Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 01-12-2008, 06:48 PM   #1
Evil STI
Member#: 36792
2012 TuRD
Special Edition
Default Machine shop needed for wheel offset correction.
I have a very specific set of wheels that I need to alter the offset on, in order to make them legal for SCCA Stock class. I know most manufacturers cast/forge their wheels in their specific diameters/widths, then lathe their offsets to specification accordingly.
Does anyone here know of a competent machine shop in the Northeast capable of doing this for me?
Preferably one in the Northeast, but I'm willing to have them drop-shipped anywhere in the contiguous 48 states.
Evil STI is offline   Reply With Quote
Old 01-13-2008, 04:04 PM   #2
stagex
Member#: 168949
can you give an example of what your trying to do? for example..
the machine shop will modify your 52mm offset wheels, to a 42mm offset?
stagex is offline   Reply With Quote
Old 01-13-2008, 07:20 PM   #3
Paisan
Tri-State Track Instructor
Member#: 197
335i Charity Liason
Jag XJ http://48hrs.info
I guess you want a specific wheel? I'd suggest just purchasing the proper offset rim from the get-go.
-mike
Paisan is offline   Reply With Quote
Old 01-13-2008, 07:27 PM   #4
uncle lewie wrx
Member#: 78066
uncle lewie wrx is offline   Reply With Quote
Old 01-13-2008, 07:29 PM   #5
Evil STI
Member#: 36792
2012 TuRD
Special Edition
I need a shop to remove 10mm from the hub mating surface on the back of each wheel, effectively raising the offset.
-mike
I agree wholly Paisan. The trouble is that there are absolutely NO lightweight wheels in a legal size and offset for my Honda. This is an extreme measure, but one that will enable me to use a car that I see lots of potential in H Stock class. The stock wheels are 17lbs each and I will be removing a total of 36lbs just by using the lighter ones.
Old 01-13-2008, 07:56 PM   #6
Paisan
Member#: 197
335i Charity Liason
Yeah I figured that that was the issue, the unsprung weight reduction will be nice for yah.
I always hated how the SCCA rules were written to cause you to do crazy things like you have to do in this case!
-mike
Old 01-14-2008, 12:47 PM   #7
IT Swift
Member#: 125853
2013 Impreza Sport
Red
there should be many, many competant machine shops in your area that can handle this... Just start calling around.
IT Swift is offline   Reply With Quote
Will a machine shop need my case bolts to bore/hone? CKxx Built Motor Discussion 4 02-15-2010 09:17 PM
Need a machine shop recommendation for flywheel/pressure plate balancing AnorexicSTI Vancouver Impreza Club Forum -- VIC 2 06-21-2007 04:23 PM
DFW shop needed for painting aftermarket wheels subUrbanAuthority Texas Impreza Club Forum -- TXIC 1 03-20-2007 05:44 PM
KCMO - body shop needed for hail damage Black06TR Mid West Subaru Owners Club Forum -- MWSOC 1 04-21-2006 08:29 AM
Front spacing question for wheel offset wizards subysouth Tire & Wheel 7 04-19-2003 05:11 PM
Message Board Statistics All times are GMT -4. The time now is 06:16 PM.
