Old 01-15-2008, 11:38 AM   #1
smurfwrx
Member#: 151928
09 Triumph S3
Default 2.0L bolt-on limit
Hey guys, haven't found any precise threads on this. My question is... I have an 02 WRX and want the following:
- evoIII 16g
- huge turboxs TMIC (staying top-mount for now)
- walbro fuel pump
- pe650 injectors
- water/alch injection
Can I run this on stock internals? Any of you that a similiar set-up or larger on stock internals? Is this safe with a good tune or is this pushing it? Please, don't tell me about how the power will be hard on my tranny.... PPG's sucka!
smurfwrx is offline   Reply With Quote
Old 01-15-2008, 11:46 AM   #2
Boostinwagon
Member#: 138070
2005 BoostinWagon
Here is my setup on stock internals:
FP EvoIII 16G
Hyperflow TMIC
255/lph Walbro
Deatchworks 650's
Catless header/uppipe
3in Turboback
Open source tune
This with a good tune should put you between 300-320 and that is kinda safe for stock internals. Just be carefull thats all. Good luck and expect to spend alotta money.
Boostinwagon is offline   Reply With Quote
Old 01-15-2008, 11:50 AM   #3
shootinsoobie
Member#: 71170
04 JBP
All Murdered Out
careful, yes....
also dont expect to have the stock motor go past 80k with those mods.
*CHECK YOUR OIL LIKE EVERYDAY*
shootinsoobie is offline   Reply With Quote
Old 01-15-2008, 11:56 AM   #4
smurfwrx
Member#: 151928
09 Triumph S3
yeah, see... I've heard that this would be safe and seems like I've heard of others running around the 350whp range and that's what I'm shooting for. I just don't want to get into rods, pistons, etc. I will eventually (like, when my motor blows or in about 4 years) drop a 2.5L in it and go rotated but I want something more than stg2 to tide me over. I really like the idea of the aforementioned set-up but I don't want to blow it up, ya' know?
** just saw the "your engine won't last past 80k" comment. I certainly don't want that. So... what would I need to run that safely OR what other "safer" set-up would you recco? I need more power but I need a reliable car. Ah... the balance of work and pleasure, desire and necessity. lol.
Old 01-15-2008, 12:07 PM   #5
xxxjuhstenxxx
Member#: 161666
2005 STI
CGM
I am trying to achieve the same amount of power, but iplan new internals, 20g, front mount, 650 injectors, wallbro fuel pump. I also plan on obtaining an 8000 rpm redline. Goodluck on the build.
xxxjuhstenxxx is offline   Reply With Quote
Old 01-15-2008, 12:09 PM   #6
Boostinwagon
Member#: 138070
2005 BoostinWagon
i have 60k on my car and its fine and as long as you dont beat on it all the time and keep up with regular maintenance you will be fine. I also plan on going built block and rotated when it grenades. Good Luck
Old 01-15-2008, 12:12 PM   #7
smurfwrx
Member#: 151928
09 Triumph S3
any idea on what kind of upgraded internals would be needed to max out that set-up? Forged pistons, I know, but what else and how much is some of that? I just assume it would be more cost-effective to wait for a complete engine swap later down the line but maybe I'm wrong? I don't know, I just know I need more power and want to do it safely.
Old 01-15-2008, 12:13 PM   #8
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
I would say more power and reliability are two words that dont go together. With mods like that you may run into some problems down the road and then you have to play detective to figure out where the issue is. Do you really want the hastle of knowing that you are pushing your motor to its limits, checking your oil every day All I am saying is that you and others that have done it are taking a risk of blowing something up. What is the real problem, are you trying to get to work faster. And I read your first post saying "dont tell me about my tranny". Well with that power you better consider your trans, because one mis shift, and it could go boom Now when you think about it, is that really a risk you are willing to take?
Just think about it. If something breaks, will you have the cash to fix it. Again, I am not trying to discourage you, just saying what might happen.
