#76 |
Member#: 142133
Vehicle:3 Jeeps And a Saab |
#77 |
Member#: 142133
Ok, I'm really second-guessing this whole self-tuning thing.. Maybe I should stop. I can't even get the spreadsheet right! LOL Here's what I got, will..
#78 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
PMed you.
#79 |
Member#: 142133
cool. email sent. thanks
#80 |
Member#: 71092
![]() You just had the spreadsheet set up wrong to make a graph from it. See how I added the MAFv's for your MAF Scaling Map into the MAFv column before your actual data and then pasted the Means and Modes beside the MAFvs to make it all line up in columns? ![]() I didn't check your data itself, you're on your own there. |
#81 |
Member#: 142133
sweet! I see my error in the spreadsheet, thank you for your help!
Now I can continue with the directions! ![]() |
#82 |
Member#: 142133
ty - in the last formula (cor g/sec), do i understand that for the Cor% row, you enter the 'mode' number? Or is it more so a "guess" of what you want to increase/decrease, judging by what the mode value is?
I.E. In the MAFv cell of the ROM, say it's 1.4v with 7.2 g/sec. The mode calculated from the log is -10.94. Would you enter "-10.94" in the Cor% cell, resulting in a Corr g/sec from 7.2 to 6.41, effectively "leaning out" a little, at that MAFv? |
#83 | ||
Member#: 71092
#84 |
Member#: 142133
awesome! LOL thanks for your patience with my n00b questions
#85 |
Member#: 67483
Vehicle:2005 WRX STi |
I plot out mode, median, and average(mean). Then I look at the three and decide what I want my correction to be (also plotting this). This last time I started to notice an offset across the board. So I had excel average my desired correction. Then applied that average correction to my injector scale and my proposed MAF changes. In this case I reduced the size fo the injectors (increased ST fuel scaler) by 1%. Then reduced my proposed MAF changes by the same amount.
I have a stock MAF + APS inlet + larger injectors. So I don't want to stray too far from the factory MAF settings. Just got back from a short test drive. Things look good. Still a tiny dip or bump or two. But slowly getting better. I just need to make sure my wideband readings at WOT are still close to the fuel table like I had them many moons ago. |
#86 |
Member#: 78394
Vehicle:03 Euro WRX MY03 Dirty White |
ty,
Using your method, I've got huge corrections, across the whole MAFv range. I've got an APS CAI 70mm, AVO turbo inlet, TurboXS TMIC. MAFv 0.94 0.98 1.02 1.05 1.09 1.13 1.17 1.21 1.25 1.29 1.33 1.37 1.41 1.48 1.56 1.64 1.72 1.8 1.88 1.95 2.03 2.11 2.19 2.27 2.34 2.42 corr g/s 1.7052 1.9488 2.1888 2.4955 2.9106 3.2982 3.62004 4.1825 4.64508 5.15592 5.67248 6.2894 6.9266 7.48 9.32695 10.685 12.848 15.539 17.796 20.920 23.218 25.451 29.344 32.186 36.45 39.854 The logs were generated after I increased the MAFv scale by 1.1 from the stock values (since I read on the forum that the stock is 65mm - after changing to 70mm, just scale by 70/65 = 1.1). Is that normal? |
#87 |
Member#: 78394
My correction values... corrections are mostly > 15
MAFv Mean Mode 0.94, , 0.98, 16.41 , 1.02, 14.26 , 1.05, 15.31 , 1.09, 15.14 , 18.75 1.13, 18.01 , 19.53 1.17, 18.54 , 16.4 1.21, 18.69 , 19.53 1.25, 18.52 , 18.75 1.29, 17.59 , 18.75 1.33, 16.79 , 17.18 1.37, 17.50 , 17.96 1.41, 16.42 , 17.96 1.48, 8.725 , 6.25 1.56, 12.54 , 11.72 1.64, 12.60 , 9.37 1.72, 13.98 , 13.28 1.8 , 17.77 , 18.75 1.88, 20.20 , 18.75 1.95, 20.78 , 22.65 2.03, 19.87 , 19.53 2.11, 17.26 , 14.84 2.19, 16.63 , 16.4 2.27, 13.91 , 12.5 2.34, 12.49 , 12.5 2.42, 10.47 , 9.37 |
#88 |
Member#: 71092
I have no personal experience tuning for that specific setup. However, there's a lot of things that could be going on, not the least of which is an actual mechanical issue with the car. I would try to find someone who has tuned that specific setup and ask them how much they had to modify the scaling. While every car is different, knowing what someone else did will at least tell you if you're in the ballpark or WAY off base.
#89 |
Member#: 71092
Again with the not having done this personally, but I'm pretty sure I remember discussion of this on either romraider or LGT and computing the scalar wasn't that simple (70/65).
