   189     46
6684    4554    2.19    0       0       15      15.5    73.83   7       14.07   165.21  80.39   100     1.73    55      0       -1.27   189     46
6990    4667    2.22    0       0       15      16      77.65   8       14.36   173.78  80.39   100     1.39    58      0       -1.27   189     46
7295    4804    2.24    0       0       15      17      81.99   8.5     14.65   177.97  80      100     1.04    61      0       -1.27   189     45
7598    4931    2.26    0       0       15      18      85.2    8       14.8    184.75  78.04   100     0.89    61      0       -1.27   189     45
7900    5098    2.26    0       0       15      17.5    88.1    7       14.51   190.61  76.86   100     1.31    64      0       -1.27   189     45
8206    5219    2.22    0       0       15      19      89.07   7       14.36   193.98  75.29   100     1.33    67      0       -1.27   189     45
8509    5330    2.2     0       0       15      19.5    89.83   7.5     13.93   198.46  75.29   100     1.31    67      0       -1.27   189     45
8814    5466    2.15    0       0       15      20.5    90.06   8       13.2    195.47  75.29   100     1.64    70      0       -1.27   189     45
9119    5597    2.13    0       0       15      21      90.74   8       13.06   197.8   75.29   100     1.73    73      0       -1.27   189     45
9422    5734    2.13    0       0       15      22.5    92.96   8       13.06   203     75.29   100     1.62    73      0       -1.27   189     45
9725    5841    2.11    0       0       15      23      93.46   7.5     12.91   207.8   75.29   100     1.52    76      0       -1.27   189     45
10028   5919    2.08    0       0       15      23.5    93.45   7       12.62   209.8   75.29   100     1.48    78      0       -1.27   189     45
10332   6024    2.07    0       0       15      23.5    95.1    7       12.77   208.6   75.29   100     1.31    78      0       -1.27   187     45
10633   6132    2.04    0       0       15      24      95.5    7.5     12.62   211.4   75.29   100     1.27    81      0       -1.27   187     45
10939   6318    2.02    0       0       15      26      97.05   8       12.62   212.2   74.51   100     1.1     83      0       -1.27   187     45
11244   6318    1.99    0       0       15      27      95.7    8       12.62   212.2   74.51   100     0.89    83      0       -1.27   187     45
11548   6421    1.96    0       0       15      27      97.26   8.5     12.77   210.2   74.51   100     0.66    86      0       -1.27   185     45
11867   6499    1.94    0       0       15      27.5    97.05   8.5     12.91   212.2   74.51   100     0.54    86      0       -1.27   183     45
12157   6660    1.92    0       0       15      28.5    96.62   9       12.91   208.6   74.51   100     0.42    88      0       -1.27   183     45
12462   6726    1.9     0       0       15      28.5    97.58   9.5     12.91   210.6   74.51   100     0.31    89      0       -1.27   181     45
12765   6818    1.86    0       0       15      29.5    97.45   9.5     12.91   209.8   74.51   100     0       89      0       -1.27   180     45
13068   6830    1.85    0       0       15      30.5    94.71   9.5     12.91   210.2   74.51   100     0.24    91      0       -1.27   178     45
13373   6900    1.82    0       0       15      30.5    97.14   9       12.91   211.8   74.51   100     0       93      0       -1.27   178     45
13676   6970    1.8     0       0       15      30.5    96.65   9       12.91   210.6   74.51   100     0       93      0       -1.27   176     45
13979   6938    1.73    0       0       15      29.5    91.76   8       12.62   207.4   65.1    0       0       95      0       -1.27   174     45
2nd run:
Code:
0       2024    0.94    0       0       15      33      11.66   3.5     -0.15   4.39    0       0       3       29      0       0.29    190     48
303     2074    1.02    0       0       15      34      14.16   7.5     1.02    35.03   9.02    100     3       29      0       1.9     198     48
610     2158    1.1     0       0       15      29.5    15.2    7.5     2.32    36.74   20.78   100     3       28      0       1.46    198     48
912     2235    1.16    0       -2.81   15      23.5    16.21   4.5     3.34    39.84   36.08   100     3       28      0       -0.59   198     48
1217    2325    1.23    0       -2.81   15      20      17.85   4.5     4.5     44.55   50.98   100     3       29      0       -0.59   198     48
1520    2398    1.34    0       -2.81   15      18.5    19.95   7       5.37    46.15   62.75   100     3       30      0       -0.59   198     48
1824    2478    1.43    0       -0.7    15      17      22.2    7       6.67    55.15   78.04   100     3       30      0       -1.27   198     48
2127    2577    1.54    0       -0.7    15      16.5    25.29   8       8.13    59.97   87.84   100     3       32      0       -1.27   198     48
2434    2702    1.67    0       0.35    15      17.5    28.82   8       9.29    66.61   81.18   100     3       34      0       -1.27   196     48
2736    2832    1.85    0       0.35    15      16.5    35.04   8.5     11.17   76.95   81.18   100     3       34      0       -1.27   196     48
3042    2933    1.98    0       0.35    15      15      39.42   8       13.2    90.74   81.18   100     3       36      0       -1.27   196     48
3346    3071    2.06    0       0.35    15      14      43.89   7       14.36   97.33   81.18   100     3       39      0       -1.27   196     48
