Old 01-16-2008, 10:55 AM   #1
wittmer25
Member#: 102970
2004 STi gt30r
Default Maximum AVCS Advance w/ Cosworth cams?
I had this in the built motor forum but was not getting enough info. What is the max intake cam advance you can run with the 278/274 10.7mm lift cams? Assuming an ej257, 100mm wiesco piston, .051" head gasket, usdm sti heads. I am just days away from starting up my new built motor.
Jonathon
wittmer25 is offline   Reply With Quote
Old 01-17-2008, 09:01 PM   #2
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
the cosworth int cams have -8 degrees grnd into them so you should be safe at the 20 degree avcs advance that most ecus have.the avcs advance is mostly to help spool and low end power and torque,if you look at the map it will probably go to zero at or near 5000 rpm because it will make more power up top with a little bit of cam retard---even though the map is at zero the -8 degrees ground into the cam retards you up top---i hope this explanation helps you
john 1badSTI is offline   Reply With Quote
Old 01-17-2008, 10:16 PM   #3
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Honestly, I wouldn't run any more than 16 (-8 + 16 = 8) without first checking with cosworth.
ExpO is offline   Reply With Quote
Old 01-17-2008, 10:34 PM   #4
john 1badSTI
Member#: 77470
i have put together 2 motors with cosworth cams that are running with the maps that came in the hydras and the maps run 20 degrees midrange with no issues.one motor ina an 04 sti went 10.71 on a utec with a ur 35r setup 2 yrs ago it since has a hydra.the other one went 10.93 on 28lbs with afs at 11.7 on c16 on a shakedown pass
Maximum AVCS Advance w/ Cosworth cams? wittmer25 Built Motor Discussion 44 02-08-2010 10:12 AM
Cosworth cams on AVCS problem butt_crack Built Motor Discussion 21 08-13-2009 11:37 AM
maximum AVCS with BC 272 cams for EJ257? benw Built Motor Discussion 10 12-20-2008 12:31 PM
Cosworth Cams EJ25-Material added? (What other Cams are as well?) EjtwentyfiveSti Built Motor Discussion 5 04-16-2007 10:15 PM
AG970 STi RA ECU and AVCS Advance... 30 degrees? dug-e-fresh Engine Management & Tuning 0 11-04-2003 03:10 PM
