Welcome to the North American Subaru Impreza Owners Club Thursday April 28, 2016
Old 01-06-2008, 04:19 PM   #1
wage0052
Member#: 127556
2006 WRX
RomRaided.
Default '06 Stage 2 WRX, logged AFR not matching map targets
I installed an LC-1 with XD-16 WB02 gauge a couple weeks ago. The first thing I noticed was that my car was running quite rich under load. The map values were calling for around 11:1 AFR's, and the car was down at around 9:1 at peak torque and 8.5:1 at redline. Idle and cruise AFR's were steady fluctuating right around 14.7:1.
This was somewhat surprising, as the car seemed to run well and did not stutter or hesitate at all. In addition, the car seemed to behave normally in boost, which hit targets, and did not waver at all.
After spending a lot of time checking for boost/exhaust leaks (of which I've found none), and re-calibrating the WB02 sensor (gauge and logs showed the same values after re-calibration), I decided to simply try leaning out the target AFR tables.
After leaning out the high load target AFR tables by around 2 points, the car now hits right around 10.8:1 during peak torque, and 11.3:1 at redline. The map values now call for 12.3 and 13 AFR respectively.
My first instinct would be to chalk this up to some type of leak, but I can't seem to find any other behavior that is out of the norm (boost seems to behave perfectly normal), other then the fact that actual AFR doesn't match the map targets.
Has anyone seen similar behavior? If this may be caused by a leak, where specifically should I be looking? Is my car just a freak?
Relevant information:
06 WRX
TXS Stealthback exhaust
Maddad Whisper axleback
GMBCS
Thanks.
wage0052 is offline   Reply With Quote
Old 01-06-2008, 05:34 PM   #2
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
It could be caused by a boost leak, but then you would notice either lower boost or really high wgdc to hit target boost.
Sounds like you need to tune the MAF calibration. Where logged AFR is lower than target, you need to lower the MAF calibration. The ecu thinks it's getting more air than it really is.
Try airboy's spreadsheet, it will graph everything and show the AFR error against maf voltage.
ExpO is offline   Reply With Quote
Old 01-06-2008, 06:20 PM   #3
wage0052
Member#: 127556
2006 WRX
RomRaided.
Hrm, is this something that is normal even with the stock intake? I am running a foam filter (and not the stock paper filter).
Old 01-06-2008, 08:04 PM   #4
Airboy
Member#: 72829
2006 WRX
2015 WRX
The foam filter is oiled, right? The oil will mess up your MAF readings. Clean it with some isopropyl alcohol. The sensing element (wire) is up inside the "tube" and not the little resin bulb next to the tube.
Remember to flash back to the 11AFR map after cleaning the MAF or you may get a nasty surprise.
Do you have the means to collect data logs?
The stock '06WRX intake ran lean on my car.
Airboy is online now   Reply With Quote
Old 01-06-2008, 11:19 PM   #5
wage0052
Member#: 127556
2006 WRX
RomRaided.
Yeah, the foam filter is oiled. I guess I wasn't aware that an oiled filter can skew things that much..
I've got some MAF cleaner that I've been using regularly to keep the MAF clean. I'll toss in the paper filter and clean the MAF and see what happens.
Yeah, the numbers cited previously are from datalogs. Other's that I've talked to have said the same thing, that the '06 runs just a tad leaner then map targets.
Old 01-08-2008, 02:00 PM   #6
wage0052
Member#: 127556
2006 WRX
RomRaided.
Well, I cleaned the MAF and tossed on the stock paper filter. No change in logged AFR. The car is still running ~2.0 points richer then the map calls for. Idle and cruise AFR's are still in range.
It seems like I can rule out a boost leak (as boost seems to behave normally), where else (would have to be post-MAF) should I be checking for a leak, and what would be the best way to check?
One additional thing of note: I get the impression that WOT/high load AFR seems to be bouncing around more then normal. This would be in indication of a leak, correct? I'll grab some logs to toss 'em up tonight.
Old 01-08-2008, 02:13 PM   #7
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
I have never seen a DBW Subaru match real world AFR with the fuel map targets from the factory. So no, your car is not a freak.
Master2192 is offline   Reply With Quote
Old 01-08-2008, 02:29 PM   #8
wage0052
Member#: 127556
2006 WRX
RomRaided.
Ok, fair enough. But is a 1.5-2 point difference common?
Old 01-08-2008, 09:20 PM   #9
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
where did you tap the sensor to?
txl146 is offline   Reply With Quote
Old 01-08-2008, 09:40 PM   #10
wage0052
Member#: 127556
2006 WRX
RomRaided.
The sensor is in the downpipe, around 15" from the turbo.
Old 01-09-2008, 08:14 AM   #11
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Just a thought, but check in LM Programmer for the WBO2 that you have the correct fuel specified. The AFR is merely a representation of the ratio based on the fuel that you have selected. The WBO2 actually measures lambda.
blkscooby is offline   Reply With Quote
Old 01-09-2008, 12:27 PM   #12
wage0052
Member#: 127556
2006 WRX
RomRaided.
Yeah, the LC-1 has the 14.7:1 (Gasoline) fuel type selected. Many of the guys local to me seem to be convinced the cause is simply a the car running off from the fuel mapping. It's been suggested that raise the injector scalar to bring the open loop map and logged AFR values closer. I may try playing with that this weekend.
Old 01-09-2008, 12:40 PM   #13
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Yup, in my experience anyhow. On a 05 STI I had to take the fuel map out to the 13s to get the AFR to 12.5 (101 octane tune), while on a 07 STI the fuel map says low 10s to get the AFR into the mid to high 11s. I just tune for real world AFR and don't worry about the differential unless I am running out of resolution. It takes a long long time to manually smooth the MAF table to get the AFRs to match and even at that if you change the targets in the fuel map later it won't equal the same 1:1 change in real world.
