Old 01-07-2011, 02:30 PM   #76
NYJets
Member#: 269127
Sorry to bring this thread back but I have been searching and searching ALL over the internet.
I am having some serious issues burping this 05 WRX 88k.
The only thing that differs me is that I have no heat in the cab at all!
I flushed the heater core, came out clean fully.
Brand new Subaru brand thermostat, coolant, conditioner, mixed with distilled.
I get car hot, put funnel in top turbo res., fills up the funnel, and sucks it in. Massaging all hoses, bleeding every way possible.
Heat gets hot at idle, temp stays normal. The when I drive it everything same, and when I come back to a stop at idle, I LOSE heat and temp guage goes UP.
Please somebody help me, I have been all over different Subaru forums to no avail. I have trying burping it everyway i have read, tried 3 different thermostats, ad Have drained it multiple times.
Thank you,
Cody
NYJets is offline   Reply With Quote
Old 03-04-2011, 10:34 PM   #77
wombatsauce
Member#: 31550
WorldRallyDirt
I am having a similar problem with a 1998 2.5RS I just bought. It seems to burp fine per the SOA manual and then after doing that twice and watching the level settle in the reservoir over night, take it for a drive and around 20minutes you lose heat in the vents, temp gauge shoots up and the last time the reservoir overfilled and overflowed. As it cooled it sucked all the coolant back into the system - sucked the reservoir dry. I have no idea what is going on.
I drove it around 250 miles with no problems and then decided to change the coolant and the thermostat. The "coolant" looked like crap and the thermostat was physically broken. I replaced all with Subaru parts, and today replaced the radiator cap.
wombatsauce is offline   Reply With Quote
Old 03-07-2011, 11:22 AM   #78
NYJets
Member#: 269127
Well I have done everything in my power and knowledge to fix it, no avail. Brought it this morning to the shop for a water pump, machine flush, and along with that timing belt/tensioner and plugs....
Old 04-13-2011, 10:43 AM   #79
exigex
Member#: 236304
how does this sound (2005 2.5RS with 37,000 miles):
Drive the car for 60 miles on the highway with inside temp set to cold and the car runs perfectly, engine temp right were it is supposed to be.
Ride home at night 60 miles on the highway with the inside temp of the car all the way in the hot position and the car runs perfectly with engine temp were it is supposed to be.
then when i pull onto my road i turn the inside temperature to all the way cold inside the car and pull into my driveway and by the time i open the garage and pull in the engine temp is going up fast and the coolant overflow is boiling over.
i shut the car off and open the hood and hear the coolant being sucked back out of the overflow tank rapidly, can actually see the top radiator hose compress and decompress slightly as it is moving a lot of coolant fast.
so the only time the engine temp rises and coolant boils over is when the temperature inside the car is changed from hot to cold, except for the the car runs perfectly all the time, what would cause this a faulty thermostat?
I am going to flush the coolant system, new thermostat, new hoses, and new radiator cap soon.
exigex is offline   Reply With Quote
Old 04-13-2011, 09:16 PM   #80
silver2004impreza
Member#: 127878
2004 Impreza 2.5TS
2004 Outback sedan H6
Personally, I use an Airlift when I have to do cooling system work. If you do this kind of work for a living, it's worth it's weight in gold. The gauge on it measures vacuum.
Last edited by silver2004impreza; 04-13-2011 at 09:18 PM. Reason: Found a better video
silver2004impreza is offline   Reply With Quote
Old 04-14-2011, 09:59 AM   #81
NYJets
Member#: 269127
Radiator caps!!!
I posted this on another forum. Please see:
Just saved about 1500$ and one large(r) headache. Heres the story...
About a month ago, driving my 05 WRX (exhaust, STI turbo/IC, intake, injectors, 90k). I was driving up a pretty good hill, and at the top I see my temp gauge spike to the red. I cool down, bring home, and next day I do thermostat/rad flush, all with name brand parts/subaru spec. Had a hell of a time(to put it nicely) trying to bleed system, driving myself nuts. Finally seem to get it right and driving about 2 wks...no problems.
