Old 02-01-2002, 09:26 PM   #1
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default WRX ride height for DMS 40mm Gold
can someone tell me what the DMS prescribed Street and Gymkhana ride height settings are for the WRX? i'm doing the install of my revalved 40's and dave c. wasn't able to dig up a spec sheet for a WRX in time and i can't find my install instructions... :\
thanks
duckboy
duckboy is offline   Reply With Quote
Old 02-02-2002, 02:34 AM   #2
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default help...
anyone??? please......
i have some settings that i think would work based on when struts were on the car last time, but, i'd like to base things off of what DMS prescribes...
duckboy
Old 02-02-2002, 09:21 AM   #3
M.Coffman
Member#: 12613
2010 Legacy
Azurite Blue
Duckboy, You can set them at whatever height you please, thats why the adjustability range it so much. I personally like 1" to 1-3/4" in so the tire is about even with the wheel well. I am not a fan of "slamming it"
-Mike
M.Coffman is offline   Reply With Quote
Old 02-02-2002, 09:28 AM   #4
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Dunno. Call Dave, or email Jamie Drummond, who will know. His email address is at the DMS website, www.dmshocks.com.
I'm 1" down.
Kevin
gtguy is offline   Reply With Quote
Old 02-02-2002, 01:27 PM   #5
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
DMS recommended ride height is 350mm front and 330 mm rear, from the center of the wheel to the fender lip.
Someone just posted in another thread that the factory service manual says a stock sedan ride height is 396mm F, 376mm R (+/- 12mm), so that would be a 46mm drop, or about 1 4/5" drop.
Austin is offline   Reply With Quote
Old 02-02-2002, 08:54 PM   #6
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default height...
thanks all for the input.
i did get the units installed and almost got the whole ride height thing squared away. still getting the damping settings sorted out.
m. coffman, although i agree that coilovers do allow you to adjust the ride height to what ever you want, the DMS golds are ONLY to used with a drop of 30-40mm from stock. outside of that range, the shocks will either top too easily on extension or run up against the bump stops on compression.
the other reason why i was asking for DMS's prescribed settings was because i wasn't sure if DMS was trying to get more front weight biasing than the stock set up has. this is why the front on all WRX's and RS/TS's feel loose and vague when pushed at the limit. by weighting the front a bit more, the car has more front weight bias when under power and won't push/understeer as much. again, this is why i was curious as to what DMS had in mind...
again, thanks all for your input...
duckboy
DMS 40MM Gold Coilovers for sale!!!!!!! galli916 Suspension/Brakes/Handling 23 04-25-2007 10:13 PM
02+ wrx dms 40mm gold coilovers kenlee Private 'For Sale' Classifieds 9 07-01-2004 03:59 PM
DMS 40mm Golds for 02 WRX on a 00 2.5RS? evorev Brakes, Steering & Suspension 4 12-12-2003 09:56 AM
DMS 40mm Gold... CRAZY KEN Brakes, Steering & Suspension 3 08-09-2001 11:32 PM
What is the best price on DMS 40mm Golds??? Ru fan Brakes, Steering & Suspension 1 05-29-2001 06:35 PM
Message Board Statistics All times are GMT -4. The time now is 03:48 AM.