Good luck
Ryan
shamrock 05 is offline   Reply With Quote
Old 01-15-2008, 12:15 PM   #9
shootinsoobie
Member#: 71170
04 JBP
All Murdered Out
think of it this a way. stock= restrictions= reliable
no restrictions= fun= bigger turbo= not so reliable.
there is no "hit this amount of miles and your car goes boom", but it is safe to say from past owners that our little 2.slows rarely make it past said named benchmark with those types of mods.
im at 60k now stg2- ic hoses, short ram, header, UP, DP, Exhaust, ECUtek road tune. i dont kill my motor at all and expect it to be good for over 100k, if i keep it that long.
it seems the bearings in our motors are the crap point, due to improper oil levels.
think maybe vf series turbo, that will be more reliable than the evo III, but not as fun.
up to you man, your car, yourr rules. good luck!
Old 01-15-2008, 12:18 PM   #10
SideWay
Member#: 148497
04 Stage II WRX
Java Black Pearl
I think its all in the tune, obviously the higher mileage you got the tougher it is on the motor, but I've seen really conservative tunes with 18G's 20's even and dudes have been pushing them for a long time.
Tell your tuner your looking to daily drive and that you dont wan't an agressive map.
SideWay is offline   Reply With Quote
Old 01-15-2008, 12:18 PM   #11
shamrock 05
Member#: 120057
^^^^^With the proper oil level in the car at all times, you shouldn't have an problem with the spun bearing though, right?
Old 01-15-2008, 12:18 PM   #12
xxxjuhstenxxx
Member#: 161666
2005 STI
CGM
If I decide to not go with 8000 rpm redline I am gonna go with forged pistons, new rods, bearings, apr studs and maybe cams. If I go 8000 rpm then I am going to get a new crank as well.
Old 01-15-2008, 12:22 PM   #13
shootinsoobie
Member#: 71170
04 JBP
All Murdered Out
yes, correct, but it seems like some owners dont check that, therefore becoming a problem fast, making your car slow
Old 01-15-2008, 12:27 PM   #14
smurfwrx
Member#: 151928
09 Triumph S3
Good luck
Ryan
nah, you're good and your input is appreciated. I'm here to learn, not front like I know everything. I'm inquiring and your helping so no sweat.
The reason I say that about the tranny is that I have PPG's now so I didn't need a lecture on how "the stock tranny can't hold that power" b/c that is not the case in my case.
I'm not so foolish as to throw junk on my car that will destroy it. That's why I'm trying to figure out what it takes (specifically) to get a 2.0L to that mark safely OR what can I do to add some nice power on stock internals without being that near teh danger zone.
Everyone should know that I'm not a kid. I saved for a long time to buy this car and I treat it with the fear and respect it deserves. I RARELY run it up to 6k RPM and have launched once ever and don't plan to again unless I make a 1/4 run on a track. Not into drag racing (but may on rare occassion) but I do want to eventually make mine a time attack monster (after new motor and several years). So... all that being said, can we continue to talk this over and see what I may be able to do for now?
Old 01-15-2008, 12:35 PM   #15
smurfwrx
Member#: 151928
09 Triumph S3
hopefully Audiosavvy will join us in a moment and maybe he has some ideas. He's going to be running the same set-up I mentioned earlier minus the water/alch injection and seems to think it's good to go on stock intenals and that there shouldn't be much cause for concern. I know people are going to have different opinions but let's try to see some logic here.
Old 01-15-2008, 12:36 PM   #16
shootinsoobie
Member#: 71170
04 JBP
All Murdered Out
vf 34
550 cc
walbro
heder back exhaust
sti tmic
tmic splitter
stock airbox with k&n minus snorkus
new clutch
Old 01-15-2008, 12:38 PM   #17
smurfwrx
Member#: 151928
09 Triumph S3
Originally Posted by shootinsoobie View Post
vf 34
550 cc
walbro
heder back exhaust
sti tmic
tmic splitter
new clutch
and what kind of whp are we looking at on something like that? Man.. honestly I'm bummed that my game-plan may not be such a good one. I aim to know for sure though.
Old 01-15-2008, 12:40 PM   #18
Foska Oats
Member#: 144081
2003 WRX
Mods mentioned are safe for your car.
