Old 04-19-2008, 10:24 PM   #126
Rogan
Member#: 142133
3 Jeeps
And a Saab
Originally Posted by williaty View Post
The one person working on Subaru defs is also the person trying to get real time tuning working. RT comes out before he resumes work on the Subaru defs.
:happydance:
I just tried the rev037 MAF tab. it's much "tighter" scatterplot than the previous test releases. With no ROM change, my scatter plot went from +/- 10% to +/- 7%.
I think tomorrow, Ty, I'm pulling the 3" MAF, and putting in a 65mm inlet (temp) to scale the injectors/latency tables. Then once they're squared away, put the 3" back in, and start on the MAF again.. THis "chasing my tail" trying to scale both, simultaneously, is for the birds
THEN, I'll start on OL again..
Rogan is offline   Reply With Quote
Old 04-20-2008, 01:44 AM   #127
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
There have been no additional definitions released since the initial release for the NAs. The one person working on Subaru defs is also the person trying to get real time tuning working. RT comes out before he resumes work on the Subaru defs.
WTF? I DIDN'T post that in this thread! That went into the NA tuning thread!
EDIT: Crazy, the thread I actually did post that in no longer exists in the NA forum. It's been deleted or something.
Old 04-20-2008, 01:50 AM   #128
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Also, to post something actually relevant to the thread, I finally gave up trying to chase my MAF scaling in circles with the temperature changes and zeroed the temp compensation table. I'll see if it's any more steady this way, and if it's not, at least I can use one day's scaling as a starting point for building a new compensation table.
Old 04-30-2008, 11:32 PM   #129
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
dude, send me your logs. I have the program that will split it up by temps
Wheeler Bement is offline   Reply With Quote
Old 05-01-2008, 12:04 AM   #130
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Actually, zeroing everything but the MRP compensation table seems to have helped things tremendously.
Old 05-01-2008, 12:14 AM   #131
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
which maps did you zero? My engine load map came zeroed(don't know if I may have picked it up in a "stock download") I noticed that the MAF comp table will only let you select values of .8 multiples, which appears to be too big for what we want to do anyway.
Old 05-02-2008, 12:31 AM   #132
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Zeroed Temp comp of load and Throttle Opening angle comp of load. Mainly because both of those are either 0 or non-existant on other years of RSes. Considering zeroing the MRP comp of load as well, but other models do use that.
Old 07-28-2008, 11:27 PM   #133
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
/thread
Old 07-29-2008, 12:16 AM   #134
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
Educational read. This should be a sticky in the open ecu section as how to tune. How long did you log to get all of that data? Combined time...
srREXed is offline   Reply With Quote
Old 07-29-2008, 12:22 AM   #135
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
It was just a trip to the store and back. Of course, the store is about 40min 1 way...
~1hr log is the shortest you can reasonably work from.
Old 07-29-2008, 02:45 AM   #136
Riles
Member#: 121154
2002 Impreza WRX PSM
Stage 47, Romraided
Just curious about what's the most amount that you can log?
Riles is offline   Reply With Quote
Old 07-29-2008, 03:00 AM   #137
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You know, I haven't hit it yet, and I've logged for more than an hour a couple of times. The limit is either going to be the maximum Windows file size, or when the variable tracking Time in RomRaider overflows.
Old 07-29-2008, 05:46 AM   #138
kascade
Member#: 124395
I would be interested in the answer to this as well. I would think the max windows file size would most likely be the limit. It definitely won't be the time variable (unless you plan on logging for the next 300million years ). If you were using the maf tool however I suspect it wouldn't last anywhere near as long due to memory requirements needed hold and display all the data.
kascade is offline   Reply With Quote
Old 07-29-2008, 09:34 AM   #139
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
I know I have logged for 2:30 hours straight once for my maf scaling. Yeah there was a lot of data!!
Oh and skimming through it to check for any knocking, not fun.
-Rene
Rene2.5RS is offline   Reply With Quote
Old 07-29-2008, 10:11 AM   #140
Rogan
Member#: 142133
3 Jeeps
And a Saab
sort-function is my friend
Old 07-29-2008, 10:24 AM   #141
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Don't want to use sort function because I want to see everything not just the highest knock count, I've tried and and looked at the data and said that was pointless. I want to be able to see before during and after. Have to be able to tell if it is slowly counting back to zero or if it pulls timing again. I have not found an easier way of doing it.
-Rene
Old 08-01-2008, 10:33 PM   #142
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
williaty, quite bragging untill you are +/-2...raw unfiltered data.
Old 08-01-2008, 11:37 PM   #143
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Actually, the bragging wasn't about the accuracy. That was actually pre-tuning. I cleaned my MAF and had to totally re-do the MAF scaling. It's about +-1.78 most days now. Well, +-1.78 of where I want it to be as I want it to be pulling a little fuel in a couple of the ranges so if/when my O2 sensors fail, it runs a little rich rather than a little lean.
The bragging was about my being able to force Excel to graph 35k points. The index variable overflows at 32k.
Old 08-01-2008, 11:50 PM   #144
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
mmmmm, interesting
Old 04-25-2009, 02:42 AM   #145
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
How is it that your IAT's stayed so low... Below temp of freezing for water? I know Ohio can get cold, but man... Unless you meant C instead of F.
How did you beat the 32k limit... I must know.
formula91 is offline   Reply With Quote
Old 04-25-2009, 11:50 AM   #146
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
No, that was real. Looks like the outside temp when I took that was about 29F. Which, btw, is not really cold at all. 0F with wind starts to feel cold. However, I've been sleeping outside in Ohio when it was -30F, so that actually qualifies as cold.
Had to run it in two different series and plot them on the same graph.
Old 04-26-2009, 10:54 AM   #147
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Brilliant! (thx for sharing)
bcblues is offline   Reply With Quote
Old 04-27-2009, 01:58 AM   #148
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
That's pretty beast.
It's about 75F right now in Chicago, and I'm running 90F consistently on the highway with the hybrid intake cut a little short so it would draw from the fender. I hope something isn't wrong with my car. Oh well.
Now if I could get that stupid DBW map to work well with my TCU, I'd be happy.
(Not to be off topic but I did start another thread about it, much would be appreciated if you could help)
Old 04-27-2009, 10:24 PM   #149
bcblues
Member#: 17256
04 STi
My K&N semi short ram runs about 15 degrees hotter than ambient, unless I am sitting in traffic.
Old 04-29-2009, 01:05 AM   #150
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Ok, cool, that's good to know.
I would like to think I'm running a little cooler. The summertime will tell I suppose.
need help with scaling the MAF 07wrx4life Open Source Reflashes 11 05-21-2008 02:21 PM
One man's trek across 5 dealerships in the Bay Area... fluxwl Dealership Reviews 1 07-14-2004 06:45 PM
One man's junk is another man's needed subaru part mynew02 Private 'For Sale' Classifieds 44 05-01-2004 08:40 PM
One man's junk.... chkltcow Off-Topic 15 04-12-2004 04:41 PM
One man's trash is another man's treasure... Jarvis Texas Impreza Club Forum -- TXIC 13 04-22-2002 11:07 PM