#90 | |
Member#: 72829
W. Canada
Vehicle:2006 HTA68'd wagon Powered by RomRaider |
http://www.iwsti.com/forums/cobb-str...libration.html |
#91 |
Member#: 165749
South East
Vehicle:2007 No YELLING on the bus! |
so im using williaty's method described in the OP and im getting correction %'s of 8% and 9% for the first few MAF's... am I way way off or is this typical for the first MAF rescaling with a SRI?
i havn't gone any further because im afraid im way off but maybe im not. Any thoughts/opinions? thanks. |
#92 |
Member#: 71092
My lowest attainable MAFv needed scaled +22%, but it came back under 10% shortly after that:
![]() Which results in this: ![]() I'm still trying to get idle dialed in. Idle is a freakish place. I'm trying to get it to be pulling about 5% fuel at idle to make sure when the O2 sensor hasn't warmed up yet and started working that it's running rich enough to actually get itself started. |
#93 |
Member#: 78394
ty,
how do u read your first graph? is "change: the changes made to "stock" line that results in the "corrected" line? your stock and corrected line are very close, what does that indicate? btw, how do you know that idle is still not dialed in? some other questions: using your method, can I merge two log files together but adding the time column from the previous file to the next file I am adding? the reason is becoz my defogger switch always goes off after about 15-20mins and that stops the logging. So its quite impossible for me to get > 20mins worth of logging everytime. any implications? |
#94 | |
Member#: 78394
airboy, thanks for the link.. its very useful. I've compared my corrections with the ones in the link and they are quite close, so I guess I am doing ok. in fact, I just did a reflash with the new corrections and the car runs ok so far. I think I still need a few more iterations though. |
#95 |
Member#: 165749
South East
anyone using OpenOffice.Org Calc app? Im getting tons of #VALUE! errors when i try to use these formulas and I cant figure out why. OO.Org's forum is so far no help and google i can only find answers applied to Microsoft Office Excel and i tried those fixes and they aren't helping. I love openSource software like Enginuity/RomRaider, EcuFlash and OpenOffice.Org (not to mention Firefox) but im getting frusturated.
N/M, think i figured it out.. my universe just got 10x better. Last edited by RaceFaceXC; 02-23-2008 at 12:45 AM. |
#96 | ||||
Member#: 71092
Seriously, I dunno. This intake isn't screwing up the scaling much and I think that sort of a plot makes the values seem closer than it really is.Quote:
You can also use the 774 and newer builds and just click the "Log to File" button for long logs, which is what I do. |
#97 |
Member#: 165749
South East
I finally finished all the computing for my first stab at scaling the MAF and got
MAFv g/sec % cor cor g/sec 1.17 2.48 8.7 2.7 1.21 2.72 8.5 2.95 1.23 2.85 7.8 3.07 1.25 3.04 8 3.28 1.29 3.46 7.5 3.72 1.3 3.57 1 3.61 1.33 3.89 1 3.93 1.37 4.35 3.1 4.48 1.38 4.5 1 4.55 1.41 4.83 3.1 4.98 1.45 5.44 4.5 5.68 1.48 6.03 5 6.33 1.56 7.27 5 7.63 1.64 8.59 4.5 8.98 1.72 10 3.8 10.38 1.8 11.55 4.5 12.07 1.88 13.25 3.9 13.77 1.95 15.16 3.8 15.74 2.07 18.31 4.5 19.13 2.11 19.55 1.6 19.86 2.19 22.27 3.1 22.96 2.27 25.3 1.2 25.6 2.34 28.66 4.2 29.86 2.42 32.36 3.6 33.52 Anyone who skims this see anything out of the ordinary? seems to be ok to me but i am a little worried about adding so much more fuel @ the lower end and getting a super rich condition. is a lower end correction that severe typical for the first round of rescaling of an SRI n/a? thanks for any input/comments. I cant get the columns straight without making them worse... sorry. |
#98 | |
Member#: 71092
And look up a bit, I had to put the wammy on my scaling way more than you did. |
#99 |
Member#: 165749
South East
the wammy huh? you mean how you were up 22% at one point? I loved that gameshow. Big Money.. no wammy.. STOP!
#100 |
Member#: 4574
NESIC
Vehicle:2011 Legacy 2.5i LMT Silver |
Sounds similar to this:
http://www.romraider.com/forum/topic1871.html It is what I used and automated. -Rene |
| Thread Tools | |
| Display Modes | |
| need help with scaling the MAF | 07wrx4life | Open Source Reflashes | 11 | 05-21-2008 02:21 PM |
| One man's trek across 5 dealerships in the Bay Area... | fluxwl | Dealership Reviews | 1 | 07-14-2004 06:45 PM |
| One man's junk is another man's needed subaru part | mynew02 | Private 'For Sale' Classifieds | 44 | 05-01-2004 08:40 PM |
| One man's junk.... | chkltcow | Off-Topic | 15 | 04-12-2004 04:41 PM |
| One man's trash is another man's treasure... | Jarvis | Texas Impreza Club Forum -- TXIC | 13 | 04-22-2002 11:07 PM |