Try not to pump too much boost. The fact that you will have meth or alcohol, that can be good for about 20 - 22 psi.
But try not to go above that.
I have a friend with a VF22 and he has no injection system and pumps 22 psi.
This setup has been running now for over a year and he is on the track (drag) every other weekend.
His best time is 12.9 and he is making 280whp on our 90 octane pump gas.
And remember, Jamaica is pretty warm.
Foska Oats is offline   Reply With Quote
Old 01-15-2008, 12:42 PM   #19
shootinsoobie
Member#: 71170
04 JBP
All Murdered Out
300-310whp range.
best of the vf series. though smaller than the evoIII 16g. i like both and would put either on i guess.
Old 01-15-2008, 12:51 PM   #20
urwrxt02
Member#: 168503
2004 FORESTER XT
WHITE
Default Good Times
Accessport v2, UP, DP, CATBACK, SAMCO HOSES, INTAKE, AVCR, TT, DEFI GUAGES, BOV, and a vf22 runing 16 psi constantly. My fiance' drives this thing with a lead foot. Everything is going awesome. I am only at 20k on an 02 but she is a stickler for the oil changes/checks. Make sure that you stay/drive practical. I only know that in a few thousand miles I get to upgrade so I tell her to drive the pooh out of it! You should be good bro
Take care from Iraqistan!
urwrxt02 is offline   Reply With Quote
Old 01-15-2008, 12:58 PM   #21
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
115,000 on my 02 and have had the vf22 on there since about 73,000. I drive it every day. I don't autox yet and do the drag thing occasionally. But I do like to open it up at times and am lucky enough to have a couple of real good roads a mile form my house. So the car gets it share of abuse. Be deligent with your maintnance. Your car will be fine with the 16G and the other mods. The meth/h2o will help get you to where want and probably a little safer. You may want to think about ewg for greater boost control. Maybe an oil cooler might help the motor but I think your safe as long as you have a good tuner.
breathinez is offline   Reply With Quote
Old 01-15-2008, 01:03 PM   #22
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Dang dude you only have 20k on the original motor? You know that you could pump the boost up a tad more to like 19 and have a real good time. Oh never mind I see your Fiance' is the one driving and you didn't list any fuel mods. She might pop before you get back home. Good luck soldier
Old 01-15-2008, 01:23 PM   #23
04subyrex
Member#: 144873
2004 WRX evoIII/meth
66 Mustang 408w
I have a blouch evoIII, 650cc, meth/water, spearco tmic, aps turboback, and protuned by Scott Siegel at TopSpeed. 22psi peak boost tapering down to 18 at redline over 300whp. I have 60,000 miles on it now and he said i should be able to get another 100,000 miles off it. Of course I dont drive like a maniac all the time but i do push it on the weekends. stock internals, tranny and clutch
04subyrex is offline   Reply With Quote
Old 01-15-2008, 02:27 PM   #24
shootinsoobie
Member#: 71170
04 JBP
All Murdered Out
thats what i want but with a fmic!
Old 01-15-2008, 02:32 PM   #25
smurfwrx
Member#: 151928
09 Triumph S3
THAT is what I'm talking about!!! I have about 55k miles on mine and I had already planned on getting tuned at TopSpeed. I still have friends in ATL and thought I'd go there next time I'm down. That sounds excellent! So what's with the naysayers?
Assembly: 2.0L Heads on 2.5L block Kingpin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 110 09-26-2014 06:58 AM
Reliablity Of 2.0l heads on a built 2.5l block? rsw0124 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-30-2009 05:47 PM
2.0L alternator on a 2.5L??? HELP PLEASE VladiWrX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 04-18-2009 04:17 AM
STi Version 7 top-mount intercooler/throttle body hose. Direct 2.0L bolt-on. thrdeye Private 'For Sale' Classifieds 6 08-10-2005 02:08 PM
2.0L Block on EJ22 Soon2BturbodRS Normally Aspirated with bolt-on Forced Induction Powertrain 0 06-15-2003 11:18 PM
