Old 07-31-2013, 08:22 PM   #1
fava299
Member#: 348900
2002 impreza wrx wag
Default does this sound fine?
The car surrently has 82k on it makes the same noise as the day i got it runs and drives fine just would like some input in case something is wrong.
fava299 is offline   Reply With Quote
Old 07-31-2013, 08:27 PM   #2
jam007
Member#: 174706
2008 LGT-B
This seems a bit vague, are you asking what will be needing repair/replaced soon? If so there's maintenance intervals and tables online that will tell what needs to be done based on mileage.
jam007 is offline   Reply With Quote
Old 07-31-2013, 08:36 PM   #3
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
Save money for a rebuild. Usually with those noise problems they usually explode about 84k miles give or take a mile or two;(
boosted25 is offline   Reply With Quote
Old 07-31-2013, 09:15 PM   #4
fava299
Member#: 348900
sorry vid would not upload has to use computer.
Old 07-31-2013, 10:14 PM   #5
25rsti
Member#: 166324
Hard to really tell but from what I can hear it sounds normal.
You keep up on your maintenance?
25rsti is offline   Reply With Quote
Old 07-31-2013, 11:23 PM   #6
danger1138
Member#: 279525
04 rex luger!
Is that in a cold start? We need more details. Is the car modded? Sounds normAl to me as well.
danger1138 is offline   Reply With Quote
Old 08-01-2013, 12:22 AM   #7
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
recent timing belt change? sounds exactly like my faulty gmb tensioner.
Old 08-03-2013, 11:00 AM   #8
fava299
Member#: 348900
sprry on the late response. not a cold start run and drives fine. at what point do you do a timing belt, or any valve adjustments?
Old 08-03-2013, 06:20 PM   #9
paulpat
Member#: 237145
02 WRX
12 FXT
Use ur owners manual. Or check the maintenance section on Nasioc. Its at 90-104? Miles for timing belt. I have no idea for your heads.
paulpat is offline   Reply With Quote
