Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 01-14-2008, 12:14 PM   #1
hmanxx
Member#: 104120
Default Rescaling MAFg to go beyond 300g/sec on 2.5L wrx ROM ?
I understand that 2.5L WRX STI default with MAF Voltage versus airflow gram/sec table extended beyond 300gram/sec.
For wrx ,the table stop at 4.69V..29x g/sec air..
Question...as for 32bits processor used on WRX 2.5L..the internal storage should not be limited to 300gram/sec, right ? I knew 2.0L is limited by the internal representation of maximum scaling.
If we just want to stretch the top end abit..like extend the 4.69V to 4.8V to cover the full turbo airflow range..can we just do 2 things
1) Extend the MAF airflow table.e.g add 4.8V, make room for 4.8V by dropping some low usage MAF voltage cell.
2) Change the capping from 300g/sec to a desired new value.
hmanxx is offline   Reply With Quote
Old 01-14-2008, 12:19 PM   #2
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
My MAF scale goes to 350 stock. I am able to edit it up to whatever value I want.
gabedude is offline   Reply With Quote
Old 01-14-2008, 12:25 PM   #3
hmanxx
Member#: 104120
I am talking about WRX .not STI..
YOur stock WRX map directly scale to 350 ?
Old 01-14-2008, 01:37 PM   #4
06rexwagon
Member#: 114730
2006 WRX Limited Wag
9.8@150
The 06+ WRX will go to whatever you want it to. You're thinking of the 2L rom
06rexwagon is offline   Reply With Quote
Old 01-14-2008, 01:54 PM   #5
gabedude
Member#: 10108
07 STI
32 bit ECU FTW!
Old 01-14-2008, 01:57 PM   #6
06rexwagon
Member#: 114730
9.8@150
There are tricks to get around the 300 g/s stuff.
Old 01-14-2008, 02:52 PM   #7
testes1010
Member#: 47145
2012 Gas Saver
You can use the MAF table posted here, it is a very good starting point for rescaling your MAF table to larger than 300g/s. EDIT: The flow values(g/sec) in the MAF table posted in the linked-to thread would need to be multiplied times 2.
http://forums.nasioc.com/forums/show....php?t=1363692
testes1010 is offline   Reply With Quote
Old 01-14-2008, 02:58 PM   #8
gabedude
Member#: 10108
07 STI
Yup, just halve the correct stuff.
Old 01-15-2008, 05:12 AM   #9
hmanxx
Member#: 104120
thanks alot for all the prompt reply..this should set me ready to explore the stock MAF housing size tuning for bigger turbo on 32bits SH70xx processor ecu.
I am no fan of Big MAF tuning..due to stringent local requirement..poking the wideband on the exhaust ass and running around while tuning attract too much unnecessary attention.
Having said that, I dont mean wideband is not required..just that for normal fine tuning ,we can avoid using it.
Old 01-15-2008, 09:28 AM   #10
Tea cups
Member#: 103136
This does not apply to the 32-bit ECU, which the OP has. There's no limit with these ECUs, only a capped value (usually 300 g/s) which can be raised easily. The MAF scaling table can represent any airflow value you want.
Tea cups is offline   Reply With Quote
Old 01-15-2008, 10:06 AM   #11
testes1010
Member#: 47145
2012 Gas Saver
True. I only said to use the MAF table posted in that thread as a starter. BUT I did forget to mention that the flow values(g/sec) would need to be multiplied times 2.
Stage 2 pushing it on 2.5L wrx? nikiter Newbies & FAQs 9 11-26-2008 05:50 PM
Will coilpacks from 2.5L WRX or STI fit on 2.0L WRX? gopsu Service & Maintenance 7 10-08-2008 12:31 PM
Rescaling MAFg to go beyond 300g/sec on 2.5L wrx ROM ? hmanxx Open Source Reflashes 0 01-14-2008 12:24 PM
Twin scroll on 2.5L wrx? Rock_Strongo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 10-26-2006 01:03 PM
AVo450 on 2.5L Wrx Hybrid swift2fly Proven Power Bragging 15 07-28-2006 11:25 PM
