Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 01-14-2008, 07:39 PM   #1
PERRIN_Ken
Member#: 165212
Blaze Yellow
Default Perrin BugEye 15K Stealth Exhaust DIY
We just finished road testing our Stealth Exhaust system and let me tell you this thing looks cool. The whole yellow and black combo that we have is very nice.
By adding the PERRIN Exhaust System you will not only gain performance but you also get the added pleasure of listening to the boxer engine as you run around town. The results can be felt and heard the second you take off from your house. For more information click here.
Needed tools:
1) Jack and Jack stand
2) Socket or wrench
3) WD-40 or other lubricant to use on the hangers
Step 1) Raise the vehicle to a desired height allowing for enough room to move freely. For this you will want to use jack stands to support the vehicle while working on the exhaust. NEVER WORK ON A VEHICLE SUPPORTED ONLY BY A JACK.
Step 2)Time to remove the stock exhaust from the car. To do this I used a lubricant on the hangers helping to make things go quicker. Once the hangers were loosened I decided to remove the exhaust from all of the hangers except for the one on the drivers side rear muffler. This way I could remove the OEM spring bolts from the down pipe and not have the exhaust fall on my head (very important not to hurt yourself).
Once the sprig bolts and springs are removed from the down pipe carefully lower the stock exhaust system to the floor. You can now go back and remove the system from the last hanger. I recommend re-lubricating the hangers one more time before you install the PERRIN exhaust.
Step 3) Time to install the PERRIN exhaust, there are two way to go about doing this. The first is to install the front section to the down pipe (if stock down pipe is being used, use the OEM spring bolts and springs to secure the system to the down pipe. If the PERRIN Down Pipe is being installed at the same time use the provided springs and bolts from PERRIN). Once the front section is in place you can then install the rear muffler section.
The second way to install the exhaust system (what I did) is to completely assemble the PERRIN system. To do this you will want to install the front section and rear muffler section on your garage floor. Using the included 3” Gasket and the bolts and washers connect the two pieces and tighten to 25ft-lbs of torque. Once everything is in place secure the muffler to one of exhaust hangers and then connect the front section of the PERRIN exhaust to the factory down pipe with the OEM spring bolts and springs. For this I recommend slightly tightening them up allowing you to go back and connect the exhaust to the rest of the hangers.
With the exhaust now suspended from the hangers you can go back and fully tighten the front section to the down pipe.
Step 4) Lower the car back to earth and give her a test. Be sure to check for leaks prior to driving the vehicle. (DO NOT START THE CAR IN AN ENCLOSED AREA AS DEATH CAN RESULT FROM CARBON MONOZIDE POISONING)
If you have any questions or would like more information on our exhaust system or other PERRIN items feel free to contact me at anytime.
Hope you enjoyed my DIY
Ken
Ken Jubb
Sales
PERRIN Performance™
AIM: perrinsales4
1-503-693-1702 Ex. 113
WWW.PERRINPERFORMANCE.COM
PERRIN_Ken is offline   Reply With Quote
Old 01-16-2008, 02:00 AM   #3
PERRIN_Ken
Member#: 165212
Blaze Yellow
Old 01-16-2008, 10:47 AM   #4
Bluestreak2006
Member#: 140536
93 MR2 Turbo
Turq Pearl
Can you PM me the the super special NASIOC pricing for this catback?
Bluestreak2006 is offline   Reply With Quote
Old 01-16-2008, 11:38 PM   #5
SQC120
Member#: 39677
2008 Land Rover
02 WRX
lol i just noticed that you guys are located in Portland, OR. Saying Hi from another blaze yellow owner located in Portland, ME :P
That ride is going to be superb!
i am so glad that the car landed with Perrin!
Keep us posted
(PS what kind of benefits are you guys getting w/ the crank pulley?)
SQC120 is offline   Reply With Quote
Old 01-17-2008, 10:32 AM   #6
PERRIN
NASIOC Manufacturer
Member#: 6776
PERRIN is offline   Reply With Quote
Old 01-17-2008, 06:34 PM   #7
PERRIN_Ken
Member#: 165212
Blaze Yellow
Keep us posted
Its nice to see another Blaze Yellow out there. I have to say that the improvement from the crank pulley is felt the second you get on the gas.
The PERRIN Crank Pulley is 4-pounds lighter than the stock crank pulley. This reduction is equal to removing more than 100 lbs of vehicle weight.
Thanks for the question
Ken
Ken Jubb
Sales
PERRIN Performance™
AIM: altaperrinsales4
[email protected]
Old 01-18-2008, 09:08 PM   #8
vecdran
Member#: 162932
This has got to be the sexiest exhaust I have ever seen. This thing would fit perfectly for the theme I am going for on my bugeye. You guys planning on stealthing the dual tip too?
Are video clips going up soon? Preferably of the street version (and cats are even better), I love the way this exhausts looks and the tone is incredible, but I don't particularly want the massive volume
Edit:
Found one of your clips on youtube. Is that street or sport? Mic was a bit muffled, know what dB it goes to?
http://youtube.com/watch?v=53aB3cKXi9E
vecdran is offline   Reply With Quote
Old 01-19-2008, 11:16 AM   #9
PERRIN
NASIOC Manufacturer
Member#: 6776
Edit:
We can do ANY of the systems in Stealth coating. We released the singles first, but KEN is happy to help on that request. Might take 7 days to get it done. No big deal.
That is the sport stealth with cats. Sounds AWESOME! I have ridden in the car several times after selling the car to Ken and I must say it is a great addition to the car!