Old 01-09-2008, 03:21 PM   #14
carnz-pj-410
Member#: 110994
2004 Aspen White
Is The Best
where can i get a copy of airboys spreadsheet for the maf
carnz-pj-410 is offline   Reply With Quote
Old 01-09-2008, 04:40 PM   #15
wage0052
Member#: 127556
2006 WRX
RomRaided.
OK, good to know. For the reasons you stated, I am hesitant to re-scale the MAF, as in this case, it would most likely be more of a headache then worthwhile.
The current resolution is adequate, but I was simply concerned, as a 2 point differential seemed like a high tolerance for a car with the stock airsystem.
Thanks much for the info!
Old 01-13-2008, 03:17 PM   #16
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Mine is 1.1 different from whats in the map. i.e. when Im targeting 12.1 during boost onset, Im actually getting 11.0.
I think 06rexwagon had the same thing if I remember correctly. Ive seen two other 06's where the fuel maps didnt match the actual AFR's as well.
cucamelsmd15 is offline   Reply With Quote
Old 01-13-2008, 04:08 PM   #17
wage0052
Member#: 127556
2006 WRX
RomRaided.
Yeah, after talking to a number of '06 WRX owners/tuners, it appears like there is a fairly large tolerance around the stock fuel table, and what I'm seeing is fairly normal.
For anyone else researching this issue: In open loop, my car is right at 1.5 points richer then target.
Old 01-15-2008, 07:54 PM   #18
turboge
Member#: 35076
2004 507whp Wagon
If you have the stock MAF housing you can update your MAF scaling pretty quickly to adjust your AFR to match targets. Probably take about 3-5 WOT runs and a few flashes.
Easiest way to do it is log RPM, MRP, MAF v, EL, and WBo2. I generally log MRP to show changes in onset fueling which is tough to dial in. But once that is stable you can modify the voltages on the MAF table to fall in line. Add voltage to lean it out, subtract to richen.
I would recommend setting your Target fuel to 11:1 from 2800-redline during this time to keep the maf tuning easy, then adjust your fuel curve after the MAF is dialed.
turboge is offline   Reply With Quote
Old 01-15-2008, 11:14 PM   #19
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
I disagree. For open loop, it takes 2-3 pulls if you have an idea of the compensation required for a given % error. In my experience, it allows for damn near a 1:1 change in real world.
Last time I did my afr's I ran a 10.5-10 map, scaled the maf, then bumped it to 11.5-11 with no issues.
Doing it this way also eliminates the possibility of a rich/lean run if your load/rpm cell goes into a part of the fueling table in which you haven't logged the afr error.
Anyone know for sure if there are any other compensations that apply or use either table?
Old 01-16-2008, 01:19 PM   #20
wage0052
Member#: 127556
2006 WRX
RomRaided.
Yup, I plan to give the MAF scaling tool integrated with Enginuity beta 785 a shot when I get a chance, and playing with OL by hand.
Old 01-16-2008, 02:01 PM   #21
testes1010
Member#: 47145
2012 Gas Saver
+1.....& yes a 1.5-2 point AFR difference is normal for DBW subaru's.
I use an unorthodox way of correcting this that most don't do BUT I've used it on just about every car I've tuned & its worked flawlessly. I see jacking w/ the MAF table as a last resort.
Instead of jacking w/ the MAF table, raise the injector scalar. My reasoning, if you jack w/ the MAF tables you'll end jacking with more tables, most of them that include the Load reference values.
By raising the injector scalar you are linearly raising the fuel table. I'd start by dropping the AFR back down to a ~11.0:1(assuming you are on 93octane) at peak load, then raising the scalar 20-30cc/min since your tailpipe is ~2 points off of matching the AFR table. This is generally the first thing I do when tuning a car.
testes1010 is offline   Reply With Quote
Old 01-16-2008, 02:24 PM   #22
benw
Member#: 103320
1998 swapped
Forester L
testes,
does this apply to DBC or only DBW cars? Interesting approach.
benw is offline   Reply With Quote
Old 01-16-2008, 02:28 PM   #23
testes1010
Member#: 47145
2012 Gas Saver
Originally Posted by benw View Post
testes,
I do this as well on non-stock injector DBC cars. Typically stock injector DBC cars are within 1.# AFR.
Old 01-16-2008, 03:09 PM   #24
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Testes, if the injector scaling is the actual problem, then fixing it rather than MAF scaling is the correct thing to do.
However, if the AFR targets weren't being met because the MAF scaling was off, then in stock form you're getting bad load data anyway. Fixing the MAF scaling would fix both the AFR targets AND give you correct load data.
The real question is what's wrong in the stock tune.
Old 01-16-2008, 03:24 PM   #25
testes1010
Member#: 47145
2012 Gas Saver
We can all agree that the stock tunes are a joke.....especially the newer cars.
Logged target boost does not match map STIlin' Open Source Reflashes 1 04-15-2009 12:10 AM
Stage 2 WRX map enginuity HKSpowerWRX Commercial ECU Reflashes 3 12-04-2007 12:12 AM
Stage 2 WRX looking to go back to the stock map-Questions.. SubbieAndCoop Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-14-2007 09:22 PM
06 Stage 2 WRX PDXtuning map drmichael North West Impreza Club Forum -- NWIC 11 10-20-2006 05:56 PM
PDX Maps for 06 Cobb Stage 2 WRX sleestak6326 TXIC Private Classifieds 15 07-23-2006 10:34 AM