Then car does it again. temp gauge does what it wants, mostly going up on hills and at idle after a drive, and heat in cab comes and goes as it pleases. Pushes water in reservoir tank, sucks it dry. Had system pressure tested and it fine.
Stress level at a maximum now. So i decide to go ahead and have a mechanic do water pump, timing belt, flush and check what he can. $980 later car seems fine from shop, till i get it home. Pulls same stunt.
At this point I am thinking headgasket. Not fun. At all.
I had some radiator caps ordered from Subaru (btw $35 for the two, holy hell).
I put them on and BAM, problem fixed(as of now).
LESSON:
If your having overheating problems, CHECK YOUR RADIATOR CAPS!!
I do still have some problems with my gauge acting funky, usually after a drive it bounces a bit and moves up, and sometimes on hills. My guess would either be the sender got messed up somewhere in the process, or it is airbound somewhere in the system. I personally think subaru was completely retarded when designing the cooling system with no actual bleeder or anything of the sort.
Old 07-15-2011, 04:24 PM   #82
jonyblaze87
Member#: 259245
Originally Posted by NYJets View Post
Radiator caps!!!
LESSON:
i had a similar problem to what your explaining ans simultaneously i had some hairline fractures in my radiator housing. so i when with a full aluminum mishimoto replacement, new thermostat and new rad caps... everything runs a bit cooler and much better, haven't had any issues
jonyblaze87 is offline   Reply With Quote
Old 08-28-2011, 04:03 PM   #83
rally me
Member#: 100127
02 WRX wagon
Default words to live by LOL
DON'T GIVE UP! KEEP MASSAGING YOUR HOSES UNTIL YOU GET ALL OF THE AIR OUT! IT MAY TAKE A VERY LONG TIME!!
my upper radiator hose failed so i replaced it. the temperature still was not in the norm. only after doing a breif search did i find this little nugget of information. thanks. after all the years this site still rocks
rally me is offline   Reply With Quote
Old 08-29-2011, 11:30 AM   #84
subaru_sti_steve
Member#: 289798
94 Ranger Truck
world rusty blue
Snap your throttle while the cap is off it shouldn't take you more than 10 minutes or so
subaru_sti_steve is offline   Reply With Quote
Old 08-29-2011, 02:05 PM   #85
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
Plus this.
I just fully flushed the my entire coolant and this is what I did.
Fill up the entire fill spout with coolant. Once that's done I filled up the actual radiator with coolant. Put the cap back on the rad and then started to sqeeze the top coolant hose. This cause the fill resovoir to burb and then sink/drop coolant level. Keep filling and burping... etc. It will get to the point where the upper rad hose is completely filled with coolant at which point the fill res will no longer drop in coolant. Turn the car on... as it heats up you will see that the coolant starts to raise in the fill resorvior... as soon as it starts to come out of the actual resovoir I cap it and tighten it down... At which point I let the car run until the fans kick on. Shut the car off and then check the overflow tank. Make sure it's at FULL and then I am done.
I've NEVER had an issue with air in the system at all by doing this method. I've done this at least 7 times now and each time it is the same and I never have to try and get trapped air out because there isn't any.
Hope this helps with some issues that people have.
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 08-30-2011, 02:30 AM   #86
subaru_sti_steve
Member#: 289798
94 Ranger Truck
world rusty blue
Or you can use a speciality tool called a radiator air lift tool to put cooling system under vacuum and open valve and bam automatically sucks in coolant and no air bubbles
Old 08-30-2011, 02:40 AM   #87
Evilchargerfan
Member#: 183529
i wanna help teh
haters ... love life ...
^^^ how much does one of those run?
