Old 01-14-2008, 06:08 PM   #1
iamadam1122
Member#: 123748
02 BMW M3
TiAg
Default air in power steering
I have a 2006 sti. i just replaced the power steering pump, so of course there is air in the lines. i searched on ehre how to bleed out the fluid. i turned from lock to lock numerous times with the car on and off. No air bubbles or foam are in the reservoir. and the steering wheel continues to vibrate horribly if i turn it too quickly. also the front end is jacked up off of the ground. any advice would be appreciated
iamadam1122 is offline   Reply With Quote
Old 01-14-2008, 06:24 PM   #2
silver2004impreza
Member#: 127878
2004 Impreza 2.5TS
2004 Outback sedan H6
You might want to try driving in a figure 8 at low speeds for a while to see if that'll help work the air out of the power steering. I know that on the second generation Ford Exploder if you turn the wheel with the engine off, you have to go drive in a figure 8 for about 5 minutes or so to work the roughness out of the steering... Maybe it'll work on your car.
You'll need a fairly large space to drive around in, so I'd suggest an empty mall parking lot, or a school parking lot after hours or something similar.
Also, double check to make sure that you're not leaking power steering fluid from anywhere that could potentially be letting more air into the system.
silver2004impreza is offline   Reply With Quote
Old 01-14-2008, 06:32 PM   #3
iamadam1122
Member#: 123748
02 BMW M3
TiAg
ok i will try that, the only thing is that i do not want to damage this pump the same way as the first one. (driving it with air in the lines, starving the pump of fluid)
Old 01-14-2008, 07:52 PM   #4
silver2004impreza
Member#: 127878
2004 Impreza 2.5TS
You're not going to be driving it for extended periods of time. Just take a couple of bottles of fluid with you (IIRC Subarus use standard ATF) and make sure that you keep the reservoir topped off.
Now that I think about it, are the lines from the reservoir flowing freely? They aren't pinched anywhere are they? You might want to check that too.
Old 01-14-2008, 09:24 PM   #5
drewzter
Member#: 39879
2008 Infiniti G37S
Graphite # 73 FS
It's cause it's off the ground. With the front end off the ground it is going to do that all day. Put it on the ground and drive like the other posts said.
drewzter is offline   Reply With Quote
Old 01-14-2008, 09:49 PM   #6
iamadam1122
Member#: 123748
02 BMW M3
TiAg
yes, i just drove it around, its fine. thanks for the help everyone.
Old 01-15-2008, 12:18 AM   #7
Web Foot STi
Member#: 39086
2004 STi
A nice upgrade is Moble 1 ATF.
Web Foot STi is offline   Reply With Quote
Old 01-15-2008, 04:09 PM   #8
drewzter
Member#: 39879
2008 Infiniti G37S
Graphite # 73 FS
+1 for that. Holds up to heat better. Almost required for AutoX in FL
Can you reduce the "power" in power steering? bboy Brakes, Steering & Suspension 17 12-08-2012 11:54 AM
Fix for air in Power Steering MasterKwan Brakes, Steering & Suspension 2 04-04-2009 09:52 AM
Air in power steering line? imisplacedmine Service & Maintenance 2 04-21-2008 03:12 PM
differences in power steering failure ryzies Service & Maintenance 7 01-10-2007 06:41 AM
Small amount of antifreeze in power steering ftt Service & Maintenance 1 04-28-2006 08:48 PM
