Old 01-15-2008, 04:03 PM   #1
zavier
Member#: 141189
2007 2.5i (NBP)
2014 BRZ (DGM)
Default WRX LSD into 2.5i
Ok I have a question about the rear axles. I am planning on putting a 2005 WRX rear LSD into my car and I know I have to get a place to swap over the ring and pinion so that it works with my current transmission. But I wanted to know about the axles. Are the 2005 WRX rear axles interchangable with the 2006-2007 2.5i rear axles?
I called up my local dealer and they said in 2006-2007 the rear axles are the same part number for left and right but in 2005 the WRX had different part numbers for the left and right and I just want to confirm if this is true...cause if so I now need to find new axles...
So can I just reuse my 2007 2.5i rear axles with this 2005 WRX rear LSD?
edit: I did read the sticky about what years have LSD's and also the sticky on Axle Compatibility....but neither of those address the 2006-2007 axle lengths, that is why I am making a new thread.
zavier is offline   Reply With Quote
Old 01-16-2008, 08:35 AM   #2
zavier
Member#: 141189
2007 2.5i (NBP)
2014 BRZ (DGM)
bump...
can anyone at least supply the part numbers for the 2007 2.5i rear axles and the 2005 wrx rear axles?
Old 01-17-2008, 10:52 AM   #3
zavier
Member#: 141189
2007 2.5i (NBP)
2014 BRZ (DGM)
maybe this needs to be moved to the "Transmission (AT/MT) & Driveline" forum?
can i install 2.5L stuff into 2.5i?? kansai104 Newbies & FAQs 19 05-06-2010 09:15 AM
LSD into 2.5i? timbits Vancouver Impreza Club Forum -- VIC 29 12-18-2009 05:00 PM
Installing a trubo into 2.5i 07imprezadrifter Newbies & FAQs 8 10-12-2007 12:54 PM
Scoop into 2.5i hood... mxtwoforty Interior & Exterior Modification 7 02-05-2007 01:15 AM
WRX Rack Into 2.5i? modernist Brakes, Steering & Suspension 2 04-08-2006 10:11 AM