Let Ken or I know how we can help further!
[email protected]
Old 01-19-2008, 06:00 PM   #10
BuggeyEYED
Member#: 101691
97 Supra TT
SOLD - 35r bug/hawkeye
looks good!
BuggeyEYED is offline   Reply With Quote
Old 01-21-2008, 11:18 PM   #11
Le Saboteur
Member#: 142244
2007 SWP STi
WFC #243
ballllin'
Le Saboteur is offline   Reply With Quote
Old 01-26-2008, 01:55 PM   #13
PERRIN_Ken
Member#: 165212
Blaze Yellow
The new PERRIN Stealth Exhaust system is made with a thermal powder coating process, we created an entire new look for the system. And as you can see from the pics its definitely cool looking.
If you don't want to draw attention to what would have been a bright and shiny exhaust system, then this if for you. The thermal coating not only locks heat in the system to increase exhaust scavenging and flow, it also prevents excessive heat build up under the tunnel of the car. SOUND CLIP
Best of all this system prevents unwanted attention from your local law enforcement as well!
If there are any question on the system or how to install it please let me know.
Best,
Ken
Ken Jubb
Sales
PERRIN Performance™
[email protected]
Old 01-30-2008, 12:59 AM   #14
rcdrivercrl
Member#: 170320
hello Ken, do you guys have any tbe that gains power(like 15-20hp)but quiet? and how much would it cost to ship it to vancouver bc?
i really like your products and please upload more videos on youtube, thank you.
rcdrivercrl is offline   Reply With Quote
Old 01-30-2008, 02:28 AM   #15
kookaburrabomb
Member#: 145297
07 2.5i
I know its not what most people would ask, but what is the loudest exhaust that Perrin sells that could be stealth coated? I love Perrin products, but I want the best of both worlds.
Awesome project, very inspiring. Keep up the good work boys!
kookaburrabomb is offline   Reply With Quote
Old 01-30-2008, 11:21 AM   #16
PERRIN
NASIOC Manufacturer
Member#: 6776
Complete TBE typically dyno out at around 20WHP gains on 2 l. I will Pm you a quote going to Vancouver BC. Thanks for the heads up on the YouTube stuff. We will get on it!
[email protected]
Old 01-30-2008, 11:33 AM   #17
PERRIN
NASIOC Manufacturer
Member#: 6776
Thanks for asking!
Just got word that Project 15K had a bit of a spill this morning in the snow! Apparently the ultra sticky tires aren't the best match for 31 deg and 1 inch of snow. So the Project is either on TEMP hold or PERMANENT hold pending and investigation of the damage. Stay tuned!
On the Exhaust. The Sport-Tone would be the loudest option available. And everyone has their own tastes so no problem!
Let me know if you would like one quoted for you!
[email protected]
Old 08-11-2008, 11:05 PM   #18
Bdon23
Member#: 124014
2002 Subaru Impreza
Hey sorry been out of the loop for a while, but Are you going to offer this in a dual tip form?
Bdon23 is offline   Reply With Quote
Old 08-12-2008, 12:37 AM   #19
PERRIN
NASIOC Manufacturer
Member#: 6776
The stealth? Sure we can do that! Just let us know!
Thanks!
Old 08-16-2008, 03:51 PM   #20
AWheele
Member#: 187086
2005 WRX Stg. 2
Awesome
AWheele is offline   Reply With Quote
Old 09-06-2008, 05:47 PM   #21
mattakacas
Member#: 188746
2003 Impreza WRX
Sonic Yellow
Very nice!
mattakacas is offline   Reply With Quote
Old 09-07-2008, 03:37 PM   #22
PERRIN
NASIOC Manufacturer
Member#: 6776
Originally Posted by mattakacas View Post
Very nice!
Thank you! These have been really popular with the California owners due to the stringent exhaust laws down there, this has allowed a literally "stealthy" installation and use!
Old 09-17-2008, 06:56 PM   #23
PERRIN_Ken
Member#: 165212
Blaze Yellow
Here is a sound clip and video of the system (not the stealth)
MORE INFO AND SOME DEALS........
Clip of the stealth system (filmed during a cold Oregon morning)
Thanks
Ken
Ken Jubb
Retail Sales Manger
PERRIN Performance™
503.693.1702 Ex. 101
WebsiteBlogMyspaceE-mailAIM
Old 09-28-2008, 11:28 PM   #24
kbg1998
Member#: 189854
sounds excellent!
kbg1998 is offline   Reply With Quote
Old 09-29-2008, 04:13 PM   #25
PERRIN_Ken
Member#: 165212
Blaze Yellow
Thanks,
Let me know if you have any questions.
Ken
Ken Jubb
Retail Sales Manger
PERRIN Performance™
Perrin Performance Stealth Exhaust Diy PERRIN_Ken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 03-15-2016 10:55 PM
Pics of Perrin Stealth Exhaust rampagepb Member's Car Gallery 0 05-10-2010 03:30 PM
WTB APEXi WS Noir Catback Exhaust or Perrin Cat-Back Stealth Sport System damnedhooligan SCIC Private Classifieds 13 01-24-2009 03:08 PM
WTB: Perrin Stealth Exhaust Andrew06WRX Private 'Wanted' Classifieds 0 08-12-2008 06:18 PM
PERRIN - Project 15k, Selection Process and Cleaning PERRIN_Ken NASIOC Project Cars 3 06-10-2008 09:34 AM