3650    3227    2.06    0       0.35    15      14      47.5    7       14.51   105.77  81.18   100     2.09    39      0       -1.27   196     48
3953    3380    2.08    0       0.35    15      13.5    49.17   7       14.36   111.05  81.18   100     1.88    41      0       -1.27   196     48
4257    3514    2.12    0       0.35    15      12.5    53.23   6       14.22   118.08  81.18   100     1.97    41      0       -1.27   196     48
4560    3637    2.13    0       -0.35   15      12      55.86   6       14.07   125.91  81.18   100     2.13    44      0       -1.27   196     48
4863    3755    2.14    0       -0.35   15      12.5    58.48   6       14.07   132.43  81.18   100     2.2     47      0       -1.27   196     48
5167    3908    2.14    0       -0.35   15      13      60.03   6       14.22   135.59  81.18   100     2.16    47      0       -1.27   196     46
5473    4026    2.11    0       -0.35   15      13      61.83   6       14.22   140.03  81.18   100     1.04    50      0       -1.27   196     46
5776    4157    2.12    0       -0.35   15      14      63.86   6.5     14.07   141.08  81.18   100     1.95    53      0       -1.27   196     46
6080    4293    2.15    0       0       15      14      67.77   6.5     13.93   148.19  81.18   100     2.04    53      0       -1.27   196     46
6383    4412    2.19    0       0       15      14.5    70.58   7       13.93   155.43  81.18   100     2.13    56      0       -1.27   196     46
6686    4596    2.17    0       0       15      15.5    74.51   7.5     14.22   162.6   80.39   100     1.85    58      0       -1.27   194     46
6992    4688    2.17    0       0       15      16      77      8       14.51   165.68  80.39   100     1.55    58      0       -1.27   194     46
7297    4876    2.18    0       0       15      16.5    80.61   8.5     14.51   173.09  80.39   100     1.25    62      0       -1.27   194     46
7599    4993    2.2     0       0       15      17      83.08   8       14.36   176.58  80      100     1.27    64      0       -1.27   194     46
7903    5071    2.2     0       0       15      17.5    85.46   7       14.07   185.38  78.43   100     1.35    64      0       -1.27   194     46
8206    5183    2.19    0       0       15      18      87.35   7       13.93   187.62  76.86   100     1.55    67      0       -1.27   194     46
8510    5319    2.17    0       0       15      19      88.51   7       13.78   190.24  75.29   100     1.83    67      0       -1.27   194     46
8813    5435    2.13    0       0       15      20      88.12   8       13.49   193.6   75.29   100     1.55    70      0       -1.27   194     46
9119    5584    2.12    0       0       15      21      90.54   8       13.2    194.72  75.29   100     1.73    73      0       -1.27   194     46
9421    5690    2.11    0       0       15      21.5    92.26   8       13.06   196.22  75.29   100     1.46    73      0       -1.27   194     46
9756    5805    2.08    0       0       15      22.5    92.88   7.5     12.91   201.85  75.29   100     1.52    75      0       -1.27   194     46
10029   5905    2.07    0       0       15      22.5    93.22   7       12.77   200.73  75.29   100     1.35    78      0       -1.27   194     46
10333   6024    2.05    0       0       15      23.5    93.81   7       12.77   205.8   75.29   100     1.38    78      0       -1.27   194     46
10640   6178    2.03    0       0       15      24      96.2    7.5     12.77   207     75.29   100     1.19    80      0       -1.27   192     45
10943   6244    2.01    0       0       15      26      95.92   7.5     12.62   207.4   75.29   100     1.12    83      0       -1.27   192     45
11245   6302    1.97    0       0       15      27      95.46   8       12.77   207.8   75.29   100     1.06    83      0       -1.27   192     45
11551   6410    1.94    0       0       15      27      94.36   8       12.77   210.2   75.29   100     1       85      0       -1.27   192     45
11854   6482    1.92    0       0       15      27      95.42   9       12.91   205.8   75.29   100     0.71    87      0       -1.27   190     45
12157   6660    1.9     0       0       15      29      96.62   9       12.91   207     75.29   100     0.52    87      0       -1.27   190     45
12464   6732    1.87    0       0       15      29.5    97.66   9.5     12.91   209     75.29   100     0.43    89      0       -1.27   189     45
12765   6812    1.85    0       0       15      30      97.36   9.5     12.91   211     75.29   100     0.37    91      0       -1.27   189     45
13069   6880    1.83    0       0       15      30.5    96.88   9.5     12.91   211.16  75.29   100     0       91      0       -1.27   187     45
13375   6951    1.79    0       0       15      30      96.38   9       12.91   209.8   75.29   100     0.28    93      0       -1.27   187     45
13678   6976    1.79    0       0       15      30      96.74   9       13.06   211.4   75.29   100     0       93      0       -1.27   185     45
13981   6906    1.71    0       0       15      30      88.4    8       12.91   210.2   75.29   100     0       94      0       -1.27   183     45
flkc is nothing to be worried about at that rpm, right? it's just the map has learned that it needs to dial back a bit at lower rpms? (sorry i'm still trying to understand everything!)