Evilchargerfan is offline   Reply With Quote
Old 08-31-2011, 02:15 PM   #88
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
A radiator air lift tool sounds keen but probably expensive. Plus the cost of the air compressor to drive it unless you already have one. I use a $.99 small blue funnel. I have customized this funnel for this specific purpose by cutting the neck short so it doesnt extend overly far into the coolant box. I place the funnel in the rad cap hole and as I squeeze the rad hose coolant goes up the funnel; air comes out. I release the rad hose; coolant goes back down the funnel sans air bubbles. This allows me to burp the coolant system completely free of air without spilling by merely by repeatedly squeezing the rad hose for about 15 minutes. One trick I have found is to turn the engine off every 5 minutes, burp the coolant and then restart the car. This allows more air to work its way out of the system because air cannot float to the surface very easily when the water pump is pulling it down. It will collect in a location in the coolant system until waterpump stops then it will try to float to the surface. As the coolant heats up the air bubbles expand allowing some of them to escape.
My GF8 has a similar joylessly designed single cap waterbox coolant system to the GD ej20. It is such a joyless design because without a Rad cap on the radiator its damn difficult to make sure the system is free of air.
I also have a tale of warning. I recently replaced the turbo on my wrx. I replaced it because the seals went bad and were pushing compressed air from the turbo into the coolant lines. This was causing excessive pressure to form in the coolant system which was causing an overheating issue. It would begin to overheat everytime I would run any amount of boost and the top rad hose would have so much pressure it would be rock hard. Initially the issue occured running over 5psi of boost and then escalated to running any amount of boost.
The failed turbo in question was some kind of custom ported job that previous owner installed prior to me owning the car. Likely an ebay special because it lacks manufacturer and model stamps on the housings. The new turbo is a ported oem with nice mitsubushi stamps.
As soon as I replaced it my overheating issues went away. Air expands from heat far more quickly than coolant. Introducing bonus air to the coolant system fracks everything right up.
FYI
Synopsis:
$.99 small funnel good. bogus crap ebay turbo bad.
TommyAtomic is offline   Reply With Quote
Old 09-04-2011, 04:56 PM   #89
Mikal92
Member#: 290668
2011 STI
Plasma Blue
as said before im with check the cap
Mikal92 is offline   Reply With Quote
Old 12-29-2013, 07:58 PM   #90
bwc
Member#: 102279
05 WRX SW
my radiator is lowering the water, do not have any leaks. could be the radiator cap?
bwc is offline   Reply With Quote
Old 12-29-2013, 09:27 PM   #91
25rsti
Member#: 166324
Could be HG.
Old 12-31-2013, 09:00 AM   #92
Jgilbs06
Member#: 361145
I would put it up on ramps or stands and rev your engine leave it on the stands if possible overnight. YOu should have no air in the system when you are done. Worked for me yesterday when I was flushing coolant.
Jgilbs06 is offline   Reply With Quote
Old 01-09-2014, 08:18 AM   #93
bwc
Member#: 102279
05 WRX SW
Originally Posted by 25rsti View Post
Could be HG.
headgasket?
Old 01-04-2015, 08:46 PM   #94
Impressive_Impreza
Member#: 293493
2004 WRX
Red
Just wanted to add something. I recently did my timing belt and water pump so i had to replace the coolant in the system. Anyways after getting everything back together and tight i took it out for a test drive. Turns out i didn't get all the air out the system and my upper radiator hose blew off of the radiator and was resting on the alternator pulley, the pulley ended up cutting my upper hose in half. there was smoke and coolant every where i couldn't see out of my windshield driving 65mph on 485 hwy, had to pull over with my head sticking out of the drivers window it was nucking futs. Lesson learned be patient and bleed the air system. I know the upper hose was snug down good so that air pocket was insane.
Impressive_Impreza is offline   Reply With Quote
Old 03-24-2015, 02:10 PM   #95
zkhennings
Member#: 393895
2002 Impreza WRX
I have filled the system a few times now with no problems and no need to add coolant later.
I have an 02 so I don't have a radiator cap on the radiator, only on the turbo reservoir.
