Old 01-13-2008, 11:02 PM   #1
krexx
Member#: 168723
Question Logging error ?
On Friday, I logged my car using Enginuity for stage 1, all went well. I leaned out the map a bit with EcuFlash, flashed it, and then proceeded to attempt to log using Enginuity again.
The problem I'm having is that it will connect to the ECU, say "Select parameters" at the bottom, but theres no list of parameters. Also, in the process of connecting, a red message pops up for a fraction of a second. I can only make out "Error" and "null" somewhere in the message because it only appears for so short a time.
Then I flashed the un-touched stage 1 map back on, thinking it was the map. No luck . Do I need to re-install definitions? I'm stumped (EDIT: or stupid?)
krexx is offline   Reply With Quote
Old 01-14-2008, 09:45 AM   #2
Tea cups
Member#: 103136
Sounds like your logger.xml file is corrupted. I would delete it, download the latest version (0.3.2b), UNZIP the logger.xml file into the same directory.
Tea cups is offline   Reply With Quote
Old 01-14-2008, 08:20 PM   #3
krexx
Member#: 168723
Thanks Teacup, I had figured that would fix that. Would you happen to know why my file was corrupted? I know I didn't download a corrupt one because I had logged already.
Old 01-14-2008, 08:25 PM   #4
Tea cups
Member#: 103136
No, it is just a guess. If that doesn't work, then you should uninstall Enginuity completely, re-download, and re-install.
Old 01-14-2008, 10:33 PM   #5
krexx
Member#: 168723
Yeah it didn't, doing that now.
Old 01-24-2008, 10:35 PM   #6
ix rs
Member#: 169754
where i can download Enginuity??
ix rs is offline   Reply With Quote
Old 01-24-2008, 10:40 PM   #7
Tea cups
Member#: 103136
look for the enginuity/ecuflash getting started faq in this sub-forum
Old 01-24-2008, 10:44 PM   #8
ix rs
Member#: 169754
Ok regards.
Old 01-24-2008, 10:57 PM   #9
ix rs
Member#: 169754
Enguity and tactrix cable supports older gc8 wrx??( 99-00)
error 66 or error bb ?? lastsnare Tribeca Forum 3 01-22-2009 06:40 PM
Error Reading or Logging Troganin Open Source Reflashes 12 01-14-2009 07:52 PM
Error while installing; saves stock map, then I get an error... SonicYeller AccessPort 3 05-11-2007 01:00 PM
Here's a new one: MAF Error Code -- Transmission Error scooterforever Transmission (AT/MT) & Driveline 2 10-12-2006 07:06 AM
ghetto logging. take a look at my Tari log, need help Keith Engine Management & Tuning 8 06-21-2005 07:14 AM