<continued>
Old 01-05-2008, 08:31 PM   #15
fulham
Member#: 167864
2005 Saabaru Aero
<continue>
what i still don't like is the low mrp. here's a screenshot of my map.
think i need to check my wastegate arm? i'm not even seeing 15psi...
one other question: sounds like the lc-1 is the best wbo2 to get for enginuity purposes, right?
i'll replace the fuel filter. i'm sure it's the original, the car only has 30,000mi.
thanks!
-scott
Old 01-05-2008, 09:59 PM   #16
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
I suggest reading some tuning guides or books.
You need to charge the Boost target, and wastegate tables to really change boost.
lc1 is nice, but ive had nothing but problems with mine. It's been at innovative for 2+ weeks now.
ExpO is offline   Reply With Quote
Old 01-06-2008, 09:46 PM   #17
controler
Member#: 100271
Yes tighten the wastegate arm a few turns and log. While I used one of ev8siv maps for stage 1 on my car, I didn't like his targets of 16.4 psi on the stock dowpipe. I dialed it back to 15.6 to be safe. I ran the map for 6+ months and did a compression test and all the numbers were rock solid in the 140s. From the logs, it looks like the map is pretty safe on your car... I wouldn't worry about the IDCs. But keep logging, that is always a good thing.
Old 01-08-2008, 03:30 PM   #18
pweizman
Member#: 131268
.... GOD........
Isn't the FLKC still bad because it is detecting knock?
I am learning too...I thought all knock was a bad thing. Like the column should be zeros...
What is IDC?
Patrick
Old 01-08-2008, 08:23 PM   #19
fulham
Member#: 167864
2005 Saabaru Aero
IDC is Injector Duty Cycle. in effect how close to capacity the injector is getting. you really dont want to be at 100% because after that the injector is unable to provide additional fuel but the turbo is still pushing additional oxygen in there. that'll lead to a lean condition and eventually melt some part of your engine.
there has been discussion that you can run over 100% IDC, and some people see that on their logs, but IMHO it's just really not a good idea to get up there.
as the air temp cools down, the air becomes denser and you can pack ever more into the cylinder. that means you need some overhead on IDC at normal temperatures for your area, so that when it is cold out you don't go >100%.
i dont feel comfortable enough discussing FLKC, so someone should give both of us a good overview of what it is
-scott
Old 01-08-2008, 08:58 PM   #20
quazimoto
Member#: 70395
You can bump up the base fuel pressure,rescale the injectors and end up with some extra headroom for free.
Old 01-08-2008, 10:28 PM   #21
pweizman
Member#: 131268
.... GOD........
-scott
Ah yeah...thanks.
Patrick
Old 01-11-2008, 11:09 AM   #22
gabedude
Member#: 10108
07 STI
Just an FYI. I hit 106% DC this morning and AFRs started to drift toward 12.5:1. I let off.
Run extra injector at 100% duty? sick1.8t Normally Aspirated with bolt-on Forced Induction Powertrain 7 04-04-2004 05:37 PM
maximum injector duty cycle on stock injectors? inpreza kid Normally Aspirated with bolt-on Forced Induction Powertrain 5 09-17-2003 02:10 AM
Injector Pulse Width to Injector Duty Cycle SonicWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-19-2002 09:36 AM
Injector duty cycle stays at 49%?? KillerRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-06-2002 03:28 PM
Tapping Injector to measure Duty Cycle Xeno Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-11-2002 03:56 PM