After I drained the coolant and reinstalled the hoses, I kept the upper hose attached to the rad but not the crossover. I filled the rad this way until it was full. Then I reattached it to the crossover. Then I filled the engine from the turbo reservoir until it gets to the top.
Then I squeeze the rad hose repeatedly so the coolant level rises to the top of the turbo reservoir (TR). I let go sharply and bubbles will rise and the level will go way down. I keep adding coolant this way until it stops working.
Then I leave the cap off the TR, turn the heater on full, and start the engine. I let it idle for a while until the fans kick on as I squeeze the upper rad hose and add coolant to the TR. This guarantees the thermostat is opening.
THEN once that stops allowing me to add more coolant, I grab the throttle body and rev the car, then stop and squeeze the hose, then rev, then squeeze, add coolant if it needs it.
Then I am done and I never have overheating problems and never need to add more coolant. Takes maybe half hour tops.
I like to shove a small cheap funnel into the TR hole so when the coolant level rises too high it doesn't spill everywhere. It helps really determine when the engine stops sucking in more coolant too.
I know this thread is mad old but I wanted to add my .02 and it has never failed for me and with multiple WRX's
zkhennings is offline   Reply With Quote
Old 07-27-2015, 08:46 PM   #96
gulps
Member#: 426230
For you all Subie experts
please help
https://www.youtube.com/watch?v=5675YMkr9R4
EJ22 internal HG leak?
- New t-belt kit + Aisin water pump + Stant XSTAT t-valve + new radiator + new hoses (including heater) + new coolant
- Car don not overheat, coolant bubbles and foam are seen at operating temp, but no bubbles in the expansion tank.
- When fans turn on, level suddenly drops as showed (i guess it's normal)
- Coolant expansion tank level self rose far above the max line.
Other:
- No smoke on the tail pipe
- Small oil leak underneath, not sure where from (goes all the way down to the oil pan, but no serious dripping and head gaskets are apparently fine from the outside)
gulps is offline   Reply With Quote
Old 07-28-2015, 09:06 AM   #97
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
Get a Lisle funnel from Amazon for 25 bucks. Put on car for filling radiator. Run car with heat on until fans come on. This can take up to thirty minutes depending on the temperature. Watch bubbles come out.
Ernest is offline   Reply With Quote
Old 07-28-2015, 09:27 AM   #98
gulps
Member#: 426230
Thanks. Just running the car yesterday without the rad cap and letting the bubbles come off seems to have solved a squash sound behind the dashboard. Took the car for a run this morning and no coolant rising or bubbles n reservoir tank. This video was shot yesterday, few minutes before the other posted above: https://youtu.be/E453F6gwOoE
I'm a pessimist, probably just air trapped inside. Will watch closely from now.
Old 07-28-2015, 09:43 AM   #99
Evilchargerfan
Member#: 183529
i wanna help teh
+1 in the lisle funnel, makes life so much easier. best $25 ive ever spent
Amazon.com: Lisle 24680 Spill-Free Funnel: AutomotiveAmazon.com: Lisle 24680 Spill-Free Funnel: Automotive
Old 08-13-2015, 09:21 PM   #100
wagonship
Member#: 415111
car is fine, no overheat. Coolant seems not to be rising at the point of overflow the exp tank and radiator level not dropping. Took 2hrs trip both ways, then a lot o city driving, everything seems fine so far. thanks for the tip on the spill free. Tryed to fabricate my own, maybe doesn't worth the effort, but here it is
cheers
ps. found my old account here so it's me same guy gulps=wagonship
wagonship is offline   Reply With Quote
FS : 04 WRX DP. UP, Air Box Intake System, Alternator Cover Steeldon Engine/Power/Exhaust 13 01-27-2011 07:21 PM
Coolant temp up but oil temp is the same? ogboot Newbies & FAQs 5 04-15-2009 10:57 PM
HELP with air pocket. massdrewski Normally Aspirated Powertrain 7 11-29-2008 06:33 PM
Air pocket in cooling system. Questions. Obsessive Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 02-22-2008 08:51 AM
