Old 02-24-2013, 02:01 PM   #1
piddyplace
Member#: 181942
2002 wrx
Default Tuned for MBC but wanna run stock BCS again...
Whats up guys, hope someone has my answer. If my car was tuned with a MBC on it can I switch over to the stock BCS with out blowing anything up from running lean or such?
piddyplace is offline   Reply With Quote
Old 02-24-2013, 02:06 PM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Blow it up from running lean? No, since you wouldn't be touching anything related to the fueling system.
But from overboosting? Sure
Depends on how your boost control tables are set up in the tune.
the suicidal eggroll is online now   Reply With Quote
Old 02-24-2013, 02:10 PM   #3
piddyplace
Member#: 181942
2002 wrx
What should I look for?
Old 02-24-2013, 02:18 PM   #4
Member#: 51961
2005 STi
2012 WRX
What all is on the car? Maybe just flash an OTS stage 1 or 2 map. If you don't know what to look for, then you shouldn't try to tune the boost control system. It's not something you just sit down with one afternoon and nail it.
Old 02-24-2013, 02:31 PM   #5
piddyplace
Member#: 181942
2002 wrx
agreed just wondering cause its got a custom tune for the vf43 and new injectors with a catless up,dp and cat back.
Old 02-24-2013, 02:33 PM   #6
piddyplace
Member#: 181942
2002 wrx
I may be able to view the maps/tables what would give you the info to answer my question?
Old 02-24-2013, 02:41 PM   #7
Member#: 51961
2005 STi
2012 WRX
Was it ever tuned on the vf43 with the downpipe on the stock BCS, or has it always been using the MBC with that turbo?
Old 02-24-2013, 02:42 PM   #8
piddyplace
Member#: 181942
2002 wrx
Tuned using the MBC
Old 02-24-2013, 02:52 PM   #9
Member#: 51961
2005 STi
2012 WRX
Then you'll need to get the boost control system tuned.
Old 02-24-2013, 02:53 PM   #10
piddyplace
Member#: 181942
2002 wrx
ahh so how would i go form this to running a hybrid system? Would it be worth it?
Old 02-24-2013, 03:29 PM   #11
Member#: 51961
2005 STi
2012 WRX
You would get a tune for it. Whether or not it's worth it is a decision only you can make.
Message Board Statistics All times are GMT -4. The time now is 08:09 PM.
