Old 01-14-2008, 01:59 PM   #1
slo06sti
Member#: 144043
06 Stage 2 sti
OBP master tuned 298/313
Default Advance multiplier
So my buddy flashed my 06 sti yesterday with an xpt stage 2 map. We did 2 3rd gear from 3k pulls and logged them. To us everything looks fine except we logged with the values from his 02 and we were wondering why the Advance multiplier would show up as 255 accross the board. and if its related to the values we used for the log does anyone know what value to use for the Advance multiplier.
slo06sti is offline   Reply With Quote
Old 01-14-2008, 02:03 PM   #2
Tea cups
Member#: 103136
What are using to log with? Ecuexplorer?
You should use Enginuity - it will automatically determine the proper address for IAM/load and gives you access to a number of additional extended parameters not supported by other loggers.
Tea cups is offline   Reply With Quote
Old 01-14-2008, 02:20 PM   #3
slo06sti
Member#: 144043
06 Stage 2 sti
yeah we used ecuexplorer. i'll have to try it with enginuity next time.
Old 01-14-2008, 02:30 PM   #4
sense of nature
Member#: 112759
02 Srp STi...
R ur Boltz to long????
IAM should be set to 16 on 02-05 wrx
sense of nature is offline   Reply With Quote
Old 01-14-2008, 03:43 PM   #5
drkramm
Member#: 159156
2007 wrx
wrb
06 should be 1
drkramm is offline   Reply With Quote
Old 01-14-2008, 05:53 PM   #6
slo06sti
Member#: 144043
06 Stage 2 sti
we didn't alter anything from the map we got from xpt. So i should be fine then right? Also When you log IAM will it just give you the same number all the time.
Old 01-14-2008, 06:01 PM   #7
Tea cups
Member#: 103136
No, it is dynamic and changes based on knock. For your ECU, IAM would range from 0 to 1. So, for example, it could be 0.5.
Per johnnytran's request...Dynamic Advance & Dynamic Advance Multiplier Explained Christian. Rocky Mountains Impreza Club Forum -- RMIC 121 10-01-2005 08:05 AM
Ignition Advance Multiplier question gpatmac Engine Management & Tuning 50 02-28-2004 11:00 AM
Just did the Shiv advance multiplier reset thingy... Camperguy New England Impreza Club Forum -- NESIC 8 07-20-2003 07:53 PM
deltadash no show advance multiplier? Equilibrium Tuning Engine Management & Tuning 12 07-14-2003 09:04 PM
Ecutek users... what's your advance multiplier? Equilibrium Tuning Engine Management & Tuning 7 06-28-2003 05:06 PM
Message Board Statistics All times are GMT -4. The time now is 12:02 AM.
